Loaded latest .iso release on ventoy usb. The live environment starts out to load fine but when it starts to load the x11 to build the window, the service fails and goes into a loop and can only force a reboot. I know Arch will run without issue on this system. This is current config:
inxi -Fxxxz
Kernel: 5.18.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Distro: Manjaro Linux base: Arch Linux
Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4201
date: 04/26/2022
Info: 16-core model: AMD Ryzen 9 5950X bits: 64 type: MT MCP smt: enabled
arch: Zen 3 rev: 0 cache: L1: 1024 KiB L2: 8 MiB L3: 64 MiB
Speed (MHz): avg: 3467 high: 4299 min/max: 2200/5083 boost: enabled
cores: 1: 3593 2: 3611 3: 2875 4: 3974 5: 3782 6: 3284 7: 3463 8: 3281
9: 2919 10: 3424 11: 3489 12: 2988 13: 3507 14: 4299 15: 2903 16: 4295
17: 3639 18: 3652 19: 3491 20: 4014 21: 3067 22: 3268 23: 2987 24: 3152
25: 3078 26: 3625 27: 2956 28: 3314 29: 3728 30: 3602 31: 4057 32: 3658
bogomips: 217288
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M]
vendor: Tul / PowerColor Red Devil driver: amdgpu v: kernel arch: RDNA 2
pcie: speed: 16 GT/s lanes: 16 ports: active: DP-1, DP-2, DP-3, HDMI-A-1
empty: none bus-ID: 0d:00.0 chip-ID: 1002:73ff class-ID: 0300
Device-2: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: eVga.com.
driver: N/A arch: Ampere pcie: speed: 16 GT/s lanes: 8 bus-ID: 0e:00.0
chip-ID: 10de:2482 class-ID: 0300
Device-3: Elgato Systems GmbH Cam Link 4K type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-3:2
chip-ID: 0fd9:0066 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3862x4680 s-dpi: 96 s-size: 1020x1237mm (40.16x48.70")
s-diag: 1603mm (63.12")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: 3-1 model: VG278
serial: <filter> res: 1920x1080 dpi: 82 size: 598x336mm (23.54x13.23")
diag: 686mm (27") modes: max: 1920x1080 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: primary,1-4
model: LG (GoldStar) Ultra HD serial: <filter> res: 3840x2160 hz: 60
dpi: 163 size: 600x340mm (23.62x13.39") diag: 690mm (27.2") modes:
max: 3840x2160 min: 640x480
Monitor-3: DP-3 mapped: DisplayPort-2 pos: 2-3 model: Acer EI342CKR
serial: <filter> res: 3440x1440 dpi: 110 size: 797x334mm (31.38x13.15")
diag: 864mm (34") modes: max: 3440x1440 min: 720x400
Monitor-4: HDMI-A-1 mapped: HDMI-A-0 pos: 3-2 model: VG278
OpenGL: renderer: AMD Radeon RX 6600 XT (dimgrey_cavefish LLVM 13.0.1 DRM
3.46 5.18.6-1-MANJARO)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 2-3:2 pcie: chip-ID: 0fd9:0066 speed: 16 GT/s lanes: 16
class-ID: 0102 bus-ID: 0d:00.1 serial: <filter> chip-ID: 1002:ab28
class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 8
bus-ID: 0e:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 10:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Elgato Systems GmbH Cam Link 4K type: USB
Sound Server-1: ALSA v: k5.18.6-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 16.1 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8125
class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0
chip-ID: 8086:1539 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: N/A pcie: speed: 5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr1 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 49.2 TiB used: 1016.38 GiB (2.0%)
ID-1: /dev/nvme0n1 vendor: Sabrent model: Rocket 4.0 2TB size: 1.82 TiB
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT401.3
temp: 53.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Sabrent model: Rocket 4.0 2TB size: 1.82 TiB
temp: 55.9 C scheme: GPT
ID-3: /dev/sda vendor: Western Digital model: WDS500G2B0A-00SM50
size: 465.76 GiB speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
scheme: GPT
ID-4: /dev/sdb vendor: Western Digital model: WDS500G2B0A-00SM50
scheme: GPT
ID-5: /dev/sdc vendor: HGST (Hitachi) model: HUH721212ALE600
size: 10.91 TiB speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: T925 scheme: GPT
ID-6: /dev/sdd vendor: HGST (Hitachi) model: HUH721212ALE600
ID-7: /dev/sde type: USB model: SSK SSK Storage size: 931.51 GiB
type: N/A serial: <filter> rev: 0212 scheme: GPT
ID-8: /dev/sdf type: USB vendor: Seagate model: Backup+ Desk
size: 7.28 TiB type: N/A serial: <filter> rev: 040B scheme: GPT
ID-9: /dev/sdg type: USB vendor: SMI (STMicroelectronics) model: USB
size: 58.59 GiB type: N/A serial: <filter> rev: 1100 scheme: MBR
ID-10: /dev/sdh type: USB model: Specific STORAGE DEVICE size: 29.3 GiB
type: N/A serial: <filter> rev: 0009 scheme: MBR
ID-11: /dev/sdi model: FILEIO size: 4.55 TiB type: N/A serial: N/A
rev: 4.0 scheme: GPT
ID-12: /dev/sdj model: FILEIO size: 2.73 TiB type: N/A serial: N/A
ID-13: /dev/sdk model: FILEIO size: 7.28 TiB type: N/A serial: N/A
ID-1: / size: 1.82 TiB used: 1016.38 GiB (54.6%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 568 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 1.82 TiB used: 1016.38 GiB (54.6%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 1.82 TiB used: 1016.38 GiB (54.6%) fs: btrfs
dev: /dev/nvme0n1p2
System Temperatures: cpu: 55.0 C mobo: 44.0 C gpu: amdgpu temp: 56.0 C
mem: 56.0 C
Fan Speeds (RPM): cpu: 0 gpu: amdgpu fan: 0
Processes: 599 Uptime: 37m wakeups: 0 Memory: 125.71 GiB
used: 9.18 GiB (7.3%) Init: systemd v: 251 default: graphical Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1566 pacman: 1519 flatpak: 21 snap: 26
Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.19
Any ideas or thoughts would be helpful…
