Hi Ive just installed the latest from EndeavourOS_Artemis_nova_22_9.iso, and at the same time replaced my Nvidia card with a Radeon RX6500XT card, and a new monitor so I can 3840x2160 resolution.
I immediately restored all my configs from backup, and Im running XFCE with bspwm. Everything works great… except the performance is terrible now, Xorg seems to be running at 90%+ constantly.
Im not sure what info is relevant, but here’s some info:
Below is the output… but I think I might have solved it, after a re-install. Im think there is a problem with my previous picom.conf that doesn’t work well with this new video card. I put a default conf in place and Im getting much better performance and Xorg is back to like 1% while streaming youtube
[ 1796.470] Current Operating System: Linux FHP011VELO 5.19.10-arch1-1 #1 SMP PREEMPT_DYNAMIC Tue, 20 Sep 2022 15:17:59 +0000 x86_64
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 1796.470] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 1796.470] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 1796.470] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 1796.470] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 1796.470] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 1796.470] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 1796.503] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 1796.535] (WW) Warning, couldn't open module fbdev
[ 1796.535] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 1796.535] (WW) Warning, couldn't open module vesa
[ 1796.535] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 1796.536] (WW) Falling back to old probe method for modesetting
[ 1796.585] (II) Initializing extension MIT-SCREEN-SAVER
[ 1796.860] (EE) libinput: PixArt USB Optical Mouse: Failed to create a device for /dev/input/mouse0
[ 1796.860] (EE) PreInit returned 2 for "PixArt USB Optical Mouse"
[ 1796.894] (EE) libinput: HDA ATI HDMI HDMI/DP,pcm=3: Failed to create a device for /dev/input/event3
[ 1796.894] (EE) PreInit returned 2 for "HDA ATI HDMI HDMI/DP,pcm=3"
[ 1796.927] (EE) libinput: HDA ATI HDMI HDMI/DP,pcm=7: Failed to create a device for /dev/input/event4
[ 1796.927] (EE) PreInit returned 2 for "HDA ATI HDMI HDMI/DP,pcm=7"
[ 1796.960] (EE) libinput: HD-Audio Generic Front Headphone: Failed to create a device for /dev/input/event10
[ 1796.960] (EE) PreInit returned 2 for "HD-Audio Generic Front Headphone"
[ 1797.004] (EE) libinput: HD-Audio Generic Front Mic: Failed to create a device for /dev/input/event6
[ 1797.004] (EE) PreInit returned 2 for "HD-Audio Generic Front Mic"
[ 1797.037] (EE) libinput: HD-Audio Generic Rear Mic: Failed to create a device for /dev/input/event7
[ 1797.037] (EE) PreInit returned 2 for "HD-Audio Generic Rear Mic"
[ 1797.070] (EE) libinput: HD-Audio Generic Line: Failed to create a device for /dev/input/event8
[ 1797.070] (EE) PreInit returned 2 for "HD-Audio Generic Line"
[ 1797.104] (EE) libinput: HD-Audio Generic Line Out: Failed to create a device for /dev/input/event9
[ 1797.104] (EE) PreInit returned 2 for "HD-Audio Generic Line Out"
[ 1797.174] (EE) libinput: PC Speaker: Failed to create a device for /dev/input/event2
[ 1797.174] (EE) PreInit returned 2 for "PC Speaker"
