theo
September 5, 2021, 9:07am
#1
Whenever I start 0ad my laptop just reboots. I did post earlier and got frustrated. Sorry about that. Here is more info. Please help and let me know what else you guys need. Ps. When I run the game from command line the same happens.
Kernel: 5.13.13-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=e5318d21-2f3e-4c85-8f36-4da3e5717ca9 rw quiet loglevel=3
nowatchdog
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: LENOVO product: 20236 v: Lenovo G500 serial: <filter>
Chassis: type: 10 v: Lenovo G500 serial: <filter>
Mobo: LENOVO model: INVALID v: 31900004Std serial: <filter> UEFI: LENOVO
v: 78CN19WW(V1.07) date: 07/04/2013
Battery:
ID-1: BAT1 charge: 35.6 Wh (100.0%) condition: 35.6/40.4 Wh (88.1%)
volts: 12.0 min: 10.8 model: LENOVO PABAS0241231 type: Li-ion
serial: <filter> status: Full
Memory:
RAM: total: 7.63 GiB used: 1.82 GiB (23.9%)
RAM Report:
missing: Required tool dmidecode not installed. Check --recommends
Info: Dual Core model: Intel Core i3-3120M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB bogomips: 19962
Speed: 1285 MHz min/max: 1200/2500 MHz Core speeds (MHz): 1: 1285 2: 1878
3: 1647 4: 1348
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs lahf_lm
lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp
rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf
mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
IBRS_FW, STIBP: conditional, RSB filling
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Realtek Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 3-4:2
chip-ID: 0bda:5728 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: kwin_x11 driver:
loaded: intel unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Device-1: Qualcomm Atheros AR8162 Fast Ethernet vendor: Lenovo driver: alx
v: kernel port: 2000 bus-ID: 01:00.0 chip-ID: 1969:1090 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Lenovo driver: wl v: kernel
port: 2000 bus-ID: 02:00.0 chip-ID: 14e4:4365 class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: dynamic noprefixroute scope: global
IP v6: <filter> type: noprefixroute scope: link
WAN IP: <filter>
Bluetooth:
Device-1: Foxconn BCM43142A0 Bluetooth module type: USB driver: btusb v: 0.8
bus-ID: 1-1.3:4 chip-ID: 105b:e065 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: disabled
Logical:
Permissions: Unable to run lvs. Root privileges required.
RAID:
Message: No RAID data found.
Local Storage: total: 465.76 GiB used: 41 GiB (8.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPVT-24G33T1 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A02
scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DS8A9SH rev: EL3A
dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes
rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 34.33 GiB (35.1%)
fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: e5318d21-2f3e-4c85-8f36-4da3e5717ca9
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 4121-1DC1
ID-3: /home raw-size: 229.15 GiB size: 224.49 GiB (97.97%)
used: 6.67 GiB (3.0%) fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: 1b122c7a-021c-4ec5-b272-87d9c72f0566
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 6f65a16f-2413-40df-9e78-7f248cc8df0e
Unmounted:
ID-1: /dev/sda1 maj-min: 8:1 size: 99.49 GiB fs: <superuser required>
label: N/A uuid: 6828A96428A931CC
ID-2: /dev/sda13 maj-min: 8:13 size: 32 GiB fs: <superuser required>
label: N/A uuid: 85651370-f7ea-43a4-847d-a77bd24a4494
ID-3: /dev/sda2 maj-min: 8:2 size: 516 MiB fs: <superuser required>
label: N/A uuid: 4E78B74478B7299B
ID-4: /dev/sda3 maj-min: 8:3 size: 100 MiB fs: <superuser required>
label: N/A uuid: 52AE-8B20
ID-5: /dev/sda4 maj-min: 8:4 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
USB:
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:3 info: Maxxter Wireless Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 248a:8566 class-ID: 0301
Device-2: 1-1.3:4 info: Foxconn BCM43142A0 Bluetooth module type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 105b:e065
Device-3: 1-1.4:5 info: Realtek RTS5129 Card Reader Controller
type: <vendor specific> driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-4:2 info: Realtek Lenovo EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:5728
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 178 Uptime: 56m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1154 lib: 262 flatpak: 0
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.05```
onyxnz
September 5, 2021, 11:31am
#2
It would seem that for some reason mesa is not installed.
yay mesa
should help.
theo
September 5, 2021, 11:42am
#3
Hi onyxnz. Look at this lot. Which must I install?
63 aur/mesasdk 1:20.3.2-1 (+0 0.00)
Software development kit for use with the MESA stellar evolution code
62 aur/directx-headers 1.4.9-1 (+0 0.00)
DirectX headers for mesa-d3d12
61 aur/mingw-w64-mesa-git 21.1.0_devel.135801.23b87b56b6f-1 (+0 0.00)
An open-source implementation of the OpenGL specification (mingw-w64)
60 aur/mingw-w64-mesa 21.2.0-1 (+0 0.00)
59 aur/mesalink 1.0.0-1 (+0 0.00)
A memory-safe and OpenSSL-compatible TLS library
58 aur/dummy-opengl-driver-git 1-3 (+1 0.00)
Transactional package to build mesa-git against libglvnd
57 aur/mesa-d3d12 21.2.1-1 (+1 0.71)
Mesa with D3D12 Gallium backend
56 aur/mingw-w64-mesa-demos-git r6122.faaa319d-1 (+1 0.13)
Mesa demos and tools incl. glxinfo + glxgears (mingw-w64)
55 aur/lib32-glu-git 9.0.1-1 (+1 0.01)
Mesa OpenGL utility library (32 bits)
54 aur/mesa-demos-git 8.4.0-1 (+1 0.01)
53 aur/lib32-mesa-demos-git 8.4.0-1 (+1 0.01)
Mesa demos and tools (32-bit)
52 aur/mesa-minimal+-git 21.0.0_devel.133218.b634d7f3e2b-1 (+1 0.01)
an open-source implementation of the OpenGL specification, stripped down git version
51 aur/lib32-mesa-minimal+-git 21.0.0_devel.132039.6df572532dc-1 (+1 0.01)
an open-source implementation of the OpenGL specification, git version
50 aur/glu-git 9.0.1-1 (+1 0.01)
Mesa OpenGL Utility library
49 aur/lib32-vulkan-radeon-noglvnd 18.3.2-1 (+3 0.00)
Radeon's Vulkan mesa driver (32-bit) - non-libglvnd version
48 aur/lib32-vulkan-intel-noglvnd 18.3.2-1 (+3 0.00)
Intel's Vulkan mesa driver (32-bit) - non-libglvnd version
47 aur/lib32-mesa-libgl-noglvnd 18.3.2-1 (+3 0.00)
Mesa 3-D graphics library (32-bit) - non-libglvnd version
46 aur/lib32-mesa-noglvnd 18.3.2-1 (+3 0.00)
an open-source implementation of the OpenGL specification (32-bit) - non-libglvnd version
45 aur/lib32-libva-mesa-driver-noglvnd 18.3.2-1 (+3 0.00)
VA-API implementation for gallium (32-bit) - non-libglvnd version
44 aur/lib32-mesa-vdpau-noglvnd 18.3.2-1 (+3 0.00)
Mesa VDPAU drivers (32-bit) - non-libglvnd version
43 aur/lib32-mesa-minimal-git 21.3.0_devel.142889.bd9550b026e-1 (+4 0.04)
42 aur/eglut-git 8.2.0.5978.87a60bf-1 (+5 0.00)
The OpenGL Utility Toolkit for EGL. From mesa demos with Wayland backend.
41 aur/vulkan-intel-git 20.3.0_devel-1 (+5 0.00)
40 aur/mesa-minimal-git 21.2.0_devel.138224.f601fd635bb-1 (+5 0.05)
39 aur/libva-mesa-driver-noglvnd 18.3.2-1 (+6 0.00) (Out-of-date: 2020-04-11)
VA-API implementation for gallium - non-libglvnd version
38 aur/vulkan-intel-noglvnd 18.3.2-1 (+6 0.00) (Out-of-date: 2020-04-11)
Intel's Vulkan mesa driver - non-libglvnd version
37 aur/opencl-mesa-noglvnd 18.3.2-1 (+6 0.00) (Out-of-date: 2020-04-11)
OpenCL support for AMD/ATI Radeon mesa drivers - non-libglvnd version
36 aur/mesa-noglvnd 18.3.2-1 (+6 0.00) (Out-of-date: 2020-04-11)
an open-source implementation of the OpenGL specification - non-libglvnd version
35 aur/mesa-libgl-noglvnd 18.3.2-1 (+6 0.00) (Out-of-date: 2020-04-11)
Mesa 3-D graphics library - non-libglvnd version
34 aur/mesa-vdpau-noglvnd 18.3.2-1 (+6 0.00) (Out-of-date: 2020-04-11)
Mesa VDPAU drivers - non-libglvnd version
33 aur/vulkan-radeon-noglvnd 18.3.2-1 (+6 0.00) (Out-of-date: 2020-04-11)
Radeon's Vulkan mesa driver - non-libglvnd version
32 aur/lib32-mesa-git 21.3.0_devel.143549.688d11e4e82-1 (+40 0.04)
31 aur/glxgears 8.4.0-1 (+57 0.00)
GLX version of the gears GL demo. Standalone binary from the mesa-demos project.
30 aur/epsxe-plugin-gpu-mesagl 1.78-5 (+94 0.08)
Accelerated MesaGL plugin
29 aur/glxinfo 8.4.0-1 (+116 0.16)
Display info about a GLX extension and OpenGL renderer. Standalone binary from the mesa-demos project.
28 aur/mesa-git 21.2.0_devel.142376.c70f45c7596-1 (+166 1.04)
27 multilib/lib32-vulkan-radeon 21.2.1-1 (1.7 MiB 6.9 MiB)
26 multilib/lib32-vulkan-mesa-layers 21.2.1-1 (271.0 KiB 727.4 KiB)
Mesa's Vulkan layers (32-bit)
25 multilib/lib32-vulkan-intel 21.2.1-1 (2.2 MiB 9.3 MiB)
24 multilib/lib32-opencl-mesa 21.2.1-1 (7.6 MiB 53.3 MiB)
OpenCL support for AMD/ATI Radeon mesa drivers (32-bit)
23 multilib/lib32-mesa-vdpau 21.2.1-1 (3.2 MiB 11.1 MiB)
22 multilib/lib32-mesa-demos 8.4.0-2 (107.8 KiB 591.8 KiB)
21 multilib/lib32-mesa 21.2.1-1 (13.4 MiB 77.7 MiB)
An open-source implementation of the OpenGL specification (32-bit)
20 multilib/lib32-libva-mesa-driver 21.2.1-1 (3.0 MiB 10.7 MiB)
19 multilib/lib32-glu 9.0.1-1 (169.2 KiB 498.0 KiB)
18 community/unichrome-dri 7.11.2-11 (998.4 KiB 3.4 MiB)
Mesa DRI drivers for S3 Graphics/VIA Unichrome
17 community/tdfx-dri 7.11.2-11 (1009.7 KiB 3.4 MiB)
Mesa DRI drivers for 3dfx
16 community/sis-dri 7.11.2-11 (1001.9 KiB 3.4 MiB)
Mesa DRI drivers for SiS
15 community/savage-dri 7.11.2-11 (1008.1 KiB 3.4 MiB)
Mesa DRI drivers for S3 Sraphics/VIA Savage
14 community/r128-dri 7.11.2-11 (991.3 KiB 3.4 MiB)
Mesa DRI drivers for ATI Rage128
13 community/mga-dri 7.11.2-11 (1021.5 KiB 3.4 MiB)
Mesa DRI drivers for Matrox
12 community/mach64-dri 7.11.2-11 (1005.2 KiB 3.4 MiB)
Mesa DRI drivers for ATI Mach64
11 community/i810-dri 7.11.2-11 (1001.6 KiB 3.4 MiB)
Mesa DRI drivers for Intel i810
10 community/adriconf 2.4.1-2 (195.4 KiB 550.7 KiB)
GUI tool to configure Mesa drivers by setting options and writing them to the standard drirc file
9 extra/vulkan-radeon 21.2.1-1 (1.7 MiB 7.5 MiB)
8 extra/vulkan-mesa-layers 21.2.1-1 (267.0 KiB 679.7 KiB)
7 extra/vulkan-intel 21.2.1-1 (2.3 MiB 10.0 MiB)
6 extra/opencl-mesa 21.2.1-1 (8.5 MiB 58.9 MiB)
5 extra/mesa-vdpau 21.2.1-1 (3.1 MiB 11.5 MiB)
Mesa VDPAU drivers
4 extra/mesa-demos 8.4.0-4 (1.6 MiB 7.8 MiB)
3 extra/mesa 21.2.1-1 (16.9 MiB 100.2 MiB) (Installed)
2 extra/libva-mesa-driver 21.2.1-1 (3.0 MiB 11.2 MiB)
1 extra/glu 9.0.2-1 (142.5 KiB 354.8 KiB) (Installed)
==> Packages to install (eg: 1 2 3, 1-3 or ^4)```
theo
September 5, 2021, 3:01pm
#4
Ok. Thanks all. I solved the problem by just switching to the LTS kernel. Stupid me thought it would be best to have the latest kernel. Game works now.
ReemZ:
Angry frog
Well, yes. But there is no point in getting angry at the OP. He has already demonstrated bad manners and pissed all over our forum, so this little transgression is negligible in light of his previous sins.
Frankly, I’m more angry (or, more accurately, disappointed rather than angry) at other members who continue to engage with the OP.
theo
September 5, 2021, 7:54pm
#8
Like I said, sorry for my earlier bad manners while everyone was just trying to help. Thanks a million to everyone that tried.
onyxnz
September 5, 2021, 8:14pm
#9
That’s interesting, so does glxinfo work now?
pebcak
September 5, 2021, 8:19pm
#10
glxinfo
is a standalone binary provided by mesa-demos.
It’s not required by mesa
onyxnz
September 5, 2021, 8:20pm
#11
Thanks mate. Consider me edumicated.
pebcak
September 5, 2021, 8:25pm
#12
onyxnz:
edumicated.
You got me on that. Had to look it up! So we are even.
onyxnz
September 5, 2021, 8:30pm
#13
onyxnz:
edumicated
And actually, I SHOULD NOT do that; it’s rather cruel for an international audience where English is a second language.
So folks, to explain:
edumacate (third-person singular simple present edumacates , present participle edumacating , simple past and past participle edumacated )
(humorous ) Deliberate misspelling of educate .
I have a terrible habit of butchering my own language for the sake of brevity (humour).
ReemZ
September 5, 2021, 9:45pm
#14
As a non-native speaker, I find humour one of the best tools in learning
Also, if $reader can’t figure out how to use a search engine, well…
system
closed
September 7, 2021, 9:46pm
#15
