A User Command to Clean and Update System
If you have to alias these operations, do it like this:
alias install="sudo pacman -S"
#alias update="sudo pacman -Syu"      # one y, not two
alias update="yay"                    # better than above, but alias is stupid (more typing)
alias search="pacman -Ss"             # no sudo
alias search-local="pacman -Qs"       # no sudo
alias pkg-info="pacman -Qi"           # no sudo
alias local-install="sudo pacman -U"
alias clear-cache="sudo pacman -Scc"
alias unlock="sudo rm /var/lib/pacman/db.lck"
alias remove="sudo pacman -R"
alias autoremove="sudo pacman -Rns"   # understand what it does before using it
However, I would recommend learning what these commands to rather than memorising a bunch of aliases.
Also, as a personal preference, I never put sudo in aliases. Typing out the word sudo in the terminal is a great time to reflect upon one’s actions: “Is this really what I want? Do I really need to be root to do it?”
Just to be sure, is this OK or would probably remove something might be needed?
Amazing @Kresimir
You are all wonderful guys
I always call it here EndeavourOS University
That would remove all the packages in cache.
I think paccache is a better choice for having a more fine grained control.
:eye: paccache --help
There is no general yes/no answer to this.
It will remove everything from the cache. If this is what you want, then great. If not, don’t do it (as with anything in life).
Are there situations where this is what you want? Sure. Are there situations where you might regret this? Absolutely.
I find it a bit depressing how amazed you are at my most useless post in this thread, yet the serious advice I give you, you just ignore.
Sorry for that
I see your posts are useful. Any posts of anybody I see useful even if proven wrong. One way is learning from mistakes. They say a rational/reasonable man is who learns from “his” mistakes, and a wise man is who learns from “others” mistake.
So, I am this “other” who makes users “wise”
Thank you.
Thank you. I will study more!
This is just for my own testing, learning and trying!
#!/bin/bash
paccache -ruk1
rate-mirrors arch | sudo tee /etc/pacman.d/mirrorlist
eos-rankmirrors
### journalctl --vacuum-time=4weeks
yay -Syu
An interesting clarification. I don’t think a package that is an optional dependency of another package will ever be on the list of orphans. I believe the reason optional dependencies get removed is because of how pacman -Rs works.
I started removing orphans in a pacman -R loop to avoid this behaviour. To be honest, I have always kind of felt it was a bug in pacman but I guess you can look at either way.
Same here… this is why I said earlier I am confused! An orphan is an orphan… I do not understand semi orphans!
That is true. But @Kresimir’s other point is still valid.
An orphan is package that was brought in as a dependency of another package that is no longer installed. It has nothing to do with if you want/need that package.
You as the end-user need to review the list of orphans and determine if you want to remove them or not.
how do you go about it? use the command yay -Yc or are there better ways?
There should be no reason to use -Rc with orphans. By definition there shouldn’t be anything depending on them.
I basically call pacman -R $(pacman -Qtdq) until pacman -Qtdq stops returning results.
Except, I can never remember pacman -Qtdq, so I use aura -O instead but it does the exact same thing.
i thought yay -Yc not -Rc :wink:
yay -Yc 	Clean unneeded dependencies.
From looking at the code it appears to do the right thing.
However, I would need to setup a test to be sure.
Yeah, that cleans the orphan packages, but I still wouldn’t do it like that, but go through the list and decide what to remove, what to leave alone, and what to mark as explicitly installed.
Only Arch Linux users love to kill orphans without any remorse!!!1111
honka_memes-128px-15
I like to follow this guide to clean up my system. I hope you find it helpful.
I did a test and found that both commands do not lead to the same result. pacman deletes e.g. no packages where one of the packages to be deleted is listed as ‘Depends On’ or 'Required By '. yay -Yc deletes those too.
