I didn’t find out why it doesn’t let me add a second code block via the Ctrl E sign </> like it works when open a topic new and hit the Ctrl E Sign </> directly and get the empty block and can then add code into it. But the moment I write normal text before and after it, I can hit the Ctrl E sign </> as often as I like some lines under the last text or near it or above it or what but not code block appears afterward. And I paste code always unformatted with Ctrl+Shift+V
This then happens, when hitting the block sign first an then putting text into it by ctrl+shift+V. Do I have to put in 2 .or 3 codeblocks before adding one letter elsewhere???
Don’t know what to tell you, I still can’t replicate this. Can you post a screenshot of your post edit before actually posting? The web source is impossible to decipher.
Typing three backticks bevor added a letter text the box comes. Now its over after this text.
It work only directly when I dont type a letter bevor or afterward.
I would suggest asking a forum moderator to split this post as most of the responses are related to code-blocks instead of the title. It would get a lot more eyes that way.
To write a code block, it’s as you’ve done, but perhaps turn off the rich text editor mode. I find I end up wrestling with that as it tries to automate things.
copy text you desire to paste over here. Then past it over here. Select the newly copied text and the press CTRL+E and then it will enclose the entire text
seems cooking dinner took longer than expected oh well as long as Op has a working solution.
Markdown format is the solution. Rich text seems to format unformated text.
After I opend a reply I could put one code-box in it but when wrote one letter nothing works with code block anymore in rich text.
In Markdown I can do this:
: Installation fortsetzen? [J/n]
(1/1) Schlüssel im Schlüsselbund werden geprüft [------------------------------------------------] 100%
(1/1) Paket-Integrität wird überprüft [------------------------------------------------] 100%
(1/1) Paket-Dateien werden geladen [------------------------------------------------] 100%
(1/1) Auf Dateikonflikte wird geprüft [------------------------------------------------] 100%
:: Pre-transaction-Hooks werden gestartet …
(1/1) Scanning packages for security issues...
codeblock2
endeavouros ist aktuell
core ist aktuell
extra ist aktuell
multilib ist aktuell
:: Durchsuche AUR nach Updates...
:: Durchsuche Datenbanken nach Updates...
-> lib32-llvm-libs: local (1:22.1.8-1) is newer than multilib (1:22.1.6-1)
-> Als nicht aktuell markierte AUR-Pakete: low_latency_layer-git qt-sudo xwaylandvideobridge
-> maliit-keyboard: lokales (2.3.1-4) ist neuer als das AUR (2.3.1-3)
es gibt nichts zu tun
