When I hit Ctrl+Button(1/2/3) the xterm window gets closed the same way as if I just hit Ctrl+d. The expected behavior would be to bring a pop-up menu with settings, different one for each mouse button pressed. It is not my dwm settings (I’m almost sure) as only xterm windows are concerned (no other apps) and I have nothing like that defined on mouse button click anyway. I am really lost as to what can be causing this behavior, because I already used this dwm config with the same xterm config and everything was normal.
I am not sure what information may be relevant to the issue, so here’s my xterm related settings from my .Xresources:
! XTERM
! set correct TERM env var
XTerm.termName: xterm-256color
! follow the locale
XTerm.vt100.locale: true
! Alt sends '^[' (escape) key
XTerm.vt100.metaSendsEscape: true
! save more scrolled off lines
XTerm.vt100.saveLines: 2048
! enable TrueFont by default
XTerm.vt100.renderFont: true
! fonts
XTerm.vt100.faceName: monospace:size=10:antialias=true
XTerm.vt100.font: 7x13
! colors
XTerm.vt100.foreground: white
XTerm.vt100.background: black
My dwm mouse related part of the config.h (I left this part at default):
/* button definitions */
/* click can be ClkTagBar, ClkLtSymbol, ClkStatusText, ClkWinTitle, ClkClientWin, or ClkRootWin */
static Button buttons[] = {
/* click event mask button function argument */
{ ClkLtSymbol, 0, Button1, setlayout, {0} },
{ ClkLtSymbol, 0, Button3, setlayout, {.v = &layouts[2]} },
{ ClkWinTitle, 0, Button2, zoom, {0} },
{ ClkStatusText, 0, Button2, spawn, {.v = termcmd } },
{ ClkClientWin, MODKEY, Button1, movemouse, {0} },
{ ClkClientWin, MODKEY, Button2, togglefloating, {0} },
{ ClkClientWin, MODKEY, Button3, resizemouse, {0} },
{ ClkTagBar, 0, Button1, view, {0} },
{ ClkTagBar, 0, Button3, toggleview, {0} },
{ ClkTagBar, MODKEY, Button1, tag, {0} },
{ ClkTagBar, MODKEY, Button3, toggletag, {0} },
And my libinput settings, in case it’s relevant (I am using touchpad):
Section "InputClass"
Identifier "devname"
Driver "libinput"
Option "AccelProfile" "adaptive"
Option "AccelSpeed" "0.8"
Option "DisableWhileTyping" "true"
Option "HorizontalScrolling" "true"
Option "MiddleEmulation" "true"
EndSection
