Activation of Network Connection Failed [recurrent error]
Screenshot_2021-10-10_18-50-20
Im using Endeavour with gnome, and a ethernet cable conection. For several days i had no problem. It miight be a coincidence, but after I installed the Brave Browser the error started to appear, but it persists even after uninstalled, so i dont think thats the cause.
The error "[Connection Failed] Activationj of Network connection failed". shows up quite random, but it is more common if i leave the computer idle for around 20 minutes. (its not a problem with my ehernet connections, since the rest of my devices are still connected to the internet).
I’ve tried turning off the connection, turning off the modem and router, disconecting the ethernet cable, stoping and restarting the NetworkManager, login out, but the error persists.
The only wasy to fix it is restaring the computer.
these are the logs of the status of the NetworkManager.
$ sudo systemctl status NetworkManager
â—Ź NetworkManager.service - Network Manager
     Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; vendor preset: disabled)
    Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
             └─NetworkManager-ovs.conf
     Active: active (running) since Thu 2021-10-21 19:20:48 -04; 54min ago
       Docs: man:NetworkManager(8)
   Main PID: 3771 (NetworkManager)
      Tasks: 3 (limit: 7086)
     Memory: 3.9M
        CPU: 655ms
     CGroup: /system.slice/NetworkManager.service
             └─3771 /usr/bin/NetworkManager --no-daemon
oct 21 20:13:47 argenis-pc NetworkManager[3771]: <info>  [1634861627.8326] device (enp1s0): state change: config -> i>
oct 21 20:13:47 argenis-pc NetworkManager[3771]: <info>  [1634861627.8335] dhcp4 (enp1s0): activation: beginning tran>
oct 21 20:14:32 argenis-pc NetworkManager[3771]: <warn>  [1634861672.7952] dhcp4 (enp1s0): request timed out
oct 21 20:14:32 argenis-pc NetworkManager[3771]: <info>  [1634861672.7953] dhcp4 (enp1s0): state changed unknown -> t>
oct 21 20:14:32 argenis-pc NetworkManager[3771]: <info>  [1634861672.7954] device (enp1s0): state change: ip-config ->
oct 21 20:14:32 argenis-pc NetworkManager[3771]: <info>  [1634861672.7963] manager: NetworkManager state is now DISCO>
oct 21 20:14:32 argenis-pc NetworkManager[3771]: <warn>  [1634861672.7968] device (enp1s0): Activation: failed for co>
oct 21 20:14:32 argenis-pc NetworkManager[3771]: <info>  [1634861672.7973] device (enp1s0): state change: failed -> d>
oct 21 20:14:32 argenis-pc NetworkManager[3771]: <info>  [1634861672.8209] dhcp4 (enp1s0): canceled DHCP transaction
oct 21 20:14:32 argenis-pc NetworkManager[3771]: <info>  [1634861672.8210] dhcp4 (enp1s0): state changed timeout -> t>
and after restaring:
     Active: active (running) since Thu 2021-10-21 20:16:58 -04; 1min 32s ago
   Main PID: 4852 (NetworkManager)
     Memory: 3.4M
        CPU: 142ms
             └─4852 /usr/bin/NetworkManager --no-daemon
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.7970] device (enp1s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.8175] dhcp4 (enp1s0): canceled DHCP transaction
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.8176] dhcp4 (enp1s0): state changed timeout -> terminated
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.8193] policy: auto-activating connection 'Profile 1' (603fc3b3-7071-4814-805e-4a6203f62eef)
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.8206] device (enp1s0): Activation: starting connection 'Profile 1' (603fc3b3-7071-4814-805e-4a6203f62eef)
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.8208] device (enp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.8224] manager: NetworkManager state is now CONNECTING
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.8229] device (enp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.8244] device (enp1s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
oct 21 20:18:28 argenis-pc NetworkManager[4852]: <info>  [1634861908.8250] dhcp4 (enp1s0): activation: beginning transaction (timeout in 45 seconds)
Can you give hardware info and bootlog please?
inxi -N >> log.txt && journalctl -b -0 >> log.txt && cat log.txt | eos-sendlog
your ISP connection / Router is ipv4 only? you could try to disable ipv6 in NM-settings.
https://clbin.com/lVCE2
Maybe this is a r8168 driver package issue.
If that’s the case, then either
  • reinstall r8168 and reboot
    or
  • uninstall r8168 and reboot
I’d guess the latter helps.
And if neither of them helps, then further info will be required.
This one solved the problem.
First I did a:
sudo pacman -S r8168
And the rebooted my PC. Which made me not being able to connect to the internet at all, the internet option was not available.
Fortunately, a simple
sudo pacman -R r8168
Solved the problem. And now, the internet connection is maintained without any problem.
