Xed is not working with pkexec
I tried to add a custom action on Thunar based on the XFCE docs and specifically “Edit file as root”. I followed the tutorial and added this in the custom action: pkexec xed %f, but nothing showed up when I ran it. I tested it with another file using the same command on the terminal and here’s the output:
[rapta@endeavour ~]$ pkexec xed $HOME/Documents/scripts/test.sh
(xed:7072): Gtk-WARNING **: 18:14:41.143: cannot open display:
Using sudo did work, but with sudo the notification doesn’t pop up and I can’t type my password, making it useless. I made another custom action with pkexec too (Open Thunar as root) which does work. Is it fixable?
Try mousepad.
pkexec mousepad works for me.
I get the same output as yours with pkexec xed.
For security reasons it is recommended to avoid running GUI stuff as root.
A better approach is to use e.g. nano or another non-GUI editor.
Another question is why do you need to edit the files at your $HOME as root?
xed admin:///etc/fstab
should work :slight_smile:
answer should be around here
https://forums.linuxmint.com/viewtopic.php?p=1850810&sid=d8a9365d19f10f67a75f563dc114fa9c#p1850810
As xed admin;//%f should do
It was an example
Doesn’t seem to work…
I replaced xed with mousepad and it works, thanks!
sidenote the ; did the wrong
xed admin://%f
should work :slight_smile: no pkexec needed
Also please have a read here to know the security implications of running a GUI application as root:
https://wiki.archlinux.org/title/Running_GUI_applications_as_root
I am aware of the possible consequences, I use this function rarely and only when needed.
