AMD/Nvidia card priority, NOT hybrid (SOLVED)
I have a 6900XT and a Quadro P4000.
For the life of me I cannot get the OS to prioritize the AMD card, and everything just runs on the Quadro.
How do I get it to stop doing this, and just default to the AMD?
Hello @Cerberus
Is it possible to give the hardware info first of all. What type of laptop is it make and model. I’m assuming it’s a laptop? Post the url for the hardware output.
inxi -Faz | eos-sendlog
It’s a desktop. it’s not a hybrid solution, it’s two dedicated GPU’s.
https://0x0.st/HXO6.txt
It’s showing that it is rendering from the AMD graphics.
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon RX 6900 XT (navi21
    LLVM 15.0.7 DRM 3.49 6.2.10-arch1-1) direct-render: Yes
Why do you think it’s using the Quadro P4000?
Yes, I wasn’t sure by the title what you meant. :wink:
Because every game I load, mangohud shows the P4000 in use, and there’s zero load on the 6900 when I look at corectrl.
Horrible workaround: Move /usr/share/vulkan/icd.d/nvidia_icd.json somewhere away from that folder.
Force RADV driver with this: https://www.reddit.com/r/linux_gaming/comments/h8b7zv/amd_gpu_vulkan_driver_how_to_easily_switch/
Also an internet search brought up this: https://github.com/aejsmith/vkdevicechooser
I’m not sure if you can use one of the methods that are used with Hybrid setup?
In my Lenovo Legion firmware I can flat out turn off the switchable graphics which then uses the dgpu always. . .
So, basically I’m saying, check out your firmware.
Can you blacklist nvidia and nouveau?
I was going to suggest that too. Not sure why the OP wants to use both Gpu when the Radeon 6900XT is over 200% better. :thinking:
It’s neither a laptop, not a hybrid setup.
Nvenc and CUDA.
Does it have to be an 8 gig quadro? No. that’s just what I had sitting around that fit in the case.
I was just wondering why you don’t just use the Radeon card on it’s own? :innocent:
It has neither nvenc nor cuda, both of which I need.
I don’t plan to use the quadro for anything other than a processing unit, but for some reason it’s not only grabbing priority, but it’s also feeding video through the AMD.
Followed the ENV modification advice in there, in my case I had differing files, as expected:
l> s /usr/share/vulkan/icd.d/
./ …/ amd_icd32.json* amd_icd64.json* amd_pro_icd64.json nvidia_icd.json
so I edited my /etc/environment and stuck this on the bottom and rebooted. (there was no VK_ICD line to begin with, for clarification.)
VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/amd_icd64.json:/usr/share/vulkan/icd.d/amd_icd32.json
All is right in my rig once again thanks to you.
