After upgrade to virtualbox 7.2.4-1 VM starts fail with VERR_SYMBOL_NOT_FOUND
After upgrading to virtualbox 7.2.4-1 I cannot start any VM. I’ve tried to start a Windows 11 VM and I get this error:
00:00:00.937491 VMMR0.r0 is importing SUPR0EnableHwvirt which we couldn't find
00:00:00.937493 AssertLogRel /build/virtualbox/src/VirtualBox-7.2.4/src/VBox/HostDrivers/Support/SUPLibLdr.cpp(273) int supLoadModuleResolveImport(RTLDRMOD, const char*, const char*, unsigned int, RTUINTPTR*, void*): <NULL>
00:00:00.937494 VMMR0.r0 is importing SUPR0EnableHwvirt which we couldn't find
00:00:00.937496 SUP: RTLdrGetBits failed for VMMR0.r0 (/usr/lib/virtualbox/VMMR0.r0). rc=VERR_SYMBOL_NOT_FOUND
00:00:00.937647 PDMLdr: pdmR3LoadR0U: pszName="VMMR0.r0" rc=VERR_SYMBOL_NOT_FOUND szErr="Unable to locate imported symbol 'SUPR0EnableHwvirt' for module 'VMMR0.r0'"
00:00:00.937652 VMSetError: /build/virtualbox/src/VirtualBox-7.2.4/src/VBox/VMM/VMMR3/PDMLdr.cpp(749) int pdmR3LoadR0U(PUVM, const char*, const char*, const char*); rc=VERR_SYMBOL_NOT_FOUND
00:00:00.937653 VMSetError: Failed to load R0 module /usr/lib/virtualbox/VMMR0.r0: Unable to locate imported symbol 'SUPR0EnableHwvirt' for module 'VMMR0.r0'
00:00:00.937661 VMSetError: /build/virtualbox/src/VirtualBox-7.2.4/src/VBox/VMM/VMMR3/VM.cpp(591) int vmR3CreateU(PUVM, uint32_t, PFNCFGMCONSTRUCTOR, void*); rc=VERR_SYMBOL_NOT_FOUND
00:00:00.937662 VMSetError: Failed to load VMMR0.r0
00:00:00.937856 ERROR [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={6ac83d89-6ee7-4e33-8ae6-b257b2e81be8} aComponent={ConsoleWrap} aText={Failed to load R0 module /usr/lib/virtualbox/VMMR0.r0: Unable to locate imported symbol 'SUPR0EnableHwvirt' for module 'VMMR0.r0' (VERR_SYMBOL_NOT_FOUND).
00:00:00.937862 Failed to load VMMR0.r0 (VERR_SYMBOL_NOT_FOUND)}, preserve=false aResultDetail=-609
00:00:00.937950 Console: Machine state changed to 'PoweredOff'
I’ve reinstalled the complete virtualbox packages but no change. I’ve checked that the virtualbox and the virtualbox-host-modules-lts are both on version 7.2.4.-1:
❯ pacman -Q | grep virtual
virtualbox 7.2.4-1
virtualbox-guest-iso 7.2.4-1
virtualbox-host-modules-arch 7.2.4-1
virtualbox-host-modules-lts 7.2.4-1
I have both the arch and the lts version of virtualbox-host-modules-… installed because I have the standard kernel and the lts kernel installed. I’ve checked that the correct module is loaded:
❯ uname -r
6.12.53-1-lts
❯ modinfo vboxdrvfilename:       /lib/modules/6.12.53-1-lts/extramodules/vboxdrv.ko.zstversion:        7.2.4 r170995 (0x00340001)license:        GPLdescription:    Oracle VirtualBox Support Driverauthor:         Oracle and/or its affiliatessrcversion:     093FA893C2464C5DFBB82FDdepends:name:           vboxdrvretpoline:      Yvermagic:       6.12.53-1-lts SMP preempt mod_unloadparm:           disabled:Disable automatic module loading (int)parm:           force_async_tsc:force the asynchronous TSC mode (int)
Has anyone experienced this error or can someone help me fix it?
Greetings, Jens
I’m running the same version and it starts up Linux boxes just fine. I don’t have a Windows licence to test that.
I have a Linux Mint VM and the error is the same when I try to start it.
The only thing I can see is that I’m using virtualbox-host-dkms. Maybe someone with more knowledge will come along.
I assume that I don’t need the virtualbox-host-dkms because https://wiki.archlinux.org/title/VirtualBox states:
Install the virtualbox package. You will also need to choose a package to provide host modules:
I’ve also looked in the /var/log/pacman.log but I don’t see any entry for virtualbox-host-dkms.
Yeah, it’s an either or. The dkms package rebuilds the modules after a virtualbox or kernel update.
Try rebuilding your kernel images. Reboot and test.
i had the same issue.
remove and reinstalling virtualbox didn’t worked.
after i had read @MyNameIsRichard post i also tried with the dkms-moduls and it worked. so i switched back to the arch-modules to verify the issue BUT…surprisingly it also worked with them.
so this may be a little workaround for now until devs find the faulty bits.
cheers!
sudo reinstall-kernels
did the trick for me.
Thank you for your solution to my problem. I marked the other answer as solution because he typed the command to rebuild the kernel.
