I’m on Firefox. It works perfectly. Just one click to change the theme.
It all seems to work on Firefox. Except the logo is broken on horizon
all three theme work on qutebrowser,librewolf + firefox .. just no like sidebar.. ( impo , more clicks/keys for push)
NICE! I never liked Dark Endeavour. Dark Horizon is fantastic!!
All is well in Vivaldi, Librewolf, and Firefox.
I get the exact same behavior as you when I set the theme to Auto and follow the system setting. I’m using Firefox.
If you are talking about the light Horizon mode, then yes, I have to fix it when I have more time.
Yes. Exactly that.
What you are doing is choosing the Horizon colour palette on the Endeavour dark theme. If you choose the Horizon theme in your profile settings and choose either Horizon dark or Endeavour dark, the theme will display as @swh posted.
I know, I have to change the dark and light modes in the basic settings. I did try it earlier, but the whole site went white. So, I have the change the logo for both modes when I have more time.
Very Very Very nice, Happy Turkey Day too you to.
Mine is working again with dark endeavour.I logged in to all white and almost went blind.
Thanks for all the work making the Endeavour forum and system.
Very well done, thank you for all your hard work, @Brian.
There has been a change, because I figured things out. The previous theme toggle in the side menu doesn’t work with the light and dark mode setting in the forum, hence I removed it.
The Horizon theme is the default and now you can select which layout and layout colour you want to use in your profile interface settings.
The logo and header title colours display dark in light mode and light in dark mode.
Interesting update….took me a bit to sort it out. I’m liking the Horizon Dark mode…..Renders nicely with Firefox Nightly.
My apologies for the detour in setting your preference, but when software goes forward, plugin features are left behind. If I can find a replacement for the old theme toggle, I will implement it.
I’m good…Thank You for all the work!!! Besides….I’m a Gnome user….so plugins not working are “normal” with any major update……![]()
no dark mode at all right now.
no option to switch it to dark either. my corneas are on fire ![]()
