Check if there still is a difference between Tctl and Tdie with PBO disabled. Check if with PBO enabled, there is a difference. It might be a false positive because Tctl could be 10° lower because it now reports the same value as Tdie. Tctl on Ryzen is not a valid way of measuring temperature due to the artificial increase on code-level to increase the effect of PBO.
Yes, but your initial post here:
you did not specify that you are doing chipset undervolting, but reported your findings as if they were done while CPU-undervolting. You are doing something else then is expected in this topic - it is good what you are doing, but you should make it clear that you are doing something else.
When I compare Tctl with Tccd1/2 I can see that all three are more or less equal. During the mprime load testing they are basically the same. No big difference. Tccd2 is max 5 °C lower that the other two.
