Just did an uneventful update using yay.
Rebooted:
Loading Linux linux-lts
Loading initial ramdisk
That’s it.
Trying to boot my snapshots doesn’t work either. The log says it can’t mount root.
A couple of excerpts (ocred from photos of the screen):
[FAILEDI
Failed to start Remount Root and Kernel File Systems.
See
systemctl
status systend-remount-fs.service' for details.
Jul 24 20:09:15 beast systemd-remount-fs[1128]: /usr/bin/mount for / exited
with exit status 32.
Jul 24 20:09:16 beast systemd-remount-fs[1134]: mount: /: fsconfig system call failed: overlay: No changes allowed in reconfigure.
dmesg(1) may have more information after failed mount system call.
Jul 24 20:09:15 beast systemd[1]: modprobe@configfs.service: Deactivated
successfully.
It stops and allows to to enter maintenance mode, or continue booting. I entered the admin password, and was able to mount the root partition to /mnt/root and list files.
Not sure where to go from here.
Thanks.
Yes, it also hangs at Loading initial ramdisk, as does the non-lts kernel.
It seems anything touched by the update hangs, and all snapshots fail to mount root (though I haven’t tried really old snapshots, which I might do now).
Ran btrfs check on the root partition, no errors found.
Booted a usb and created the chroot environment, did yay, a few packages were updated, including the lts kernel. No errors. Rebooted, and it failed to mount root again.
Follow up question:I always have a little doubt about where to mount the efi partition. I have both /efi and /boot/efi. I used /boot/efi when I chrooted (actually /mnt/boot/efi since the root partition was mounted at /mnt).
I’m doing a ddrescue backup of this drive as-is, since my home folder is on it too.
It feels like I might have to reinstall, which makes me sad, as having both Intel Arc and Nvidia GPUs can make things interesting.
[root@EndeavourOS ~]# parted -l
Model: ATA WDC WD161KRYZ-01 (scsi)
Disk /dev/sda: 16.0TB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 16.0TB 16.0TB zfs-8a3a445d8e242a23
9 16.0TB 16.0TB 8389kB
Disk /dev/sdb: 16.0TB
Disk Flags:
1 1049kB 16.0TB 16.0TB zfs-58faff62f6271cff
Disk /dev/sdc: 16.0TB
Disk Flags:
1 1049kB 16.0TB 16.0TB zfs-78639b568f55ee69
Disk /dev/sdd: 16.0TB
Disk Flags:
1 1049kB 16.0TB 16.0TB zfs-d0b33e53166bed1e
Model: Sabrent (scsi)
Disk /dev/sde: 1000GB
Sector size (logical/physical): 512B/2048B
Disk Flags:
1 1049kB 1000GB 1000GB btrfs
Model: CT2000P5PSSD8 (nvme)
Disk /dev/nvme0n1: 2000GB
Sector size (logical/physical): 512B/512B
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 2000GB 2000GB btrfs
Disk /dev/nvme2n1: 2000GB
Disk Flags:
Model: PNY USB 3.2.1 FD (scsi)
Disk /dev/sdg: 31.0GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2595MB 2760MB 165MB primary fat16 esp
The EOS drive:
Disk /dev/nvme1n1: 2000GB
Disk Flags:
1 1049kB 538MB 537MB fat32 boot, esp
2 538MB 385GB 384GB btrfs endeavouros
4 385GB 2000GB 1616GB btrfs
