AMD GPU fan speed N/A
Running sensors I get
it8718-isa-0290
Adapter: ISA adapter
in0:           1.12 V  (min =  +0.00 V, max =  +4.08 V)
in1:           1.92 V  (min =  +0.00 V, max =  +4.08 V)
in2:           3.36 V  (min =  +0.00 V, max =  +4.08 V)
+5V:           3.01 V  (min =  +0.00 V, max =  +4.08 V)
in4:         480.00 mV (min =  +0.00 V, max =  +4.08 V)
in5:           0.00 V  (min =  +0.00 V, max =  +4.08 V)  ALARM
in6:          64.00 mV (min =  +0.00 V, max =  +4.08 V)
in7:           3.10 V  (min =  +0.00 V, max =  +4.08 V)
Vbat:          3.20 V
fan1:        1360 RPM  (min =    0 RPM)
fan2:           0 RPM  (min =    0 RPM)
fan3:           0 RPM  (min =    0 RPM)
fan4:           0 RPM  (min =    0 RPM)
temp1:        +37.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
temp2:        +29.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermal diode
temp3:         -2.0°C  (low  = +127.0°C, high = +127.0°C)  sensor = thermistor
cpu0_vid:    +1.275 V
intrusion0:  ALARM
amdgpu-pci-0100
Adapter: PCI adapter
fan1:             N/A
edge:         +36.0°C  (crit = +120.0°C, hyst = +90.0°C)
coretemp-isa-0000
Core 0:       +39.0°C  (high = +82.0°C, crit = +100.0°C)
Core 1:       +42.0°C  (high = +82.0°C, crit = +100.0°C)
Core 2:       +37.0°C  (high = +82.0°C, crit = +100.0°C)
Core 3:       +36.0°C  (high = +82.0°C, crit = +100.0°C)
The GPU fan speed is not reporting. I run sensors-detect, did a restart and it still doesn’t show.
I’ve somewhere about settings the GPU fan to PWM instead of DC in BIOS, but my mobo doesn’t have anything like that (it’s pretty old).
Any ideas?
You could try installing Xsensors, AUR package.
Also not all motherboards have the sensors, if missing it probably isn’t there.
You are probably right. It’s an old mobo (gigabyte p35-ds3 rev.2) and in the BIOS I don’t remember seeing any options about the GPU.
P.S.: It’s somewhat a “wasted” thread as it turns out. If it should be deleted, let me know (or just do it).
