Now with experimental support for extensions in the latest version which was just released. Thought maybe some one would be interested to check it out.
BRUH!!
I remember each time i try dat one ~ F-Droid repo is down ~ can’t even install it! ![]()
/// ping me when it works ///
Download the APK directly from Github.
Or use Obtainium.
Naah bro, my way is F-Droid!
No-trust in .apk / Obtanium for me.
You’d need more than luck with that bro!
Cos F-Droid don’t build Cromite. ![]()
I mean for long-term updates yo!
/// Guys can’t even run a proppa working F-Droid repo since 2023 ///
Not sure it’s great idea to trust in their browser either ![]()
I’ve used Bromite back in a day though, it worked great!
