Hello, forum!
I was wondering if someone could help me with the following problem.
I installed acroread from AUR, all good, but now when I try to open it, it crashes.
I’m using i3-gaps, but all the required libraries are installed as far as I’m aware.
This is what I get if I’m opening from terminal:
/home/matteo/.gtkrc-2.0:4: Unable to find include file: "~/.gtkrc-2.0.mine"
(acroread:164147): Gtk-WARNING **: Unable to locate theme engine in module_path: "pixmap",
(acroread:164147): Gtk-WARNING **: Unable to locate theme engine in module_path: "adwaita",
(acroread:164147): Gtk-WARNING **: Unable to locate theme engine in module_path: "murrine",
(acroread:164147): GdkPixbuf-WARNING **: Error loading XPM image loader: Image type 'xpm' is not supported
(acroread:164147): GLib-GObject-CRITICAL **: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(acroread:164147): GLib-GObject-CRITICAL **: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(acroread:164147): Gdk-CRITICAL **: IA__gdk_window_set_icon_list: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
(acroread:164147): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_width: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
(acroread:164147): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_height: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Is anyone aware of what should be my next step to solve this?
Thanks!
