After update, system tries to boot to unknown UUID, fixed with dracut-rebuild
I have an annoying issue I am trying to figure out. When I update my system and reboot I get an error about trying to boot into a partition that is not on my system and it drops to the emergency shell. It only does it once in a while and only on two of my computers: both AMD laptops. The Intel desktop does not do this. All are running grub and dracut.
I have found a fix by booting into my backup install (Debian) and chrooting into the system then running dracut-rebuild. After rebooting all is back to normal. I don’t know what is causing the problem and it is starting to get annoying. I could just start running the dracut-rebuild command after each update but I want to know why this problem is happening first.
Is:
2 endeavouros/eos-dracut 1.2-1 [0B 3.36KiB] [Installed]
    Dracut scripts and hooks for EndeavourOS
Installed?
Yes. Same version. Reinstall?
Might be worth an uninstall / reinstall, that is the package that rebuilds after an update.
Roughly how often do you update?
Can you share the pacman log from the most recent update that caused this issue?
I update roughly once a week. The last update prior was on the 24th.
Sorry, I’m still learning the terminal commands for text files. How do I cut the log to just the update or do I need to upload the entire thing?
You can just open the log file in a text editor and copy paste the lines from the broken update.
Ok, it is somewhere in here:
[2023-10-30T14:53:41-0500] [PACKAGEKIT] synchronizing package lists
[2023-10-30T22:36:57-0500] [PACMAN] Running 'pacman -R -n -s --config /etc/pacman.conf -- auto-cpufreq'
[2023-10-30T22:37:02-0500] [ALPM] running '05-snap-pac-pre.hook'...
[2023-10-30T22:37:03-0500] [ALPM-SCRIPTLET] ==> root: 679
[2023-10-30T22:37:03-0500] [ALPM] transaction started
[2023-10-30T22:37:04-0500] [ALPM] removed auto-cpufreq (2.0.0-2)
[2023-10-30T22:37:04-0500] [ALPM-SCRIPTLET] rm: cannot remove '/usr/bin/cpufreqctl': No such file or directory
[2023-10-30T22:37:04-0500] [ALPM] removed python-setuptools (1:68.0.0-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-validate-pyproject (0.13-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-trove-classifiers (2023.10.17-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-fastjsonschema (2.18.1-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-tomli (2.0.1-3)
[2023-10-30T22:37:04-0500] [ALPM] removed python-platformdirs (3.11.0-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-ordered-set (4.1.0-4)
[2023-10-30T22:37:04-0500] [ALPM] removed python-jaraco.text (3.11.1-3)
[2023-10-30T22:37:04-0500] [ALPM] removed python-jaraco.functools (3.9.0-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-jaraco.context (4.3.0-3)
[2023-10-30T22:37:04-0500] [ALPM] removed python-inflect (7.0.0-2)
[2023-10-30T22:37:04-0500] [ALPM] removed python-pydantic (2.3.0-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-pydantic-core (1:2.6.3-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-annotated-types (0.5.0-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-autocommand (2.2.2-4)
[2023-10-30T22:37:04-0500] [ALPM] removed python-more-itertools (10.1.0-1)
[2023-10-30T22:37:04-0500] [ALPM] removed python-click (8.1.7-1)
[2023-10-30T22:37:05-0500] [ALPM] transaction completed
[2023-10-30T22:37:05-0500] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-10-30T22:37:07-0500] [ALPM] running '30-systemd-update.hook'...
[2023-10-30T22:37:07-0500] [ALPM] running '90-packagekit-refresh.hook'...
[2023-10-30T22:37:07-0500] [ALPM] running 'update-desktop-database.hook'...
[2023-10-30T22:37:07-0500] [ALPM] running 'zz-snap-pac-grub-post.hook'...
[2023-10-30T22:37:07-0500] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-10-30T22:37:08-0500] [ALPM-SCRIPTLET] Found background: /usr/share/endeavouros/splash.png
[2023-10-30T22:37:09-0500] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-linux-lts
[2023-10-30T22:37:09-0500] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-lts.img
[2023-10-30T22:37:09-0500] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-lts-fallback.img
[2023-10-30T22:37:09-0500] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux.img
[2023-10-30T22:37:10-0500] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-fallback.img
[2023-10-30T22:37:10-0500] [ALPM-SCRIPTLET] Warning: os-prober will not be executed to detect other bootable partitions.
[2023-10-30T22:37:10-0500] [ALPM-SCRIPTLET] Systems on them will not be added to the GRUB boot configuration.
[2023-10-30T22:37:10-0500] [ALPM-SCRIPTLET] Check GRUB_DISABLE_OS_PROBER documentation entry.
[2023-10-30T22:37:10-0500] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-10-30T22:37:10-0500] [ALPM-SCRIPTLET] Detecting snapshots ...
[2023-10-30T22:37:11-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-30 22:37:03 | @/.snapshots/679/snapshot | pre    | pacman -R -n -s --config /etc/pacman.conf -- auto-cpufreq                |
[2023-10-30T22:37:11-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-30 22:14:33 | @/.snapshots/678/snapshot | single | boot        |
[2023-10-30T22:37:11-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-30 14:29:01 | @/.snapshots/677/snapshot | single | boot        |
[2023-10-30T22:37:11-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:20:34 | @/.snapshots/676/snapshot | post   | cockpit-packagekit                                                       |
[2023-10-30T22:37:11-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:20:25 | @/.snapshots/675/snapshot | pre    | pacman -S --config /etc/pacman.conf -- extra/cockpit-packagekit          |
[2023-10-30T22:37:11-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:13:26 | @/.snapshots/674/snapshot | post   | podman-docker                                                            |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:13:13 | @/.snapshots/673/snapshot | pre    | pacman -S --config /etc/pacman.conf -- extra/podman-docker               |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:03:07 | @/.snapshots/672/snapshot | post   | libpackagekit-glib packagekit                                            |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:02:54 | @/.snapshots/671/snapshot | pre    | pacman -S --config /etc/pacman.conf -- extra/packagekit                  |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-23 23:23:26 | @/.snapshots/670/snapshot | post   | cockpit-file-sharing cockpit-navigator                                   |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-23 23:23:17 | @/.snapshots/669/snapshot | pre    | pacman -U --config /etc/pacman.conf -- /home/jeremiah/.cache/yay/cockpit |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-02 16:01:33 | @/.snapshots/625/snapshot | single | timeline        |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-09-27 10:32:34 | @/.snapshots/620/snapshot | single | timeline        |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-09-26 00:00:07 | @/.snapshots/615/snapshot | single | timeline        |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-09-25 12:31:47 | @/.snapshots/605/snapshot | single | timeline        |
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Found 15 snapshot(s)
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] Unmount /tmp/grub-btrfs.eIauckLkrs .. Success
[2023-10-30T22:37:12-0500] [ALPM-SCRIPTLET] done
[2023-10-30T22:37:12-0500] [ALPM] running 'zz-snap-pac-post.hook'...
[2023-10-30T22:37:13-0500] [ALPM-SCRIPTLET] ==> root: 680
[2023-10-30T22:40:58-0500] [PACKAGEKIT] synchronizing package lists
[2023-10-30T23:23:37-0500] [ALPM] running '05-snap-pac-pre.hook'...
[2023-10-30T23:23:37-0500] [ALPM-SCRIPTLET] ==> root: 682
[2023-10-30T23:23:37-0500] [ALPM] running '60-dracut-remove.hook'...
[2023-10-30T23:23:42-0500] [ALPM] running '60-mkinitcpio-remove.hook'...
[2023-10-30T23:23:42-0500] [ALPM] running '71-dkms-remove.hook'...
[2023-10-30T23:23:42-0500] [ALPM] running 'ghc-unregister.hook'...
[2023-10-30T23:23:43-0500] [ALPM] transaction started
[2023-10-30T23:23:43-0500] [ALPM] upgraded amd-ucode (20230804.7be2766d-2 -> 20230918.3672ccab-1)
[2023-10-30T23:23:43-0500] [PACKAGEKIT] upgraded amd-ucode (20230804.7be2766d-2 -> 20230918.3672ccab-1)
[2023-10-30T23:23:43-0500] [ALPM] upgraded iana-etc (20230907-1 -> 20231018-1)
[2023-10-30T23:23:43-0500] [PACKAGEKIT] upgraded iana-etc (20230907-1 -> 20231018-1)
[2023-10-30T23:23:43-0500] [ALPM] upgraded zlib (1:1.3-1 -> 1:1.3-2)
[2023-10-30T23:23:43-0500] [PACKAGEKIT] upgraded zlib (1:1.3-1 -> 1:1.3-2)
[2023-10-30T23:23:43-0500] [ALPM] upgraded bash (5.1.016-4 -> 5.2.015-5)
[2023-10-30T23:23:43-0500] [PACKAGEKIT] upgraded bash (5.1.016-4 -> 5.2.015-5)
[2023-10-30T23:23:44-0500] [ALPM] upgraded amdvlk (2023.Q3.3-1 -> 2023.Q4.1-1)
[2023-10-30T23:23:44-0500] [PACKAGEKIT] upgraded amdvlk (2023.Q3.3-1 -> 2023.Q4.1-1)
[2023-10-30T23:23:45-0500] [ALPM] upgraded openssl (3.1.3-1 -> 3.1.4-1)
[2023-10-30T23:23:45-0500] [PACKAGEKIT] upgraded openssl (3.1.3-1 -> 3.1.4-1)
[2023-10-30T23:23:45-0500] [ALPM] upgraded krb5 (1.20.1-1 -> 1.20.1-2)
[2023-10-30T23:23:45-0500] [PACKAGEKIT] upgraded krb5 (1.20.1-1 -> 1.20.1-2)
[2023-10-30T23:23:46-0500] [ALPM] upgraded libp11-kit (0.25.0-2 -> 0.25.1-1)
[2023-10-30T23:23:46-0500] [PACKAGEKIT] upgraded libp11-kit (0.25.0-2 -> 0.25.1-1)
[2023-10-30T23:23:46-0500] [ALPM] upgraded libsysprof-capture (45.0-1 -> 45.1-1)
[2023-10-30T23:23:46-0500] [PACKAGEKIT] upgraded libsysprof-capture (45.0-1 -> 45.1-1)
[2023-10-30T23:23:46-0500] [ALPM] upgraded glib2 (2.78.0-3 -> 2.78.1-1)
[2023-10-30T23:23:46-0500] [PACKAGEKIT] upgraded glib2 (2.78.0-3 -> 2.78.1-1)
[2023-10-30T23:23:46-0500] [ALPM] upgraded libnghttp2 (1.57.0-1 -> 1.58.0-1)
[2023-10-30T23:23:46-0500] [PACKAGEKIT] upgraded libnghttp2 (1.57.0-1 -> 1.58.0-1)
[2023-10-30T23:23:46-0500] [ALPM] upgraded p11-kit (0.25.0-2 -> 0.25.1-1)
[2023-10-30T23:23:46-0500] [PACKAGEKIT] upgraded p11-kit (0.25.0-2 -> 0.25.1-1)
[2023-10-30T23:23:46-0500] [ALPM] upgraded gpgme (1.22.0-1 -> 1.23.1-1)
[2023-10-30T23:23:46-0500] [PACKAGEKIT] upgraded gpgme (1.22.0-1 -> 1.23.1-1)
[2023-10-30T23:23:46-0500] [ALPM] upgraded archlinux-keyring (20231017-1 -> 20231026-1)
[2023-10-30T23:23:50-0500] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2023-10-30T23:24:02-0500] [ALPM-SCRIPTLET] ==> Updating trust database...
[2023-10-30T23:24:02-0500] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2023-12-07
[2023-10-30T23:24:02-0500] [PACKAGEKIT] upgraded archlinux-keyring (20231017-1 -> 20231026-1)
[2023-10-30T23:24:02-0500] [ALPM] upgraded libjpeg-turbo (3.0.0-1 -> 3.0.1-1)
[2023-10-30T23:24:02-0500] [PACKAGEKIT] upgraded libjpeg-turbo (3.0.0-1 -> 3.0.1-1)
[2023-10-30T23:24:02-0500] [ALPM] upgraded vulkan-icd-loader (1.3.263-1 -> 1.3.269-1)
[2023-10-30T23:24:02-0500] [PACKAGEKIT] upgraded vulkan-icd-loader (1.3.263-1 -> 1.3.269-1)
[2023-10-30T23:24:02-0500] [ALPM] upgraded libunwind (1.6.2-2 -> 1.7.2-1)
[2023-10-30T23:24:02-0500] [PACKAGEKIT] upgraded libunwind (1.6.2-2 -> 1.7.2-1)
[2023-10-30T23:24:02-0500] [ALPM] upgraded shadow (4.14.0-4 -> 4.14.2-1)
[2023-10-30T23:24:02-0500] [PACKAGEKIT] upgraded shadow (4.14.0-4 -> 4.14.2-1)
[2023-10-30T23:24:02-0500] [ALPM] upgraded nftables (1:1.0.8-2 -> 1:1.0.9-1)
[2023-10-30T23:24:02-0500] [PACKAGEKIT] upgraded nftables (1:1.0.8-2 -> 1:1.0.9-1)
[2023-10-30T23:24:03-0500] [ALPM] upgraded qt5-declarative (5.15.11+kde+r30-1 -> 5.15.11+kde+r31-1)
[2023-10-30T23:24:03-0500] [PACKAGEKIT] upgraded qt5-declarative (5.15.11+kde+r30-1 -> 5.15.11+kde+r31-1)
[2023-10-30T23:24:03-0500] [ALPM] upgraded qt5-wayland (5.15.11+kde+r59-1 -> 5.15.11+kde+r60-1)
[2023-10-30T23:24:03-0500] [PACKAGEKIT] upgraded qt5-wayland (5.15.11+kde+r59-1 -> 5.15.11+kde+r60-1)
[2023-10-30T23:24:04-0500] [ALPM] upgraded btrfs-progs (6.5.2-2 -> 6.5.3-2)
[2023-10-30T23:24:04-0500] [PACKAGEKIT] upgraded btrfs-progs (6.5.2-2 -> 6.5.3-2)
[2023-10-30T23:24:04-0500] [ALPM] upgraded bluedevil (1:5.27.8-2 -> 1:5.27.9-1)
[2023-10-30T23:24:04-0500] [PACKAGEKIT] upgraded bluedevil (1:5.27.8-2 -> 1:5.27.9-1)
[2023-10-30T23:24:04-0500] [ALPM] upgraded kdecoration (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:04-0500] [PACKAGEKIT] upgraded kdecoration (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded breeze (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded breeze (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded breeze-gtk (5.27.8-1 -> 5.27.9-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded breeze-gtk (5.27.8-1 -> 5.27.9-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded c-ares (1.20.1-1 -> 1.21.0-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded c-ares (1.20.1-1 -> 1.21.0-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded libnsl (2.0.0-3 -> 2.0.1-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded libnsl (2.0.0-3 -> 2.0.1-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded crun (1.10-1 -> 1.11.1-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded crun (1.10-1 -> 1.11.1-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded ddcutil (1.4.1-1 -> 2.0.0-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded ddcutil (1.4.1-1 -> 2.0.0-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded debootstrap (1.0.132-1 -> 1.0.133-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded debootstrap (1.0.132-1 -> 1.0.133-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded minizip (1:1.3-1 -> 1:1.3-2)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded minizip (1:1.3-1 -> 1:1.3-2)
[2023-10-30T23:24:05-0500] [ALPM] upgraded snappy (1.1.9-2 -> 1.1.10-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded snappy (1.1.9-2 -> 1.1.10-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded serd (0.30.16-1 -> 0.32.0-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded serd (0.30.16-1 -> 0.32.0-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded discover (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded discover (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded ethtool (1:6.4-1 -> 1:6.5-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded ethtool (1:6.4-1 -> 1:6.5-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded exfatprogs (1.2.1-1 -> 1.2.2-1)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded exfatprogs (1.2.1-1 -> 1.2.2-1)
[2023-10-30T23:24:05-0500] [ALPM] upgraded gtk-update-icon-cache (1:4.12.3-1 -> 1:4.12.3-2)
[2023-10-30T23:24:05-0500] [PACKAGEKIT] upgraded gtk-update-icon-cache (1:4.12.3-1 -> 1:4.12.3-2)
[2023-10-30T23:24:06-0500] [ALPM] upgraded libsoup3 (3.4.3-1 -> 3.4.4-1)
[2023-10-30T23:24:06-0500] [PACKAGEKIT] upgraded libsoup3 (3.4.3-1 -> 3.4.4-1)
[2023-10-30T23:24:08-0500] [ALPM] upgraded firefox (118.0.2-1 -> 119.0-1)
[2023-10-30T23:24:08-0500] [PACKAGEKIT] upgraded firefox (118.0.2-1 -> 119.0-1)
[2023-10-30T23:24:11-0500] [ALPM] upgraded firefox-developer-edition (119.0b9-1 -> 120.0b4-1)
[2023-10-30T23:24:11-0500] [PACKAGEKIT] upgraded firefox-developer-edition (119.0b9-1 -> 120.0b4-1)
[2023-10-30T23:24:11-0500] [ALPM] upgraded fzf (0.42.0-1 -> 0.43.0-1)
[2023-10-30T23:24:11-0500] [PACKAGEKIT] upgraded fzf (0.42.0-1 -> 0.43.0-1)
[2023-10-30T23:24:12-0500] [ALPM] upgraded glib2-docs (2.78.0-3 -> 2.78.1-1)
[2023-10-30T23:24:12-0500] [PACKAGEKIT] upgraded glib2-docs (2.78.0-3 -> 2.78.1-1)
[2023-10-30T23:24:12-0500] [ALPM] upgraded gssproxy (0.9.1-2 -> 0.9.2-1)
[2023-10-30T23:24:12-0500] [PACKAGEKIT] upgraded gssproxy (0.9.1-2 -> 0.9.2-1)
[2023-10-30T23:24:12-0500] [ALPM] upgraded gtk4 (1:4.12.3-1 -> 1:4.12.3-2)
[2023-10-30T23:24:12-0500] [PACKAGEKIT] upgraded gtk4 (1:4.12.3-1 -> 1:4.12.3-2)
[2023-10-30T23:24:12-0500] [ALPM] upgraded haskell-bitvec (1.1.3.0-61 -> 1.1.3.0-62)
[2023-10-30T23:24:12-0500] [PACKAGEKIT] upgraded haskell-bitvec (1.1.3.0-61 -> 1.1.3.0-62)
[2023-10-30T23:24:12-0500] [ALPM] upgraded haskell-unordered-containers (0.2.19.1-75 -> 0.2.19.1-76)
[2023-10-30T23:24:12-0500] [PACKAGEKIT] upgraded haskell-unordered-containers (0.2.19.1-75 -> 0.2.19.1-76)
[2023-10-30T23:24:12-0500] [ALPM] upgraded haskell-vector-algorithms (0.9.0.1-61 -> 0.9.0.1-62)
[2023-10-30T23:24:12-0500] [PACKAGEKIT] upgraded haskell-vector-algorithms (0.9.0.1-61 -> 0.9.0.1-62)
[2023-10-30T23:24:12-0500] [ALPM] upgraded haskell-mono-traversable (1.0.15.3-139 -> 1.0.15.3-140)
[2023-10-30T23:24:12-0500] [PACKAGEKIT] upgraded haskell-mono-traversable (1.0.15.3-139 -> 1.0.15.3-140)
[2023-10-30T23:24:12-0500] [ALPM] upgraded haskell-conduit (1.3.5-14 -> 1.3.5-15)
[2023-10-30T23:24:12-0500] [PACKAGEKIT] upgraded haskell-conduit (1.3.5-14 -> 1.3.5-15)
[2023-10-30T23:24:12-0500] [ALPM] upgraded haskell-regex-tdfa (1.3.2.2-11 -> 1.3.2.2-12)
[2023-10-30T23:24:12-0500] [PACKAGEKIT] upgraded haskell-regex-tdfa (1.3.2.2-11 -> 1.3.2.2-12)
[2023-10-30T23:24:13-0500] [ALPM] upgraded haskell-sandi (0.5-403 -> 0.5-404)
[2023-10-30T23:24:13-0500] [PACKAGEKIT] upgraded haskell-sandi (0.5-403 -> 0.5-404)
[2023-10-30T23:24:13-0500] [ALPM] upgraded libyuv (r2322+3aebf69d-1 -> r2426+464c51a0-1)
[2023-10-30T23:24:13-0500] [PACKAGEKIT] upgraded libyuv (r2322+3aebf69d-1 -> r2426+464c51a0-1)
[2023-10-30T23:24:13-0500] [ALPM] upgraded libavif (1.0.1-3 -> 1.0.1-4)
[2023-10-30T23:24:13-0500] [PACKAGEKIT] upgraded libavif (1.0.1-3 -> 1.0.1-4)
[2023-10-30T23:24:15-0500] [ALPM] upgraded hedgewars (1.0.2-47 -> 1.0.2-48)
[2023-10-30T23:24:15-0500] [PACKAGEKIT] upgraded hedgewars (1.0.2-47 -> 1.0.2-48)
[2023-10-30T23:24:16-0500] [ALPM] upgraded kactivitymanagerd (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [PACKAGEKIT] upgraded kactivitymanagerd (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [ALPM] upgraded kde-cli-tools (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [PACKAGEKIT] upgraded kde-cli-tools (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [ALPM] upgraded kde-gtk-config (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [PACKAGEKIT] upgraded kde-gtk-config (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [ALPM] upgraded libksysguard (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [PACKAGEKIT] upgraded libksysguard (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [ALPM] upgraded ksystemstats (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [PACKAGEKIT] upgraded ksystemstats (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [ALPM] upgraded milou (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [PACKAGEKIT] upgraded milou (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [ALPM] upgraded layer-shell-qt (5.27.8-1 -> 5.27.9-1)
[2023-10-30T23:24:16-0500] [PACKAGEKIT] upgraded layer-shell-qt (5.27.8-1 -> 5.27.9-1)
[2023-10-30T23:24:17-0500] [ALPM] upgraded libkscreen (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:17-0500] [PACKAGEKIT] upgraded libkscreen (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:17-0500] [ALPM] upgraded kscreenlocker (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:17-0500] [PACKAGEKIT] upgraded kscreenlocker (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:18-0500] [ALPM] upgraded kwin (5.27.8-4 -> 5.27.9-1)
[2023-10-30T23:24:18-0500] [PACKAGEKIT] upgraded kwin (5.27.8-4 -> 5.27.9-1)
[2023-10-30T23:24:18-0500] [ALPM] upgraded plasma-integration (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:18-0500] [PACKAGEKIT] upgraded plasma-integration (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:18-0500] [ALPM] upgraded kpipewire (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:18-0500] [PACKAGEKIT] upgraded kpipewire (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:18-0500] [ALPM] upgraded oxygen-sounds (5.27.8-1 -> 5.27.9-1)
[2023-10-30T23:24:18-0500] [PACKAGEKIT] upgraded oxygen-sounds (5.27.8-1 -> 5.27.9-1)
[2023-10-30T23:24:20-0500] [ALPM] upgraded plasma-workspace (5.27.8-2 -> 5.27.9.1-1)
[2023-10-30T23:24:20-0500] [PACKAGEKIT] upgraded plasma-workspace (5.27.8-2 -> 5.27.9.1-1)
[2023-10-30T23:24:22-0500] [ALPM] upgraded kdeplasma-addons (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:22-0500] [PACKAGEKIT] upgraded kdeplasma-addons (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:22-0500] [ALPM] upgraded khotkeys (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:22-0500] [PACKAGEKIT] upgraded khotkeys (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:22-0500] [ALPM] upgraded systemsettings (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:22-0500] [PACKAGEKIT] upgraded systemsettings (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:22-0500] [ALPM] upgraded vulkan-tools (1.3.263-1 -> 1.3.269-1)
[2023-10-30T23:24:22-0500] [PACKAGEKIT] upgraded vulkan-tools (1.3.263-1 -> 1.3.269-1)
[2023-10-30T23:24:23-0500] [ALPM] upgraded kinfocenter (5.27.8-3 -> 5.27.9-1)
[2023-10-30T23:24:23-0500] [PACKAGEKIT] upgraded kinfocenter (5.27.8-3 -> 5.27.9-1)
[2023-10-30T23:24:23-0500] [ALPM] upgraded kmenuedit (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:23-0500] [PACKAGEKIT] upgraded kmenuedit (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:23-0500] [ALPM] upgraded kscreen (5.27.8-3 -> 5.27.9-1)
[2023-10-30T23:24:23-0500] [PACKAGEKIT] upgraded kscreen (5.27.8-3 -> 5.27.9-1)
[2023-10-30T23:24:23-0500] [ALPM] upgraded kwallet-pam (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:23-0500] [PACKAGEKIT] upgraded kwallet-pam (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:23-0500] [ALPM] upgraded kwayland-integration (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:23-0500] [PACKAGEKIT] upgraded kwayland-integration (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:24-0500] [ALPM] upgraded lib32-amdvlk (2023.Q3.3-1 -> 2023.Q4.1-1)
[2023-10-30T23:24:24-0500] [PACKAGEKIT] upgraded lib32-amdvlk (2023.Q3.3-1 -> 2023.Q4.1-1)
[2023-10-30T23:24:24-0500] [ALPM] upgraded lib32-brotli (1.0.9-12 -> 1.1.0-1)
[2023-10-30T23:24:24-0500] [PACKAGEKIT] upgraded lib32-brotli (1.0.9-12 -> 1.1.0-1)
[2023-10-30T23:24:24-0500] [ALPM] upgraded lib32-glib2 (2.78.0-2 -> 2.78.1-1)
[2023-10-30T23:24:24-0500] [PACKAGEKIT] upgraded lib32-glib2 (2.78.0-2 -> 2.78.1-1)
[2023-10-30T23:24:24-0500] [ALPM] upgraded lib32-libdrm (2.4.116-1 -> 2.4.117-1)
[2023-10-30T23:24:24-0500] [PACKAGEKIT] upgraded lib32-libdrm (2.4.116-1 -> 2.4.117-1)
[2023-10-30T23:24:24-0500] [ALPM] upgraded lib32-libunwind (1.6.2-2 -> 1.7.2-1)
[2023-10-30T23:24:24-0500] [PACKAGEKIT] upgraded lib32-libunwind (1.6.2-2 -> 1.7.2-1)
[2023-10-30T23:24:24-0500] [ALPM] upgraded lib32-openssl (1:3.1.3-1 -> 1:3.1.4-1)
[2023-10-30T23:24:24-0500] [PACKAGEKIT] upgraded lib32-openssl (1:3.1.3-1 -> 1:3.1.4-1)
[2023-10-30T23:24:24-0500] [ALPM] upgraded lib32-p11-kit (0.25.0-2 -> 0.25.1-1)
[2023-10-30T23:24:24-0500] [PACKAGEKIT] upgraded lib32-p11-kit (0.25.0-2 -> 0.25.1-1)
[2023-10-30T23:24:24-0500] [ALPM] upgraded lib32-vulkan-icd-loader (1.3.263-1 -> 1.3.269-1)
[2023-10-30T23:24:24-0500] [PACKAGEKIT] upgraded lib32-vulkan-icd-loader (1.3.263-1 -> 1.3.269-1)
[2023-10-30T23:24:26-0500] [ALPM] upgraded linux (6.5.8.arch1-1 -> 6.5.9.arch2-1)
[2023-10-30T23:24:26-0500] [PACKAGEKIT] upgraded linux (6.5.8.arch1-1 -> 6.5.9.arch2-1)
[2023-10-30T23:24:26-0500] [ALPM] upgraded linux-firmware-whence (20230804.7be2766d-2 -> 20230918.3672ccab-1)
[2023-10-30T23:24:26-0500] [PACKAGEKIT] upgraded linux-firmware-whence (20230804.7be2766d-2 -> 20230918.3672ccab-1)
[2023-10-30T23:24:28-0500] [ALPM] upgraded linux-firmware (20230804.7be2766d-2 -> 20230918.3672ccab-1)
[2023-10-30T23:24:28-0500] [PACKAGEKIT] upgraded linux-firmware (20230804.7be2766d-2 -> 20230918.3672ccab-1)
[2023-10-30T23:24:34-0500] [ALPM] upgraded linux-headers (6.5.8.arch1-1 -> 6.5.9.arch2-1)
[2023-10-30T23:24:34-0500] [PACKAGEKIT] upgraded linux-headers (6.5.8.arch1-1 -> 6.5.9.arch2-1)
[2023-10-30T23:24:36-0500] [ALPM] upgraded linux-lts (6.1.59-1 -> 6.1.60-1)
[2023-10-30T23:24:36-0500] [PACKAGEKIT] upgraded linux-lts (6.1.59-1 -> 6.1.60-1)
[2023-10-30T23:24:41-0500] [ALPM] upgraded linux-lts-headers (6.1.59-1 -> 6.1.60-1)
[2023-10-30T23:24:41-0500] [PACKAGEKIT] upgraded linux-lts-headers (6.1.59-1 -> 6.1.60-1)
[2023-10-30T23:24:41-0500] [ALPM] upgraded p7zip (1:17.05-1 -> 1:17.05-2)
[2023-10-30T23:24:41-0500] [PACKAGEKIT] upgraded p7zip (1:17.05-1 -> 1:17.05-2)
[2023-10-30T23:24:42-0500] [ALPM] upgraded python-charset-normalizer (3.3.0-1 -> 3.3.1-1)
[2023-10-30T23:24:42-0500] [PACKAGEKIT] upgraded python-charset-normalizer (3.3.0-1 -> 3.3.1-1)
[2023-10-30T23:24:42-0500] [ALPM] upgraded python-moddb (0.9.0-1 -> 0.10.0-1)
[2023-10-30T23:24:42-0500] [PACKAGEKIT] upgraded python-moddb (0.9.0-1 -> 0.10.0-1)
[2023-10-30T23:24:42-0500] [ALPM] upgraded lutris (0.5.13-6 -> 0.5.14-1)
[2023-10-30T23:24:42-0500] [PACKAGEKIT] upgraded lutris (0.5.13-6 -> 0.5.14-1)
[2023-10-30T23:24:44-0500] [ALPM] upgraded man-pages (6.05.01-1 -> 6.05.01-2)
[2023-10-30T23:24:44-0500] [PACKAGEKIT] upgraded man-pages (6.05.01-1 -> 6.05.01-2)
[2023-10-30T23:24:44-0500] [ALPM] upgraded minizip-ng (4.0.1-1 -> 4.0.2-1)
[2023-10-30T23:24:44-0500] [PACKAGEKIT] upgraded minizip-ng (4.0.1-1 -> 4.0.2-1)
[2023-10-30T23:24:44-0500] [ALPM] upgraded nextcloud-client (2:3.10.0-2 -> 2:3.10.1-1)
[2023-10-30T23:24:44-0500] [PACKAGEKIT] upgraded nextcloud-client (2:3.10.0-2 -> 2:3.10.1-1)
[2023-10-30T23:24:44-0500] [ALPM] upgraded ostree (2023.6-4 -> 2023.7-1)
[2023-10-30T23:24:44-0500] [PACKAGEKIT] upgraded ostree (2023.6-4 -> 2023.7-1)
[2023-10-30T23:24:44-0500] [ALPM] upgraded parallel (20230922-1 -> 20231022-1)
[2023-10-30T23:24:44-0500] [PACKAGEKIT] upgraded parallel (20230922-1 -> 20231022-1)
[2023-10-30T23:24:44-0500] [ALPM] upgraded passim (0.1.3-2 -> 0.1.4-1)
[2023-10-30T23:24:44-0500] [PACKAGEKIT] upgraded passim (0.1.3-2 -> 0.1.4-1)
[2023-10-30T23:24:44-0500] [ALPM] upgraded polkit-kde-agent (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:44-0500] [PACKAGEKIT] upgraded polkit-kde-agent (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:44-0500] [ALPM] upgraded powerdevil (5.27.8-2 -> 5.27.9-2)
[2023-10-30T23:24:44-0500] [PACKAGEKIT] upgraded powerdevil (5.27.8-2 -> 5.27.9-2)
[2023-10-30T23:24:46-0500] [ALPM] upgraded plasma-desktop (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:46-0500] [PACKAGEKIT] upgraded plasma-desktop (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:46-0500] [ALPM] upgraded plasma-disks (5.27.8-1 -> 5.27.9-1)
[2023-10-30T23:24:46-0500] [PACKAGEKIT] upgraded plasma-disks (5.27.8-1 -> 5.27.9-1)
[2023-10-30T23:24:46-0500] [ALPM] upgraded plasma-nm (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:46-0500] [PACKAGEKIT] upgraded plasma-nm (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:46-0500] [ALPM] upgraded plasma-pa (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:46-0500] [PACKAGEKIT] upgraded plasma-pa (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:47-0500] [ALPM] upgraded plasma-systemmonitor (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:47-0500] [PACKAGEKIT] upgraded plasma-systemmonitor (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:47-0500] [ALPM] upgraded xorg-server-common (21.1.8-2 -> 21.1.9-1)
[2023-10-30T23:24:47-0500] [PACKAGEKIT] upgraded xorg-server-common (21.1.8-2 -> 21.1.9-1)
[2023-10-30T23:24:47-0500] [ALPM] upgraded xorg-xwayland (23.2.1-1 -> 23.2.2-1)
[2023-10-30T23:24:47-0500] [PACKAGEKIT] upgraded xorg-xwayland (23.2.1-1 -> 23.2.2-1)
[2023-10-30T23:24:47-0500] [ALPM] upgraded plasma-wayland-session (5.27.8-2 -> 5.27.9.1-1)
[2023-10-30T23:24:47-0500] [PACKAGEKIT] upgraded plasma-wayland-session (5.27.8-2 -> 5.27.9.1-1)
[2023-10-30T23:24:47-0500] [ALPM] upgraded podofo (0.10.1-1 -> 0.10.2-1)
[2023-10-30T23:24:47-0500] [PACKAGEKIT] upgraded podofo (0.10.1-1 -> 0.10.2-1)
[2023-10-30T23:24:47-0500] [ALPM] upgraded python-anytree (2.11.1-1 -> 2.12.0-2)
[2023-10-30T23:24:47-0500] [PACKAGEKIT] upgraded python-anytree (2.11.1-1 -> 2.12.0-2)
[2023-10-30T23:24:47-0500] [ALPM] upgraded python-cryptography (41.0.4-1 -> 41.0.5-1)
[2023-10-30T23:24:47-0500] [PACKAGEKIT] upgraded python-cryptography (41.0.4-1 -> 41.0.5-1)
[2023-10-30T23:24:47-0500] [ALPM] upgraded xorg-server (21.1.8-2 -> 21.1.9-1)
[2023-10-30T23:24:47-0500] [PACKAGEKIT] upgraded xorg-server (21.1.8-2 -> 21.1.9-1)
[2023-10-30T23:24:47-0500] [ALPM] upgraded sddm-kcm (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:47-0500] [PACKAGEKIT] upgraded sddm-kcm (5.27.8-2 -> 5.27.9-1)
[2023-10-30T23:24:48-0500] [ALPM] upgraded suitesparse (7.2.2-1 -> 7.3.0-1)
[2023-10-30T23:24:48-0500] [PACKAGEKIT] upgraded suitesparse (7.2.2-1 -> 7.3.0-1)
[2023-10-30T23:24:49-0500] [ALPM] upgraded tailscale (1.50.1-1 -> 1.52.0-1)
[2023-10-30T23:24:49-0500] [PACKAGEKIT] upgraded tailscale (1.50.1-1 -> 1.52.0-1)
[2023-10-30T23:24:49-0500] [ALPM] upgraded texinfo (7.0.3-1 -> 7.1-1)
[2023-10-30T23:24:49-0500] [PACKAGEKIT] upgraded texinfo (7.0.3-1 -> 7.1-1)
[2023-10-30T23:24:51-0500] [ALPM] upgraded thunderbird (115.3.3-1 -> 115.4.1-1)
[2023-10-30T23:24:51-0500] [PACKAGEKIT] upgraded thunderbird (115.3.3-1 -> 115.4.1-1)
[2023-10-30T23:24:51-0500] [ALPM] upgraded usbutils (015-3 -> 016-2)
[2023-10-30T23:24:51-0500] [PACKAGEKIT] upgraded usbutils (015-3 -> 016-2)
[2023-10-30T23:24:53-0500] [ALPM] upgraded vim-runtime (9.0.2010-1 -> 9.0.2070-1)
[2023-10-30T23:24:53-0500] [PACKAGEKIT] upgraded vim-runtime (9.0.2010-1 -> 9.0.2070-1)
[2023-10-30T23:24:53-0500] [ALPM] upgraded vim (9.0.2010-1 -> 9.0.2070-1)
[2023-10-30T23:24:53-0500] [PACKAGEKIT] upgraded vim (9.0.2010-1 -> 9.0.2070-1)
[2023-10-30T23:24:53-0500] [ALPM] upgraded vulkan-headers (1:1.3.264-2 -> 1:1.3.269-1)
[2023-10-30T23:24:53-0500] [PACKAGEKIT] upgraded vulkan-headers (1:1.3.264-2 -> 1:1.3.269-1)
[2023-10-30T23:24:55-0500] [ALPM] transaction completed
[2023-10-30T23:24:57-0500] [ALPM] running '20-systemd-sysusers.hook'...
[2023-10-30T23:24:57-0500] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-10-30T23:24:59-0500] [ALPM] running '30-systemd-tmpfiles.hook'...
[2023-10-30T23:24:59-0500] [ALPM] running '30-systemd-udev-reload.hook'...
[2023-10-30T23:25:03-0500] [ALPM] running '30-systemd-update.hook'...
[2023-10-30T23:25:03-0500] [ALPM] running '30-update-mime-database.hook'...
[2023-10-30T23:25:04-0500] [ALPM] running '60-depmod.hook'...
[2023-10-30T23:25:17-0500] [ALPM] running '70-dkms-install.hook'...
[2023-10-30T23:25:17-0500] [ALPM] running '90-dracut-install.hook'...
[2023-10-30T23:25:18-0500] [ALPM-SCRIPTLET] :: Building initramfs for linux-lts (6.1.60-1-lts)
[2023-10-30T23:25:18-0500] [ALPM-SCRIPTLET] dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /usr/lib/modules/6.1.60-1-lts/initrd 6.1.60-1-lts
[2023-10-30T23:25:20-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
[2023-10-30T23:25:20-0500] [ALPM-SCRIPTLET] dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
[2023-10-30T23:25:21-0500] [ALPM-SCRIPTLET] dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: memstrack is not available
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
[2023-10-30T23:25:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
[2023-10-30T23:25:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: systemd ***
[2023-10-30T23:25:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: systemd-initrd ***
[2023-10-30T23:25:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: i18n ***
[2023-10-30T23:25:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: btrfs ***
[2023-10-30T23:25:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: crypt ***
[2023-10-30T23:25:24-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dm ***
[2023-10-30T23:25:24-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 64-device-mapper.rules
[2023-10-30T23:25:24-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 60-persistent-storage-dm.rules
[2023-10-30T23:25:24-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 55-dm.rules
[2023-10-30T23:25:24-0500] [ALPM-SCRIPTLET] dracut: *** Including module: kernel-modules ***
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: *** Including module: kernel-modules-extra ***
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: *** Including module: btrfs-snapshot-overlay ***
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: *** Including module: rootfs-block ***
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: *** Including module: terminfo ***
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: *** Including module: udev-rules ***
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 40-redhat.rules
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 50-firmware.rules
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 50-udev.rules
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 91-permissions.rules
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 80-drivers-modprobe.rules
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 70-persistent-net.rules
[2023-10-30T23:25:26-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dracut-systemd ***
[2023-10-30T23:25:27-0500] [ALPM-SCRIPTLET] dracut: *** Including module: usrmount ***
[2023-10-30T23:25:27-0500] [ALPM-SCRIPTLET] dracut: *** Including module: base ***
[2023-10-30T23:25:27-0500] [ALPM-SCRIPTLET] dracut: *** Including module: fs-lib ***
[2023-10-30T23:25:27-0500] [ALPM-SCRIPTLET] dracut: *** Including module: shutdown ***
[2023-10-30T23:25:27-0500] [ALPM-SCRIPTLET] dracut: *** Including modules done ***
[2023-10-30T23:25:27-0500] [ALPM-SCRIPTLET] dracut: *** Installing kernel module dependencies ***
[2023-10-30T23:25:27-0500] [ALPM-SCRIPTLET] dracut: *** Installing kernel module dependencies done ***
[2023-10-30T23:25:27-0500] [ALPM-SCRIPTLET] dracut: *** Resolving executable dependencies ***
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: *** Resolving executable dependencies done ***
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: *** Hardlinking files ***
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: Mode:                     real
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: Method:                   sha256
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: Files:                    827
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: Linked:                   2 files
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: Compared:                 0 xattrs
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: Compared:                 38 files
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: Saved:                    822 B
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: Duration:                 0.013616 seconds
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: *** Hardlinking files done ***
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: *** Generating early-microcode cpio image ***
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: *** Constructing AuthenticAMD.bin ***
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: *** Store current command line parameters ***
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: *** Stripping files ***
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: *** Stripping files done ***
[2023-10-30T23:25:29-0500] [ALPM-SCRIPTLET] dracut: *** Creating image file '/usr/lib/modules/6.1.60-1-lts/initrd' ***
[2023-10-30T23:25:36-0500] [ALPM-SCRIPTLET] dracut: *** Creating initramfs image file '/usr/lib/modules/6.1.60-1-lts/initrd' done ***
[2023-10-30T23:25:36-0500] [ALPM-SCRIPTLET] :: Building fallback initramfs for linux-lts (6.1.60-1-lts)
[2023-10-30T23:25:36-0500] [ALPM-SCRIPTLET] dracut: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-lts-fallback.img 6.1.60-1-lts
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'nbd' will not be installed, because command 'nbd-client' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: memstrack is not available
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
[2023-10-30T23:25:38-0500] [ALPM-SCRIPTLET] dracut: *** Including module: systemd ***
[2023-10-30T23:25:39-0500] [ALPM-SCRIPTLET] dracut: *** Including module: systemd-initrd ***
[2023-10-30T23:25:39-0500] [ALPM-SCRIPTLET] dracut: *** Including module: modsign ***
[2023-10-30T23:25:39-0500] [ALPM-SCRIPTLET] dracut: *** Including module: i18n ***
[2023-10-30T23:25:39-0500] [ALPM-SCRIPTLET] dracut: *** Including module: btrfs ***
[2023-10-30T23:25:39-0500] [ALPM-SCRIPTLET] dracut: *** Including module: crypt ***
[2023-10-30T23:25:39-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dm ***
[2023-10-30T23:25:39-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 64-device-mapper.rules
[2023-10-30T23:25:39-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 60-persistent-storage-dm.rules
[2023-10-30T23:25:39-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 55-dm.rules
[2023-10-30T23:25:40-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dmraid ***
[2023-10-30T23:25:40-0500] [ALPM-SCRIPTLET] dracut: *** Including module: kernel-modules ***
[2023-10-30T23:25:43-0500] [ALPM-SCRIPTLET] dracut: *** Including module: kernel-modules-extra ***
[2023-10-30T23:25:43-0500] [ALPM-SCRIPTLET] dracut: *** Including module: lvm ***
[2023-10-30T23:25:43-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 64-device-mapper.rules
[2023-10-30T23:25:43-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 56-lvm.rules
[2023-10-30T23:25:43-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
[2023-10-30T23:25:43-0500] [ALPM-SCRIPTLET] dracut: *** Including module: mdraid ***
[2023-10-30T23:25:43-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 64-md-raid.rules
[2023-10-30T23:25:44-0500] [ALPM-SCRIPTLET] dracut: *** Including module: multipath ***
[2023-10-30T23:25:44-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 40-multipath.rules
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: *** Including module: nvdimm ***
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: *** Including module: qemu ***
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: *** Including module: qemu-net ***
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: *** Including module: btrfs-snapshot-overlay ***
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: *** Including module: lunmask ***
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: *** Including module: resume ***
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: *** Including module: rootfs-block ***
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: *** Including module: terminfo ***
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: *** Including module: udev-rules ***
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 40-redhat.rules
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 50-firmware.rules
[2023-10-30T23:25:45-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 50-udev.rules
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 91-permissions.rules
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 80-drivers-modprobe.rules
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: *** Including module: virtiofs ***
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dracut-systemd ***
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: *** Including module: usrmount ***
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: *** Including module: base ***
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: *** Including module: fs-lib ***
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: *** Including module: shutdown ***
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: *** Including modules done ***
[2023-10-30T23:25:46-0500] [ALPM-SCRIPTLET] dracut: *** Installing kernel module dependencies ***
[2023-10-30T23:25:47-0500] [ALPM-SCRIPTLET] dracut: *** Installing kernel module dependencies done ***
[2023-10-30T23:25:47-0500] [ALPM-SCRIPTLET] dracut: *** Resolving executable dependencies ***
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: *** Resolving executable dependencies done ***
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: *** Hardlinking files ***
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: Mode:                     real
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: Method:                   sha256
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: Files:                    2065
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: Linked:                   9 files
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: Compared:                 0 xattrs
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: Compared:                 478 files
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: Saved:                    1.42 MiB
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: Duration:                 0.069601 seconds
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: *** Hardlinking files done ***
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: *** Generating early-microcode cpio image ***
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: *** Constructing AuthenticAMD.bin ***
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: *** Store current command line parameters ***
[2023-10-30T23:25:50-0500] [ALPM-SCRIPTLET] dracut: *** Stripping files ***
[2023-10-30T23:25:51-0500] [ALPM-SCRIPTLET] dracut: *** Stripping files done ***
[2023-10-30T23:25:51-0500] [ALPM-SCRIPTLET] dracut: *** Creating image file '/boot/initramfs-linux-lts-fallback.img' ***
[2023-10-30T23:26:00-0500] [ALPM-SCRIPTLET] dracut: *** Creating initramfs image file '/boot/initramfs-linux-lts-fallback.img' done ***
[2023-10-30T23:26:02-0500] [ALPM-SCRIPTLET] :: Building initramfs for linux (6.5.9-arch2-1)
[2023-10-30T23:26:02-0500] [ALPM-SCRIPTLET] dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /usr/lib/modules/6.5.9-arch2-1/initrd 6.5.9-arch2-1
[2023-10-30T23:26:04-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
[2023-10-30T23:26:04-0500] [ALPM-SCRIPTLET] dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
[2023-10-30T23:26:05-0500] [ALPM-SCRIPTLET] dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: memstrack is not available
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
[2023-10-30T23:26:06-0500] [ALPM-SCRIPTLET] dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
[2023-10-30T23:26:07-0500] [ALPM-SCRIPTLET] dracut: *** Including module: systemd ***
[2023-10-30T23:26:07-0500] [ALPM-SCRIPTLET] dracut: *** Including module: systemd-initrd ***
[2023-10-30T23:26:07-0500] [ALPM-SCRIPTLET] dracut: *** Including module: i18n ***
[2023-10-30T23:26:07-0500] [ALPM-SCRIPTLET] dracut: *** Including module: btrfs ***
[2023-10-30T23:26:08-0500] [ALPM-SCRIPTLET] dracut: *** Including module: crypt ***
[2023-10-30T23:26:08-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dm ***
[2023-10-30T23:26:08-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 64-device-mapper.rules
[2023-10-30T23:26:08-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 60-persistent-storage-dm.rules
[2023-10-30T23:26:08-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 55-dm.rules
[2023-10-30T23:26:08-0500] [ALPM-SCRIPTLET] dracut: *** Including module: kernel-modules ***
[2023-10-30T23:26:10-0500] [ALPM-SCRIPTLET] dracut: *** Including module: kernel-modules-extra ***
[2023-10-30T23:26:10-0500] [ALPM-SCRIPTLET] dracut: *** Including module: btrfs-snapshot-overlay ***
[2023-10-30T23:26:10-0500] [ALPM-SCRIPTLET] dracut: *** Including module: rootfs-block ***
[2023-10-30T23:26:10-0500] [ALPM-SCRIPTLET] dracut: *** Including module: terminfo ***
[2023-10-30T23:26:10-0500] [ALPM-SCRIPTLET] dracut: *** Including module: udev-rules ***
[2023-10-30T23:26:10-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 40-redhat.rules
[2023-10-30T23:26:10-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 50-firmware.rules
[2023-10-30T23:26:10-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 50-udev.rules
[2023-10-30T23:26:11-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 91-permissions.rules
[2023-10-30T23:26:11-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 80-drivers-modprobe.rules
[2023-10-30T23:26:11-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 70-persistent-net.rules
[2023-10-30T23:26:11-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dracut-systemd ***
[2023-10-30T23:26:11-0500] [ALPM-SCRIPTLET] dracut: *** Including module: usrmount ***
[2023-10-30T23:26:11-0500] [ALPM-SCRIPTLET] dracut: *** Including module: base ***
[2023-10-30T23:26:11-0500] [ALPM-SCRIPTLET] dracut: *** Including module: fs-lib ***
[2023-10-30T23:26:11-0500] [ALPM-SCRIPTLET] dracut: *** Including module: shutdown ***
[2023-10-30T23:26:12-0500] [ALPM-SCRIPTLET] dracut: *** Including modules done ***
[2023-10-30T23:26:12-0500] [ALPM-SCRIPTLET] dracut: *** Installing kernel module dependencies ***
[2023-10-30T23:26:12-0500] [ALPM-SCRIPTLET] dracut: *** Installing kernel module dependencies done ***
[2023-10-30T23:26:12-0500] [ALPM-SCRIPTLET] dracut: *** Resolving executable dependencies ***
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: *** Resolving executable dependencies done ***
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: *** Hardlinking files ***
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: Mode:                     real
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: Method:                   sha256
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: Files:                    843
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: Linked:                   2 files
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: Compared:                 0 xattrs
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: Compared:                 41 files
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: Saved:                    822 B
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: Duration:                 0.014193 seconds
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: *** Hardlinking files done ***
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: *** Generating early-microcode cpio image ***
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: *** Constructing AuthenticAMD.bin ***
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: *** Store current command line parameters ***
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: *** Stripping files ***
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: *** Stripping files done ***
[2023-10-30T23:26:14-0500] [ALPM-SCRIPTLET] dracut: *** Creating image file '/usr/lib/modules/6.5.9-arch2-1/initrd' ***
[2023-10-30T23:26:20-0500] [ALPM-SCRIPTLET] dracut: *** Creating initramfs image file '/usr/lib/modules/6.5.9-arch2-1/initrd' done ***
[2023-10-30T23:26:20-0500] [ALPM-SCRIPTLET] :: Building fallback initramfs for linux (6.5.9-arch2-1)
[2023-10-30T23:26:20-0500] [ALPM-SCRIPTLET] dracut: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-fallback.img 6.5.9-arch2-1
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'nbd' will not be installed, because command 'nbd-client' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: memstrack is not available
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
[2023-10-30T23:26:22-0500] [ALPM-SCRIPTLET] dracut: *** Including module: systemd ***
[2023-10-30T23:26:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: systemd-initrd ***
[2023-10-30T23:26:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: modsign ***
[2023-10-30T23:26:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: i18n ***
[2023-10-30T23:26:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: btrfs ***
[2023-10-30T23:26:23-0500] [ALPM-SCRIPTLET] dracut: *** Including module: crypt ***
[2023-10-30T23:26:24-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dm ***
[2023-10-30T23:26:24-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 64-device-mapper.rules
[2023-10-30T23:26:24-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 60-persistent-storage-dm.rules
[2023-10-30T23:26:24-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 55-dm.rules
[2023-10-30T23:26:24-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dmraid ***
[2023-10-30T23:26:24-0500] [ALPM-SCRIPTLET] dracut: *** Including module: kernel-modules ***
[2023-10-30T23:26:30-0500] [ALPM-SCRIPTLET] dracut: *** Including module: kernel-modules-extra ***
[2023-10-30T23:26:30-0500] [ALPM-SCRIPTLET] dracut: *** Including module: lvm ***
[2023-10-30T23:26:30-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 64-device-mapper.rules
[2023-10-30T23:26:30-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 56-lvm.rules
[2023-10-30T23:26:30-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
[2023-10-30T23:26:30-0500] [ALPM-SCRIPTLET] dracut: *** Including module: mdraid ***
[2023-10-30T23:26:30-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 64-md-raid.rules
[2023-10-30T23:26:30-0500] [ALPM-SCRIPTLET] dracut: *** Including module: multipath ***
[2023-10-30T23:26:30-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 40-multipath.rules
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: *** Including module: nvdimm ***
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: *** Including module: qemu ***
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: *** Including module: qemu-net ***
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: *** Including module: btrfs-snapshot-overlay ***
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: *** Including module: lunmask ***
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: *** Including module: resume ***
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: *** Including module: rootfs-block ***
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: *** Including module: terminfo ***
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: *** Including module: udev-rules ***
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 40-redhat.rules
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 50-firmware.rules
[2023-10-30T23:26:31-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 50-udev.rules
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 91-permissions.rules
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: Skipping udev rule: 80-drivers-modprobe.rules
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: *** Including module: virtiofs ***
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: *** Including module: dracut-systemd ***
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: *** Including module: usrmount ***
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: *** Including module: base ***
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: *** Including module: fs-lib ***
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: *** Including module: shutdown ***
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: *** Including modules done ***
[2023-10-30T23:26:32-0500] [ALPM-SCRIPTLET] dracut: *** Installing kernel module dependencies ***
[2023-10-30T23:26:34-0500] [ALPM-SCRIPTLET] dracut: *** Installing kernel module dependencies done ***
[2023-10-30T23:26:34-0500] [ALPM-SCRIPTLET] dracut: *** Resolving executable dependencies ***
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: *** Resolving executable dependencies done ***
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: *** Hardlinking files ***
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: Mode:                     real
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: Method:                   sha256
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: Files:                    2084
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: Linked:                   9 files
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: Compared:                 0 xattrs
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: Compared:                 478 files
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: Saved:                    1.42 MiB
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: Duration:                 0.067936 seconds
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: *** Hardlinking files done ***
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: *** Generating early-microcode cpio image ***
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: *** Constructing AuthenticAMD.bin ***
[2023-10-30T23:26:36-0500] [ALPM-SCRIPTLET] dracut: *** Store current command line parameters ***
[2023-10-30T23:26:37-0500] [ALPM-SCRIPTLET] dracut: *** Stripping files ***
[2023-10-30T23:26:37-0500] [ALPM-SCRIPTLET] dracut: *** Stripping files done ***
[2023-10-30T23:26:37-0500] [ALPM-SCRIPTLET] dracut: *** Creating image file '/boot/initramfs-linux-fallback.img' ***
[2023-10-30T23:26:46-0500] [ALPM-SCRIPTLET] dracut: *** Creating initramfs image file '/boot/initramfs-linux-fallback.img' done ***
[2023-10-30T23:26:47-0500] [ALPM] running '90-mkinitcpio-install.hook'...
[2023-10-30T23:26:47-0500] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'default'
[2023-10-30T23:26:47-0500] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2023-10-30T23:26:47-0500] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts.img --microcode /boot/amd-ucode.img
[2023-10-30T23:26:47-0500] [ALPM-SCRIPTLET] ==> Starting build: '6.1.60-1-lts'
[2023-10-30T23:26:47-0500] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-10-30T23:26:48-0500] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-10-30T23:26:48-0500] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-10-30T23:26:48-0500] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-10-30T23:26:48-0500] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-10-30T23:26:57-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-10-30T23:26:57-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-10-30T23:26:57-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-10-30T23:26:57-0500] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-10-30T23:26:57-0500] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-10-30T23:26:57-0500] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-10-30T23:27:00-0500] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-10-30T23:27:00-0500] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-10-30T23:27:00-0500] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-10-30T23:27:01-0500] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-lts.img'
[2023-10-30T23:27:02-0500] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-10-30T23:27:02-0500] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'fallback'
[2023-10-30T23:27:02-0500] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2023-10-30T23:27:02-0500] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts-fallback.img -S autodetect --microcode /boot/amd-ucode.img
[2023-10-30T23:27:02-0500] [ALPM-SCRIPTLET] ==> Starting build: '6.1.60-1-lts'
[2023-10-30T23:27:02-0500] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-10-30T23:27:03-0500] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-10-30T23:27:03-0500] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-10-30T23:27:03-0500] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-10-30T23:27:09-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2023-10-30T23:27:17-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-10-30T23:27:18-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-10-30T23:27:20-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-10-30T23:27:20-0500] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-10-30T23:27:20-0500] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-10-30T23:27:20-0500] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-10-30T23:27:21-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2023-10-30T23:27:22-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2023-10-30T23:27:23-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2023-10-30T23:27:23-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2023-10-30T23:27:23-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2023-10-30T23:27:23-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2023-10-30T23:27:27-0500] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-10-30T23:27:29-0500] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-10-30T23:27:33-0500] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-10-30T23:27:34-0500] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-lts-fallback.img'
[2023-10-30T23:27:38-0500] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-10-30T23:27:38-0500] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
[2023-10-30T23:27:38-0500] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2023-10-30T23:27:38-0500] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img --microcode /boot/amd-ucode.img
[2023-10-30T23:27:38-0500] [ALPM-SCRIPTLET] ==> Starting build: '6.5.9-arch2-1'
[2023-10-30T23:27:38-0500] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-10-30T23:27:39-0500] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-10-30T23:27:39-0500] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-10-30T23:27:40-0500] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-10-30T23:27:40-0500] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-10-30T23:27:48-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-10-30T23:27:49-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-10-30T23:27:49-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-10-30T23:27:49-0500] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-10-30T23:27:49-0500] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-10-30T23:27:49-0500] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-10-30T23:27:51-0500] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-10-30T23:27:52-0500] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-10-30T23:27:52-0500] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-10-30T23:27:52-0500] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux.img'
[2023-10-30T23:27:54-0500] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-10-30T23:27:54-0500] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'fallback'
[2023-10-30T23:27:54-0500] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2023-10-30T23:27:54-0500] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-fallback.img -S autodetect --microcode /boot/amd-ucode.img
[2023-10-30T23:27:54-0500] [ALPM-SCRIPTLET] ==> Starting build: '6.5.9-arch2-1'
[2023-10-30T23:27:54-0500] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-10-30T23:27:55-0500] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-10-30T23:27:55-0500] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-10-30T23:27:55-0500] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-10-30T23:28:01-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2023-10-30T23:28:10-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-10-30T23:28:10-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-10-30T23:28:13-0500] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-10-30T23:28:13-0500] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-10-30T23:28:13-0500] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-10-30T23:28:13-0500] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-10-30T23:28:14-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2023-10-30T23:28:14-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2023-10-30T23:28:15-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2023-10-30T23:28:15-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2023-10-30T23:28:15-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2023-10-30T23:28:15-0500] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2023-10-30T23:28:20-0500] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-10-30T23:28:22-0500] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-10-30T23:28:26-0500] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-10-30T23:28:26-0500] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-fallback.img'
[2023-10-30T23:28:31-0500] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-10-30T23:28:32-0500] [ALPM] running '90-packagekit-refresh.hook'...
[2023-10-30T23:28:32-0500] [ALPM] running 'dbus-reload.hook'...
[2023-10-30T23:28:32-0500] [ALPM] running 'eos-reboot-required.hook'...
[2023-10-30T23:28:33-0500] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2023-10-30T23:28:33-0500] [ALPM] running 'ghc-register.hook'...
[2023-10-30T23:28:34-0500] [ALPM] running 'glib-compile-schemas.hook'...
[2023-10-30T23:28:34-0500] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-10-30T23:28:35-0500] [ALPM] running 'gtk4-querymodules.hook'...
[2023-10-30T23:28:35-0500] [ALPM] running 'rebuild-detector.hook'...
[2023-10-30T23:28:35-0500] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-10-30T23:28:56-0500] [ALPM-SCRIPTLET] foreign	zoom
[2023-10-30T23:28:56-0500] [ALPM] running 'texinfo-install.hook'...
[2023-10-30T23:28:56-0500] [ALPM] running 'update-desktop-database.hook'...
[2023-10-30T23:28:56-0500] [ALPM] running 'vimdoc.hook'...
[2023-10-30T23:28:56-0500] [ALPM] running 'zz-snap-pac-grub-post.hook'...
[2023-10-30T23:28:57-0500] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-10-30T23:28:57-0500] [ALPM-SCRIPTLET] Found background: /usr/share/endeavouros/splash.png
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-linux-lts
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-lts.img
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-lts-fallback.img
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux.img
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-fallback.img
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Warning: os-prober will not be executed to detect other bootable partitions.
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Systems on them will not be added to the GRUB boot configuration.
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Check GRUB_DISABLE_OS_PROBER documentation entry.
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-10-30T23:28:58-0500] [ALPM-SCRIPTLET] Detecting snapshots ...
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-30 23:23:37 | @/.snapshots/682/snapshot | pre    | /usr/lib/packagekitd                                                     |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-30 22:55:16 | @/.snapshots/681/snapshot | single | boot        |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-30 22:37:13 | @/.snapshots/680/snapshot | post   | auto-cpufreq python-annotated-types python-autocommand python-click pyth |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-30 22:37:03 | @/.snapshots/679/snapshot | pre    | pacman -R -n -s --config /etc/pacman.conf -- auto-cpufreq                |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-30 22:14:33 | @/.snapshots/678/snapshot | single | boot        |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-30 14:29:01 | @/.snapshots/677/snapshot | single | boot        |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:20:34 | @/.snapshots/676/snapshot | post   | cockpit-packagekit                                                       |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:20:25 | @/.snapshots/675/snapshot | pre    | pacman -S --config /etc/pacman.conf -- extra/cockpit-packagekit          |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:13:26 | @/.snapshots/674/snapshot | post   | podman-docker                                                            |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:13:13 | @/.snapshots/673/snapshot | pre    | pacman -S --config /etc/pacman.conf -- extra/podman-docker               |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:03:07 | @/.snapshots/672/snapshot | post   | libpackagekit-glib packagekit                                            |
[2023-10-30T23:28:59-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-24 01:02:54 | @/.snapshots/671/snapshot | pre    | pacman -S --config /etc/pacman.conf -- extra/packagekit                  |
[2023-10-30T23:29:00-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-10-02 16:01:33 | @/.snapshots/625/snapshot | single | timeline        |
[2023-10-30T23:29:00-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-09-27 10:32:34 | @/.snapshots/620/snapshot | single | timeline        |
[2023-10-30T23:29:00-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-09-26 00:00:07 | @/.snapshots/615/snapshot | single | timeline        |
[2023-10-30T23:29:00-0500] [ALPM-SCRIPTLET] Found snapshot: 2023-09-25 12:31:47 | @/.snapshots/605/snapshot | single | timeline        |
[2023-10-30T23:29:00-0500] [ALPM-SCRIPTLET] Found 16 snapshot(s)
[2023-10-30T23:29:00-0500] [ALPM-SCRIPTLET] Unmount /tmp/grub-btrfs.TQTFLAwLNT .. Success
[2023-10-30T23:29:00-0500] [ALPM-SCRIPTLET] done
[2023-10-30T23:29:00-0500] [ALPM] running 'zz-snap-pac-post.hook'...
[2023-10-30T23:29:00-0500] [ALPM-SCRIPTLET] ==> root: 683
I think the reset and fix was between these two lines. I will have to check the other system logs for a reboot time.
Ahh…I can tell you what the issue probably is. You are running both dracut and mkinitcpio.
So your dracut images are being overwritten by mkinitcpio since that is running second.
You should only be using one or the other. Since your dracut images seem to be the ones that work. I would uninstall mkinitcpio
I wonder how that happened? I did a fresh install when R1 came out which by default uses dracut. I didn’t do a conversion.
Now that I think about it, the desktop uses mkinitcpio. It is running my initial Endeavor install. Makes sense now. Thanks.
But what is up with the random UUID it is looking for? I can not find it anywhere in my system.
Nm. The desktop also runs dracut. But it also has mkinitcpio, which when I tried to remove it links to mkinitcpio-archiso. I think it was installed when I was making the KDE EndeavourOS ISO’s. But only the laptop has problems updating, not the desktop.
Is there any way to omit the skipped modules in the log for dracut? It sure does add a lot of blot to the logs.
for that i pacstrap arch into a folder and chroot intoo that to make an iso :slight_smile: added endeavouros also on ppacman etc…
You could customize the log levels but that would require manually modifying the automation.
Alternatively, you could set the quiet flag in /etc/eos-dracut.conf but would eliminate all the output from dracut.
Nah, it’s fine. I thought I read somewhere about omitting only the missing drivers. Not worth the headache. At least this is something easy to fix. I will mark removing mkinitcpio as the solution and update if it returns.
Thanks for the quick response. I should have started using Arch years ago. If I was on Ubuntu I would be on my 5th reinstall this year.
