i dont know what i do but after install this update i am getting error. i use this command for update
sudo pacman -Syyu
i’m in KDE but feel like XFCE. no animation . no wobby windows and overall animation , but DE is KDE , interface and system overall like KDE
after getting like this error i do few times restart but not working all same . then i uninstall linux-gen kernel . but same error , anyone help me how to fix
s4ndm4n
December 30, 2021, 12:18pm
2
Did you try the settings in KDE?
yes all enabled . nothing changed. i think just animation problem but how to fix this?
and apps background color is white , but why
xircon
December 30, 2021, 1:14pm
5
Check your compositor is turned on in settings.
xircon
December 30, 2021, 1:19pm
7
Re-enable, sometimes it crashes and throws its toys out of the pram
After re-enable and Scale method - smooth
rendering backend - openGL 2.0 its working like past KDE,
but rendering backend - openGL 3.1, i do this.
xircon
December 30, 2021, 1:35pm
9
What GPU? Try some of the other setting - at work on Windows, but IIRC some of the scale methods do not work on all GPUs.
What package were updated? Work back from there.
Check logs for error messages.
Try the LTS kernel.
Do you have an nvidia gpu?
If kwin is crashing try reloading it in konsole and seeing if any error messages help.
kwin_x11 --replace&'
problem was fixed
otherbarry:
Try the LTS kernel.
i tried LTS kernel but i don’t like this kernel
Linux and linux-gen kernel what i use
no i have ryzen 5 2500u and vega 8 graphic integrated graphic card
What don’t you like about the lts kernel?
You will likely have things break occasionally if you continue to use the others. It’s just the way it is realistically.
BlackHole:
problem was fixed
How?
You may help another with a similar issue.
So?
Using the LTS kernel is useful to boot into if there is a serious regression in the mainline kernel, of which both linux
and linux-zen
are built from.
You don’t have to regularly use it, just have it available in case .
after update i think for some reason its disabled
