Last night i try to remove orhan files with the command
sudo pacman -Rns $(pacman -Qtd But this also it removes the YAY as orphan and i reinstalled it again. Is this something normal or i use wrong the command?
-Qdt does nothinh normal -Qdtq does
imayby you removed something that was depended on yay since thats gone it became orphan, it sounds like that. -Rns is much saver then -Rnsc , cascade options way more and more riskfulll then )-rns
Sorry i wrote it wrong -Qdtq i use
Better to check first what that part of the command shows, before uninstalling it blindly…
Although everyone thinks that yay is pacman, in himself he is not, now well; Before cascading pacman command, first use the yay commands:
yay -Yc
and them
yay -Ps
Edit: my answer does not have much to do with the OP’s question, but still it never hurts, I leave it.
I did that. I am just curious why it show it as orphan. And what is the proper way to remove orphan
I would check orphans one by one. And if I’m absolutely sure I don’t need a particular package anymore, then I’d uninstall the package.
It is too easy to simply uninstall a bunch of packages. It can make your system either not working properly, or not booting at all.
All in all, I would not uninstall packages from a (newly) installed system unless there is a compelling reason to do so. Disks nowadays are very large, and a few gigabytes of unused apps is no big deal.
Sorry about this rant here, please don’t take it personal. I just (too) often see users wanting to uninstall many packages for no real reason.
Now i get it. Dont apologize. I must thank you for your answer!!!
