Hello,
after last update I made reboot.
Now my monitor shows 1600x900 instead 3400x1440 ::
And I can’t choose another resolution.
Any help is welcome
Thank you in advance!
Here is an Info about my System:
xrandr
Screen 0: minimum 320 x 200, current 1600 x 900, maximum 16384 x 16384
DisplayPort-0 connected 1600x900+0+0 (normal left inverted right x axis y axis) 800mm x 335mm
1600x900 60.00*
1280x1024 60.02
1280x800 59.81
1152x864 59.97
1280x720 60.00 50.00 59.94
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 60.00 59.94
640x480 60.00 59.94
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
HDMI-A-1 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
lspci -nn | grep -E ‘VGA|Display’
03:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 10 XL/XT [Radeon RX Vega
56/64] [1002:687f] (rev c3)
