my problem is not Endeavour specific, as I also face it with pure Arch. The topic basically says it all - my laptop is Acer Predator G9-592 which comes with built in 2.1 speaker system, and all sound is coming out of subwoofer which in tests is recognized as ‘left front’.
I played with pavucontrol, alsamixer, but sound configuration isn’t the thing that I’m good at. I looked for soultions @ Arch wiki and forums, but didn’t found any good ones.
Yup that works just fine (cannot test whether the sub is playing or not - my kids are sleeping).
Don’t know how I missed that solution, perhaps not enough digging, maybe DuckDuck showed me some inacurate results…
So you got speakers working but not sure on whether the sub is also working i take it? Sometimes these solutions are hard to find. I’m used to skimming through stuff as there is so much garbage on the internet. I hope the sub works too.
Actually I just ran `speaker-test’ utlility which allows me to silently check wheter speakers are playing corrently, and something is wrong, I think front left is playing together with subwofer. I will play with setting maybe tomorrow and post solution if I’ll fix this. I suppose that its just about assigning correct pins to channels.
