┬─[ramon@ramon-m61pmes2p:~]─[17:33:19]
╰─>$ inxi -Gza 0 < 17:33:19
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Gigabyte driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 92 s-size: 442x251mm (17.40x9.88")
s-diag: 508mm (20.01")
Monitor-1: HDMI-0 res: 1600x900 hz: 60 dpi: 92
size: 443x249mm (17.44x9.8") diag: 508mm (20.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
1050/PCIe/SSE2 direct render: Yes
┬─[ramon@ramon-m61pmes2p:~]─[17:34:10]
╰─>$ lspci -vnn | grep -PA11 '3D|VGA|Display' 0 < 17:34:10
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107 [GeForce GTX 1050] [10de:1c81] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Gigabyte Technology Co., Ltd Device [1458:372e]
Flags: bus master, fast devsel, latency 0, IRQ 30, NUMA node 0
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
Memory at ce000000 (64-bit, prefetchable) [size=32M]
I/O ports at bc00 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
┬─[ramon@ramon-m61pmes2p:~]─[17:35:02]
╰─>$ lsmod | grep nvidia 0 < 17:35:02
nvidia_drm 73728 21
nvidia_modeset 1503232 42 nvidia_drm
nvidia_uvm 2904064 0
nvidia 61218816 2409 nvidia_uvm,nvidia_modeset
manuel
22
Looks like nvidia driver is in use.
system
Closed
23
