I have the following problem. I want to access a specific folder in a home directory on a different hard drive. The home directory has the same username. When I try to access the folder named “steamapps” with Dolphin, I always end up in my own. I just can’t get to the games that are in the folder.
How is the HDD connected to your computer? internal, USB?
How are you trying to access the other? CLi, GUI, etc?
Sounds like its a linux distro, but for completeness… which OS was installed on the extra HDD?
If it helps, normally, using ‘~’ will redirect to the current users home directory, not a home directory mounted otherwise.
Use ‘df’ in your terminal, and find out where the extra hard drive has been mounted to… then navigate to the folder you want.
