However.
If you back up your /home you can reuse a lot of config files. I especially suggest backing up the entire .mozilla folder if you use Firefox and everything under .config that is for an app you will install again.
It is possible (probably).
It is possible to convert whole disk (e.g. /dev/sda) to an image and then copy this image to a new disk. Then you have to adjust partition size (that is probably the most risky part).
I did some modification based on this link to create a full image backup for my raspberry pi - partitions, UUIDs are kept, only thing that has to be fixed is partiton size. When you do dd to a slightly different disk you may run into a trouble.
This script is designed for raspberry pi but you can take it as a starting point.
But on the other hand you can just backup your /home and /etc (if you modified it) and just do a fresh install.
My modification if you are interested
#!/bin/bash
# Copyright 2016 - Matteo Mattei <matteo.mattei@gmail.com>
# https://www.matteomattei.com/how-to-shrink-raspberry-pi-backup-images/
# This script is intended to be used to shrink raspberry pi images
# created with dd client command.
# Check if you are root
if [ ! $(id -u) -eq 0 ]; then
echo "ERROR: This program must run as root"
exit 1
fi
# Check if all necessary dependencies are installed
if [ -z "$(which dd 2> /dev/null)" ]; then
echo "ERROR: dd command not found - please install it and retry"
exit 1
fi
if [ -z "$(which parted 2> /dev/null)" ]; then
echo "ERROR: parted command not found - please install it and retry"
exit 1
fi
if [ -z "$(which losetup 2> /dev/null)" ]; then
echo "ERROR: losetup command not found - please install it and retry"
exit 1
fi
if [ -z "$(which resize2fs 2> /dev/null)" ]; then
echo "ERROR: resize2fs command not found - please install it and retry"
exit 1
fi
if [ -z "$(which truncate 2> /dev/null)" ]; then
echo "ERROR: truncate command not found - please install it and retry"
exit 1
fi
if [ -z "$(which gzip 2> /dev/null)" ]; then
echo "ERROR: gzip command not found - please install it and retry"
exit 1
fi
if [ -z "$(which 7za 2> /dev/null)" ]; then
echo "ERROR: 7za command not found - please install it and retry"
exit 1
fi
if [ -z "$(which zerofree 2> /dev/null)" ]; then
echo "ERROR: zerofree command not found - please install it and retry"
exit 1
fi
# argument parse - TODO
SOURCE="${1}"
IMG="${2}"
dd if=${SOURCE} of=${IMG} bs=64M status=progress
# Check if the file exists
if [ ! -f ${IMG} ]; then
echo "ERROR: File ${IMG} does not exist"
exit 1
fi
# Synchronize cached writes to persistent storage
sync
# add filesystem extend script to /boot/cmdline.txt to run it during first boot
BOOT_START=$(parted ${IMG} unit B print | grep -i fat | awk '{print $2}')
BOOT_SIZE=$(parted ${IMG} unit B print | grep -i fat | awk '{print $4}')
BOOT_START=${BOOT_START::-1}
BOOT_SIZE=${BOOT_SIZE::-1}
BCKP_TMP="bckp_tmp"
mkdir ${BCKP_TMP}
mount -v -o offset=${BOOT_START},sizelimit=${BOOT_SIZE} -t vfat ${IMG} ${BCKP_TMP}
sed -i '$s|$| init=/usr/lib/raspi-config/init_resize.sh|' "${BCKP_TMP}/cmdline.txt"
umount ${BCKP_TMP}
rm -r ${BCKP_TMP}
# Create loopback file to modify ext4 partition
INFO=$(parted -m ${IMG} unit B print | grep ext4)
NUM=$(echo ${INFO} | awk -F':' '{print $1}')
START=$(echo ${INFO} | awk -F':' '{print $2}')
OLD=$(echo ${INFO} | awk -F':' '{print $3}')
DUMMY=$(echo ${INFO} | awk -F':' '{print $4}')
START=${START::-1}
OLD=${OLD::-1}
LOOPBACK=$(losetup -f --show -o $START $IMG)
e2fsck -p -f ${LOOPBACK}
if [ ! ${?} -eq 0 ]; then
echo "ERROR: filesystem seems corrupted"
losetup -d ${LOOPBACK}
exit 1
fi
# Zero garbage blocks from old deleted files to reduce size of final
zerofree -v ${LOOPBACK}
# Shrink ext4 partition
INFO=$(resize2fs -P ${LOOPBACK} 2>&1)
SIZE=$(echo ${INFO} | awk -F': ' '{print $2}')
SIZE=$((${SIZE} + 1024))
resize2fs -p ${LOOPBACK} ${SIZE}
SIZE=$(( ${SIZE} * 4096 + ${START} ))
parted ${IMG} rm ${NUM}
parted -s ${IMG} unit B mkpart primary ${START} ${SIZE}
SIZE=$(( ${SIZE} + 58720257 ))
truncate -s ${SIZE} ${IMG}
# Make a compressed image
echo "compressing image..."
7z a -t7z -m0=lzma2 -mx=9 ${IMG}.7z ${IMG}
rm ${IMG}
echo "done"
I guess if you had LVM installed you could add the new disk as a new physical volume to the group, and then move the logical volumes from the old disk(PV) to the new one. But i think /boot is outside LVM and probably would involve a new grub install
I did this more than a year ago - it isn’t painless.
I moved from spinning rust to M2 NVME.
I had/have multiple distros installed - so the objective was to migrate all installations.
In theory just replicating the partitions using dd should work - assuming that the new ssd is the same size or larger than the old disk.
<edit>But I used partclone to copy partitions
Stating the obvious - but better safe than sorry - when cloning, none of the partitions should be mounted/ in use.
I complicated things by expanding some of the partitions.
I keep an installation of supergrubdisk2 handy, and that made it less painful to boot the new partitions when I messed up.
Once booted in the EndeavourOS - I reinstalled grub
You may also have to do something like,
First time is not painless, practice in a VM first can help, subsequent times it takes only minutes.
Create partitions for new location.
From live environment …
– Use partclone to backup your root file system.
– Use partclone to restore your root file system to new root partition.
– Use uuidgen and tune2fs to change the restored file system UUID.
– Chroot into new root file system and change any old UUID references in /etc/default/grub, /etc/fstab, /etc/crypttab, etc.
– For EFI systems mount efi partition in chroot and re-install grub.
– Regenerate initramfs’ using mkinitcpio -P
– Use efibootmgr to ensure new boot order is correct.
Reboot into your system in a new location.
I’ve cloned my system many times using this technique. Seems complicated but it really is not.
I always keep post update (usually weekly) partclone images of all my systems on backup media. I can use these for disaster recovery, ie disk failure, or to restore if the main system becomes borked. With recovery omit the UUID editing stuff.
If you have a fully encrypted system simply open the luks container with cryptsetup before running partclone. On your new location luks encrypt your root partition first. Include the new luks container UUID in the UUID editing steps above.
Generating package list for programs installed from the OFFICIAL repositories
In the following example I’m using -Qqe option, but you can manually edit this list or make your own with only desired packages pacman -Qqe >installed_packages.txt
or pacman -Qe | awk ‘{print $1}’ > installed_packages.txt
(Edit the generated list as you wish using your prefered text editor)
and
Generating package list for programs installed from the AUR packages
NOTE: this actually lists any package external from official repositories, so EndeavourOS packages are also listed here. pacman -Qqm >aur_packages.txt
then
Installing to another computer or reinstalling to your current one
–>First copy the generated .txt file(s) to the Desktop. Open Terminal and type < cd Desktop >. Then run the one or more of the following:
There are multiples ways to accomplish this installation; here are a couple of examples:
–>For official Arch repositories, if you have one package by line in installed_packages.txt, you can:
sudo pacman -S $(cat installed_packages.txt |xargs) --needed --noconfirm
Or even:
for x in $(cat installed_packages.txt) do sudo pacman -S $x --needed –noconfirm
and
–>For the AUR, if you have one package by line in aur_packages.txt, you can: yay -S $(cat aur_packages.txt |xargs) --needed --noconfirm •
–needed will only install new packages, so you won’t waste time reinstalling the already installed
–noconfirm won’t prompt the confirmation step “Do you want to install?”. Recommended for both methods but
especially for the second method and with huge list of files
But, better yet, (and this is what I do)
OR merge both generated files into one new text document [Create Document] (named complete_installed_packages.txt) and install with yay instead of pacman. yay -S $(cat complete_installed_packages.txt |xargs) --needed --noconfirm
I must thank fernandomaroto who was the person who sent these instructions to me. I have “cloned” several computers onto which I have installed EnOS and then, using these instructions, obtained “duplicates” of my original computer.
Believe it or not, it “reads” more complicated than it is and it is really easy to accomplish (in my opinion).
