hi, not been here for a while but just set up a new rig using XFCE…when I go into ‘About XFCE’ I get:
GPU AMD Renoir (512,0 MB)
How come my old 200GE CPU was using this?
GPU AMD Radeon (2,0 GiB)
you can also see
with terminal
inxi -Fza
Kernel: 5.17.7-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=dac6b410-75eb-4b96-a065-47c738bb3e1e rw quiet loglevel=3
nowatchdog
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: EndeavourOS base: Arch Linux
Type: Desktop System: Gigabyte product: B450M S2H V2 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450M S2H V2 serial: <superuser required>
UEFI: American Megatrends LLC. v: F62 date: 01/26/2022
Battery:
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2491 high: 2993 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2993 2: 2396
3: 2395 4: 2990 5: 2395 6: 2395 7: 2689 8: 2059 9: 2395 10: 2395 11: 2395
12: 2395 bogomips: 93466
Vulnerabilities:
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Gigabyte driver: amdgpu v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 09:00.0 chip-ID: 1002:1638
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu unloaded: fbdev,modesetting,vesa gpu: amdgpu
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: right model: Acer K242HL
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: Viseo243D
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.17.7-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.51 running: no
vendor: Gigabyte driver: r8168 v: 8.050.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 519.8 GiB used: 65.42 GiB (12.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Lenovo model: SSD SL700 240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6A scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Emtec model: X250 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0A0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 57.75 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
ID-1: / raw-size: 238.37 GiB size: 233.57 GiB (97.99%)
used: 65.42 GiB (28.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.42%)
used: 282 KiB (0.3%) fs: vfat dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 43.0 C mobo: 27.0 C gpu: amdgpu temp: 30.0 C
Fan Speeds (RPM): N/A
Processes: 295 Uptime: 12m wakeups: 2 Memory: 15 GiB used: 2.34 GiB (15.6%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 12.1.0 Packages:
pacman: 929 lib: 301 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.15
