Kernel: 5.17.1-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: sway v: 1.8-dev-8f036b6f Distro: EndeavourOS base: Arch Linux
Type: Laptop System: LENOVO product: 82JY v: Legion 5 17ACH6H
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
UEFI: LENOVO v: GKCN44WW date: 08/30/2021
Battery:
ID-1: BAT0 charge: 80.3 Wh (95.0%) condition: 84.5/80.0 Wh (105.7%)
volts: 17.3 min: 15.4 model: Celxpert L20C4PC2 status: full
Memory:
RAM: total: 13.57 GiB used: 4.61 GiB (34.0%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM 0 size: 8 GiB speed: 3200 MT/s type: DDR4
Device-2: DIMM 0 size: 8 GiB speed: 3200 MT/s type: DDR4
Info: 8-core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 1450 high: 3200 min/max: 1200/4462 boost: enabled
cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200
9: 1200 10: 1200 11: 1200 12: 3200 13: 3200 14: 1200 15: 1200 16: 1200
bogomips: 102240
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 510.60.02 bus-ID: 01:00.0
Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 06:00.0
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
Display: server: X.org v: 1.21.1.3 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting gpu: amdgpu resolution: 1920x1080
Message: GL data unavailable for root.
Device-1: NVIDIA GA104 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: N/A bus-ID: 06:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 06:00.6
Sound Server-1: ALSA v: k5.17.1-arch1-1 running: yes
Sound Server-2: sndio v: N/A running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_pci v: kernel port: 2000 bus-ID: 04:00.0
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 2.29 TiB used: 94.83 GiB (4.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZALQ512HBLU-00BL2
size: 476.94 GiB temp: 23.9 C
ID-2: /dev/nvme1n1 vendor: Crucial model: CT2000P2SSD8 size: 1.82 TiB
temp: 26.9 C
ID-1: / size: 1.81 TiB used: 94.83 GiB (5.1%) fs: btrfs dev: /dev/nvme1n1p2
ID-2: /boot/efi size: 299.4 MiB used: 580 KiB (0.2%) fs: vfat
dev: /dev/nvme1n1p1
ID-3: /home size: 1.81 TiB used: 94.83 GiB (5.1%) fs: btrfs
dev: /dev/nvme1n1p2
ID-4: /var/log size: 1.81 TiB used: 94.83 GiB (5.1%) fs: btrfs
dev: /dev/nvme1n1p2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme1n1p3
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): N/A
Processes: 404 Uptime: 11m Init: systemd Compilers: gcc: 11.2.0
clang: 13.0.1 Packages: 1439 Shell: Zsh v: 5.8.1 inxi: 3.3.14
[2022-03-29T22:44:37+0100] [ALPM] upgraded linux-zen (5.16.16.zen1-1 -> 5.17.1.zen1-1)
[2022-03-29T22:44:38+0100] [ALPM] upgraded linux-zen-headers (5.16.16.zen1-1 -> 5.17.1.zen1-1)
*The above reflects me rebooting to normal kernel.
Don’t think it is a zen problem as it has only happened over the last couple of days. Any ideas?
Seems OK on normal kernel, but will know better when I get home from work.
