Today when booting, my second monitor showed the following rather strange problem: It was on in the logon screen, normally showing a second logon screen, but as soon as I logon into KDE Plasma, the monitor gets disabled (light turns from blue to orange, “no signal”, standby). Sometimes I have hickups with the displays, and so far I have attributed them to the state of the NVidia driver (running a 3070).
Now, inside KDE Plasma, suddenly the monitor does not get recognized in the display configuration of Plasma. Well, I say “recognized”, the display seems to be there (selectable from the list of displays), however the graphic at the top where you can drag and drop displays to align them doesn’t show the second monitor. I fiddled around with the settings, and although I can toggle active and inactive on and off and “Apply”, the second monitor never gets used.
Afterwards, I’ve tried nvidia-settings, and in the same display where you can see visual representations of your monitor, the second monitor doesn’t get displayed as well! However, using the settings and activating the second monitor, I can “fix” the problem. So via the NVidia tool I can at least work around it.
This is the log of the last system update I did (the day before yesterday, so I already booted into the system that is this way yesterday):
[2022-11-23T06:30:26+0100] [PACMAN] Running 'pacman -S -y -u --config /etc/pacman.conf --'
[2022-11-23T06:30:26+0100] [PACMAN] synchronizing package lists
[2022-11-23T06:30:29+0100] [PACMAN] starting full system upgrade
[2022-11-23T06:31:55+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] Using system disk as snapshot device for creating snapshots in BTRFS mode
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] Mounted '/dev/nvme0n1p2' at '/run/timeshift/29759/backup'
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] Creating new backup...(BTRFS)
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] Saving to device: /dev/nvme0n1p2, mounted at path: /run/timeshift/29759/backup
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] Created directory: /run/timeshift/29759/backup/timeshift-btrfs/snapshots/2022-11-23_06-31-55
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] Created subvolume snapshot: /run/timeshift/29759/backup/timeshift-btrfs/snapshots/2022-11-23_06-31-55/@
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] Created subvolume snapshot: /run/timeshift/29759/backup/timeshift-btrfs/snapshots/2022-11-23_06-31-55/@home
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] Created control file: /run/timeshift/29759/backup/timeshift-btrfs/snapshots/2022-11-23_06-31-55/info.json
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] BTRFS Snapshot saved successfully (0s)
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] Tagged snapshot '2022-11-23_06-31-55': ondemand
[2022-11-23T06:31:55+0100] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET]
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Found stale mount for device '/dev/nvme0n1p2' at path '/run/timeshift/29759/backup'
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Unmounted successfully
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Mounted '/dev/nvme0n1p2' at '/run/timeshift/29942/backup'
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Removing snapshot: 2022-11-20_07-35-03
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Deleting subvolume: @home (Id:8888)
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Deleted subvolume: @home (Id:8888)
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Deleting subvolume: @ (Id:8887)
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Deleted subvolume: @ (Id:8887)
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Deleted directory: /run/timeshift/29942/backup/timeshift-btrfs/snapshots/2022-11-20_07-35-03
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Removed snapshot: 2022-11-20_07-35-03
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] Found stale mount for device '/dev/nvme0n1p2' at path '/run/timeshift/29942/backup'
[2022-11-23T06:31:56+0100] [ALPM-SCRIPTLET] GRUB-Konfigurationsdatei wird erstellt …
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Linux-Abbild gefunden: /boot/vmlinuz-linux
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] initrd-Abbild gefunden: /boot/amd-ucode.img /boot/initramfs-linux.img
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux-fallback.img
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Warnung: Zur Erkennung anderer bootfähiger Partitionen wird os-prober nicht ausgeführt.
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Die darauf befindlichen Systeme werden nicht zur GRUB-Bootkonfiguration hinzugefügt.
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Schauen Sie in den Dokumentationseintrag GRUB_DISABLE_OS_PROBER.
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Bootmenü-Eintrag für UEFI-Firmware-Einstellungen wird hinzugefügt …
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Detecting snapshots ...
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-23 06:31:55 | timeshift-btrfs/snapshots/2022-11-23_06-31-55/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-22 22:00:01 | timeshift-btrfs/snapshots/2022-11-22_22-00-01/@ | daily | N/A |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-21 22:00:01 | timeshift-btrfs/snapshots/2022-11-21_22-00-01/@ | daily | N/A |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-20 22:00:01 | timeshift-btrfs/snapshots/2022-11-20_22-00-01/@ | daily | N/A |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-20 11:00:02 | timeshift-btrfs/snapshots/2022-11-20_11-00-02/@ | weekly | N/A |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-20 07:38:31 | timeshift-btrfs/snapshots/2022-11-20_07-38-31/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-20 07:38:12 | timeshift-btrfs/snapshots/2022-11-20_07-38-12/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-19 22:00:01 | timeshift-btrfs/snapshots/2022-11-19_22-00-01/@ | daily | N/A |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-18 22:00:01 | timeshift-btrfs/snapshots/2022-11-18_22-00-01/@ | daily | N/A |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-13 11:00:01 | timeshift-btrfs/snapshots/2022-11-13_11-00-01/@ | weekly | N/A |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-10-27 17:00:01 | timeshift-btrfs/snapshots/2022-10-27_17-00-01/@ | monthly | N/A |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found snapshot: 2021-10-18 20:15:02 | timeshift-btrfs/snapshots/2022-08-07_14-39-16/@ | ondemand | Before restoring '2022-08-07 07:46:29' |
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Found 12 snapshot(s)
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] Unmount /tmp/grub-btrfs.EdQlhomQy4 .. Success
[2022-11-23T06:31:57+0100] [ALPM-SCRIPTLET] abgeschlossen
[2022-11-23T06:31:57+0100] [ALPM] transaction started
[2022-11-23T06:31:57+0100] [ALPM] upgraded amd-ucode (20221109.60310c2-1 -> 20221109.60310c2-2)
[2022-11-23T06:31:57+0100] [ALPM] upgraded brotli (1.0.9-8 -> 1.0.9-9)
[2022-11-23T06:31:57+0100] [ALPM] upgraded bzip2 (1.0.8-4 -> 1.0.8-5)
[2022-11-23T06:31:57+0100] [ALPM] upgraded libxcrypt (4.4.31-1 -> 4.4.33-1)
[2022-11-23T06:31:57+0100] [ALPM] upgraded zlib (1:1.2.13-1 -> 1:1.2.13-2)
[2022-11-23T06:31:57+0100] [ALPM] upgraded systemd-libs (252.1-1 -> 252.1-2)
[2022-11-23T06:31:57+0100] [ALPM] upgraded libxrandr (1.5.2-5 -> 1.5.3-1)
[2022-11-23T06:31:57+0100] [ALPM] upgraded libpng (1.6.38-2 -> 1.6.39-1)
[2022-11-23T06:31:57+0100] [ALPM] upgraded lzo (2.10-3 -> 2.10-4)
[2022-11-23T06:31:57+0100] [ALPM] upgraded icu (72.1-1 -> 72.1-2)
[2022-11-23T06:31:57+0100] [ALPM] upgraded systemd (252.1-1 -> 252.1-2)
[2022-11-23T06:31:58+0100] [ALPM] upgraded libedit (20210910_3.1-1 -> 20210910_3.1-2)
[2022-11-23T06:31:58+0100] [ALPM] upgraded filezilla (3.62.1-1 -> 3.62.2-1)
[2022-11-23T06:31:58+0100] [ALPM] upgraded gssdp (1.6.1-1 -> 1.6.2-1)
[2022-11-23T06:31:58+0100] [ALPM] upgraded gupnp (1:1.6.1-1 -> 1:1.6.2-1)
[2022-11-23T06:31:58+0100] [ALPM] upgraded lib32-brotli (1.0.9-4 -> 1.0.9-5)
[2022-11-23T06:31:58+0100] [ALPM] upgraded lib32-bzip2 (1.0.8-2 -> 1.0.8-3)
[2022-11-23T06:31:58+0100] [ALPM] upgraded lib32-icu (72.1-1 -> 72.1-2)
[2022-11-23T06:31:58+0100] [ALPM] upgraded lib32-zlib (1.2.13-1 -> 1.2.13-2)
[2022-11-23T06:31:58+0100] [ALPM] upgraded lib32-libpng (1.6.38-2 -> 1.6.39-1)
[2022-11-23T06:31:58+0100] [ALPM] upgraded lib32-libxcb (1.15-1 -> 1.15-2)
[2022-11-23T06:31:58+0100] [ALPM] upgraded lib32-libxcrypt (4.4.31-1 -> 4.4.33-1)
[2022-11-23T06:31:58+0100] [ALPM] upgraded libnewt (0.52.21-8 -> 0.52.22-1)
[2022-11-23T06:31:58+0100] [ALPM] upgraded libupnp (1.14.14-1 -> 1.14.15-1)
[2022-11-23T06:31:58+0100] [ALPM] upgraded linux-firmware-whence (20221109.60310c2-1 -> 20221109.60310c2-2)
[2022-11-23T06:31:58+0100] [ALPM] upgraded linux-firmware (20221109.60310c2-1 -> 20221109.60310c2-2)
[2022-11-23T06:31:58+0100] [ALPM] upgraded luajit (2.1.0.beta3.r449.gdad04f17-1 -> 2.1.0.beta3.r455.g46aa45dc-1)
[2022-11-23T06:31:58+0100] [ALPM] upgraded minizip (1:1.2.13-1 -> 1:1.2.13-2)
[2022-11-23T06:31:58+0100] [ALPM] upgraded mpfr (4.1.0.p13-3 -> 4.1.1-1)
[2022-11-23T06:31:59+0100] [ALPM] upgraded pciutils (3.8.0-2 -> 3.9.0-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded pycharm-community-edition (2022.2.3-1 -> 2022.2.4-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded python-autocommand (2.2.1-1 -> 2.2.2-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded python-cairo (1.21.0-1 -> 1.22.0-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded python-grpcio (1.50.1-2 -> 1.51.0-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded python-jaraco.text (3.10.0-1 -> 3.11.0-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded python-orjson (3.8.1-1 -> 3.8.2-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded python-setuptools (1:65.5.0-1 -> 1:65.5.1-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded qt5-base (5.15.7+kde+r174-1 -> 5.15.7+kde+r175-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded systemd-sysvcompat (252.1-1 -> 252.1-2)
[2022-11-23T06:32:00+0100] [ALPM] upgraded tcl (8.6.12-3 -> 8.6.13-1)
[2022-11-23T06:32:00+0100] [ALPM] upgraded xxhash (0.8.1-2 -> 0.8.1-3)
[2022-11-23T06:32:00+0100] [ALPM] transaction completed
[2022-11-23T06:32:01+0100] [ALPM] running '20-systemd-sysusers.hook'...
[2022-11-23T06:32:01+0100] [ALPM] running '30-systemd-catalog.hook'...
[2022-11-23T06:32:01+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-11-23T06:32:01+0100] [ALPM] running '30-systemd-hwdb.hook'...
[2022-11-23T06:32:01+0100] [ALPM] running '30-systemd-sysctl.hook'...
[2022-11-23T06:32:01+0100] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-11-23T06:32:01+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-11-23T06:32:01+0100] [ALPM] running '30-systemd-update.hook'...
[2022-11-23T06:32:01+0100] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-11-23T06:32:01+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
[2022-11-23T06:32:01+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
[2022-11-23T06:32:01+0100] [ALPM-SCRIPTLET] ==> Starting build: 6.0.9-arch1-1
[2022-11-23T06:32:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-11-23T06:32:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-11-23T06:32:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2022-11-23T06:32:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-11-23T06:32:01+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-11-23T06:32:02+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2022-11-23T06:32:02+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-11-23T06:32:02+0100] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-11-23T06:32:02+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-11-23T06:32:02+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-11-23T06:32:02+0100] [ALPM-SCRIPTLET] ==> Creating xz-compressed initcpio image: /boot/initramfs-linux.img
[2022-11-23T06:32:08+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-11-23T06:32:08+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'fallback'
[2022-11-23T06:32:08+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-fallback.img -S autodetect
[2022-11-23T06:32:08+0100] [ALPM-SCRIPTLET] ==> Starting build: 6.0.9-arch1-1
[2022-11-23T06:32:08+0100] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-11-23T06:32:08+0100] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-11-23T06:32:09+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-11-23T06:32:09+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-11-23T06:32:09+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: aic94xx
[2022-11-23T06:32:09+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-11-23T06:32:09+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-11-23T06:32:09+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-11-23T06:32:09+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-11-23T06:32:09+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: wd719x
[2022-11-23T06:32:09+0100] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2022-11-23T06:32:10+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-11-23T06:32:10+0100] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-11-23T06:32:10+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-11-23T06:32:11+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-11-23T06:32:11+0100] [ALPM-SCRIPTLET] ==> Creating xz-compressed initcpio image: /boot/initramfs-linux-fallback.img
[2022-11-23T06:32:43+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-11-23T06:32:50+0100] [ALPM] running 'dbus-reload.hook'...
[2022-11-23T06:32:50+0100] [ALPM] running 'eos-reboot-required.hook'...
[2022-11-23T06:32:50+0100] [ALPM-SCRIPTLET] ==> INFO: Reboot is recommended due to the upgrade of core system package(s).
[2022-11-23T06:32:50+0100] [ALPM-SCRIPTLET] GDBus.Error:org.freedesktop.Notifications.Error.ExcessNotificationGeneration: Created too many similar notifications in quick succession
[2022-11-23T06:32:50+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-11-23T06:32:50+0100] [ALPM] running 'texinfo-install.hook'...
[2022-11-23T06:32:50+0100] [ALPM] running 'update-desktop-database.hook'...
[2022-11-23T06:33:00+0100] [PACMAN] Running 'pacman -S -y --config /etc/pacman.conf -- extra/intltool'
[2022-11-23T06:33:00+0100] [PACMAN] synchronizing package lists
[2022-11-23T06:33:03+0100] [ALPM] transaction started
[2022-11-23T06:33:03+0100] [ALPM] installed intltool (0.51.0-6)
[2022-11-23T06:33:03+0100] [ALPM] transaction completed
[2022-11-23T06:33:03+0100] [ALPM] running '30-systemd-update.hook'...
[2022-11-23T06:33:03+0100] [PACMAN] Running 'pacman -D -q --asdeps --config /etc/pacman.conf -- intltool'
[2022-11-23T06:33:07+0100] [PACMAN] Running 'pacman -U --noconfirm --config /etc/pacman.conf -- /home/dromundkaas/.cache/yay/python-keyboard/python-keyboard-0.13.5-1-any.pkg.tar.zst'
[2022-11-23T06:33:07+0100] [ALPM] transaction started
[2022-11-23T06:33:07+0100] [ALPM] installed python-keyboard (0.13.5-1)
[2022-11-23T06:33:07+0100] [ALPM] transaction completed
[2022-11-23T06:33:07+0100] [ALPM] running '30-systemd-update.hook'...
[2022-11-23T06:33:07+0100] [PACMAN] Running 'pacman -D -q --asdeps --noconfirm --config /etc/pacman.conf -- python-keyboard'
[2022-11-23T06:33:21+0100] [PACMAN] Running 'pacman -U --noconfirm --config /etc/pacman.conf -- /home/dromundkaas/.cache/yay/pince-git/pince-git-r1222.9db33c3-1-any.pkg.tar.zst'
[2022-11-23T06:33:21+0100] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-11-23T06:33:21+0100] [ALPM-SCRIPTLET] Using system disk as snapshot device for creating snapshots in BTRFS mode
[2022-11-23T06:33:21+0100] [ALPM-SCRIPTLET] Mounted '/dev/nvme0n1p2' at '/run/timeshift/47960/backup'
[2022-11-23T06:33:21+0100] [ALPM-SCRIPTLET] Creating new backup...(BTRFS)
[2022-11-23T06:33:21+0100] [ALPM-SCRIPTLET] Saving to device: /dev/nvme0n1p2, mounted at path: /run/timeshift/47960/backup
[2022-11-23T06:33:21+0100] [ALPM-SCRIPTLET] Created directory: /run/timeshift/47960/backup/timeshift-btrfs/snapshots/2022-11-23_06-33-21
[2022-11-23T06:33:26+0100] [ALPM-SCRIPTLET] Created subvolume snapshot: /run/timeshift/47960/backup/timeshift-btrfs/snapshots/2022-11-23_06-33-21/@
[2022-11-23T06:33:26+0100] [ALPM-SCRIPTLET] Created subvolume snapshot: /run/timeshift/47960/backup/timeshift-btrfs/snapshots/2022-11-23_06-33-21/@home
[2022-11-23T06:33:26+0100] [ALPM-SCRIPTLET] Created control file: /run/timeshift/47960/backup/timeshift-btrfs/snapshots/2022-11-23_06-33-21/info.json
[2022-11-23T06:33:26+0100] [ALPM-SCRIPTLET] BTRFS Snapshot saved successfully (4s)
[2022-11-23T06:33:26+0100] [ALPM-SCRIPTLET] Tagged snapshot '2022-11-23_06-33-21': ondemand
[2022-11-23T06:33:26+0100] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2022-11-23T06:33:26+0100] [ALPM-SCRIPTLET] Found stale mount for device '/dev/nvme0n1p2' at path '/run/timeshift/47960/backup'
[2022-11-23T06:33:26+0100] [ALPM-SCRIPTLET] Unmounted successfully
[2022-11-23T06:33:26+0100] [ALPM-SCRIPTLET] Mounted '/dev/nvme0n1p2' at '/run/timeshift/48212/backup'
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Removing snapshot: 2022-11-20_07-38-12
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Deleting subvolume: @home (Id:8890)
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Deleted subvolume: @home (Id:8890)
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Deleting subvolume: @ (Id:8889)
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Deleted subvolume: @ (Id:8889)
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Deleted directory: /run/timeshift/48212/backup/timeshift-btrfs/snapshots/2022-11-20_07-38-12
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Removed snapshot: 2022-11-20_07-38-12
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found stale mount for device '/dev/nvme0n1p2' at path '/run/timeshift/48212/backup'
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Unmounted successfully
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] GRUB-Konfigurationsdatei wird erstellt …
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Linux-Abbild gefunden: /boot/vmlinuz-linux
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] initrd-Abbild gefunden: /boot/amd-ucode.img /boot/initramfs-linux.img
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux-fallback.img
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Warnung: Zur Erkennung anderer bootfähiger Partitionen wird os-prober nicht ausgeführt.
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Die darauf befindlichen Systeme werden nicht zur GRUB-Bootkonfiguration hinzugefügt.
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Schauen Sie in den Dokumentationseintrag GRUB_DISABLE_OS_PROBER.
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Bootmenü-Eintrag für UEFI-Firmware-Einstellungen wird hinzugefügt …
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Detecting snapshots ...
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-23 06:33:21 | timeshift-btrfs/snapshots/2022-11-23_06-33-21/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-23 06:31:55 | timeshift-btrfs/snapshots/2022-11-23_06-31-55/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-22 22:00:01 | timeshift-btrfs/snapshots/2022-11-22_22-00-01/@ | daily | N/A |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-21 22:00:01 | timeshift-btrfs/snapshots/2022-11-21_22-00-01/@ | daily | N/A |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-20 22:00:01 | timeshift-btrfs/snapshots/2022-11-20_22-00-01/@ | daily | N/A |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-20 11:00:02 | timeshift-btrfs/snapshots/2022-11-20_11-00-02/@ | weekly | N/A |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-20 07:38:31 | timeshift-btrfs/snapshots/2022-11-20_07-38-31/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-19 22:00:01 | timeshift-btrfs/snapshots/2022-11-19_22-00-01/@ | daily | N/A |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-18 22:00:01 | timeshift-btrfs/snapshots/2022-11-18_22-00-01/@ | daily | N/A |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-11-13 11:00:01 | timeshift-btrfs/snapshots/2022-11-13_11-00-01/@ | weekly | N/A |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2022-10-27 17:00:01 | timeshift-btrfs/snapshots/2022-10-27_17-00-01/@ | monthly | N/A |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found snapshot: 2021-10-18 20:15:02 | timeshift-btrfs/snapshots/2022-08-07_14-39-16/@ | ondemand | Before restoring '2022-08-07 07:46:29' |
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Found 12 snapshot(s)
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] Unmount /tmp/grub-btrfs.zPw8psQ8JA .. Success
[2022-11-23T06:33:27+0100] [ALPM-SCRIPTLET] abgeschlossen
[2022-11-23T06:33:27+0100] [ALPM] transaction started
[2022-11-23T06:33:27+0100] [ALPM] upgraded pince-git (r1112.90142e0-1 -> r1222.9db33c3-1)
[2022-11-23T06:33:27+0100] [ALPM] transaction completed
[2022-11-23T06:33:27+0100] [ALPM] running '30-systemd-update.hook'...
[2022-11-23T06:33:28+0100] [PACMAN] Running 'pacman -R -u --noconfirm --config /etc/pacman.conf -- python-keyboard intltool'
[2022-11-23T06:33:28+0100] [ALPM] transaction started
[2022-11-23T06:33:28+0100] [ALPM] removed intltool (0.51.0-6)
[2022-11-23T06:33:28+0100] [ALPM] transaction completed
[2022-11-23T06:33:28+0100] [ALPM] running '30-systemd-update.hook'...
Nothing jumps out as a possible cause, but I’m not an expert in the linux graphics and display server.
