As I described. Symboltray from Akregator (FeedReader) doesnt work.
It is displayed in the system tray, but I can only close Akregator. Maximizing/Restoring from Akregator does not work. I thought I’d wait to see if it was fixed with Plasma 6.0.2, but it’s not.
I had some weird issues in Haruna last night and solve the issue by delteting my old config. It seems they’d slightly changed the interface that stopped my setup from working.
Yes I’ve run across a lot of little bugs that are just left overs from the update. Most of them fixed in seconds with the changing of a setting or by removing the old config
I think so. Exit works. Opening and closing also works. I have tried it several times now and it still works as it should.
Who knows what was written in the old akregatorrc file.
