tankas
October 22, 2023, 8:17am
1
Hi, I did the updates. Ran akm, selected the Zen kernel, and being noob de-selected the standard kernel.
Now cannot boot into the OS. Even if select the fallback kernel.
I have an installation USB, can arch-chroot.
How can I fix this, please help.
extra/linux-zen 6.5.8.zen1-1 [installed]
The Linux ZEN kernel and modules
extra/linux-zen-headers 6.5.8.zen1-1 [installed]
Headers and scripts for building modules for the Linux ZEN kernel
tankas
October 22, 2023, 8:23am
2
[…@EndeavourOS /]$ journalctl -b -0 | grep fail | eos-sendlog
==> eos-sendlog-helper: warning: nothing to send.
[…@EndeavourOS /]$ grep -i upgraded /var/log/pacman.log
[2023-10-21T17:01:24+0100] [ALPM] upgraded archlinux-keyring (20230918-1 -> 20231017-1)
[2023-10-21T17:03:29+0100] [ALPM] upgraded adwaita-cursors (44.0-1 -> 45.0-1)
can you provide
inxi -Fza
you should run akm under chroot or add kernel & kernel-LTS
pacman -S kernel kernel-headers
pacman -S kernel-lts kernel-lts-headers
tankas
October 22, 2023, 10:44am
4
Stephane:
can you provide
inxi -Fza
[tank@EndeavourOS /]$ inxi -Fza
12System:
tankas
October 22, 2023, 10:47am
5
I tried it first thing when I arch-chroot it.
[root@EndeavourOS /]# akm
[root@EndeavourOS /]# ==> Config file /etc/akm.conf read.
==> Info: detecting available kernel packages.
Authorization required, but no authorization protocol specified
(yad:66): Gtk-WARNING **: 11:48:34.311: cannot open display: :0.0
/usr/bin/akm: line 521: : command not found
[@EndeavourOS /]$ akm
[@EndeavourOS /]$ ==> Config file /etc/akm.conf read.
(yad:162): Gtk-WARNING **: 11:51:18.158: cannot open display: :0.0
pebcak
October 22, 2023, 12:16pm
6
akm is an application with graphic interface. You can’t run that in chroot.
Supposing your are correctly chrooted into your installed system, I would suggest to run a full update of your system:
pacman -Syu
and then (re-)install your kernels.
For LTS: pacman -S linux-lts linux-lts-headers
For Zen: pacman -S linux-zen linux-zen-headers
Pay attention to the output. If you get any error message post them here.
If not exit chroot and reboot your system.
tankas
October 22, 2023, 12:33pm
7
pebcak:
pacman -Syu
The suggested commands were executed successfully, but only under root, not using my user account.
After rebooting I still can see only one kernel and it fails to boot as per screenshots bellow.
I’m investigating if I did chroot correctly.
pebcak
October 22, 2023, 12:40pm
8
Alright. Chroot again and regenerate your grub.cfg:
If you need assistance for chrooting, from the live session, post the output of the following command and indicate which is your system/root partition:
sudo parted -l
tankas
October 22, 2023, 1:44pm
9
Worked like a charm. Thank you a mill pebcak
steps for solution:
arch-chroot
pacman -Syu
system
Closed
October 24, 2023, 1:44pm
10
