A start job is running for Load Kernel Modules takes so long
I installed EndeavourOS with windows 11 in dual boot but every time i boot into EndeavourOS it takes 5 minutes to boot with the message “A start job is running for Load Kernel Modules”. I used Online Install and it is up to date its updated. What i need to do?
And by disconnecting the flash drive before booting, does anything change? I have a similar one, a kingston, and sometimes when it is plugged in, the system freezes on shutdown. After removing it, everything moves on.
Hi i solved the problem! I added in Kernel Boot Parmeters ibt=off
