Tested AI Grok model with the following task:
Redact (blur) any user sensitive info in this screenshot
Result in less than 2m:30 sec
You could have done that in about 15 seconds.
Correct, it was a test.
The task is a high level, one sentence prompt. Humans, are very capable of understanding the task, and >> if skilled in IT << , they can understand what screenshot means, what fields are sensitive, what has to be redacted, and use the correct tools to accomplish the job.
The task was accomplished successfully, time-to-finish is 2:30 but as you noted skilled humans can do it 15 sec. Cognitively AI is advancing, Speed and cost is secondary to the capability of accomplishing the task successfully from the first time.
My point (although poorly made) was that it is still better to do it yourself. There’s nothing to say AI won’t advance to the point it will be better at it than us. And on that day, I will welcome our robot overlords!
If I was given this task I would blur the entire image and then accuse you that you did not clarify what is sensitive for you. ![]()
