Xfce temrinal color scheme to terminator terminal?
i was wondering how i would get the xfce terminal color scheme imported into terminator terminal? i don’t even know if this possible or if there is a quick and easy way to do this? i like terminator more but i can’t get away from the delicious colors that the endeavor os team setup for the xfce terminal
There is only between 24 and 30 colours that are defined, so you can manually copy each one. Just write them down somewhere. I think that’s easier than figuring out an automatic way to import/export them.
thank you Kresimir
