Wireless mouse won't work sometimes on boot
Hi all,
As the title says. Sometimes it works and sometimes it doesn’t. I am on KDE 6.0.5, kernel 6.6LTS
Mouse is Logitech G305. From all of my USB devices this is the only one that has an attitude problem.
If I replug the receiver, then it works fine.
I also tried sudo reinstall-kernels, updated system , but nothing.
which Motherboard are you using? Are there some settings?
ASUS Prime X570-P. The only setting on my bios that I have changed was disable secure boot.
I am using a gigabyte, i have some settings in for usb or keyboard. Gonna check in BIOS
A mouse who
I love it!!
