Hi, I’m running EndeavourOS KDE with KDE Plasma Version 5.22.3, KDE Frameworks Version 5.84.0 and Qt Version 5.15.2.
System info
Kernel: 5.10.52-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
root=UUID=1ade638b-2046-4deb-abf6-5d158ba55143 rw quiet loglevel=3
nowatchdog
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 14-bw0xx v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 8324 v: 22.27 serial: <filter> UEFI: AMI v: F.28
date: 04/09/2019
Battery:
ID-1: BAT0 charge: 28.0 Wh (100.0%) condition: 28.0/28.0 Wh (100.0%)
volts: 16.6 min: 14.6 model: HP Primary type: Li-ion serial: N/A
status: Full cycles: 252
Info: Dual Core model: AMD E2-9000e RADEON R2 4 COMPUTE CORES 2C+2G bits: 64
type: MCP arch: Excavator family: 15 (21) model-id: 70 (112) stepping: 0
microcode: 6006705 cache: L2: 1024 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 5989
Speed: 1096 MHz min/max: 1100/1500 MHz boost: enabled Core speeds (MHz):
1: 1096 2: 1096
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Sunplus Innovation HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 1-1.3:3 chip-ID: 1bcf:2c9b class-ID: 0e02
Display: x11 server: X.org 1.20.12 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.10.52-1-lts running: yes
Sound Server-2: JACK v: 0.125.0 running: no
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.32 running: yes
vendor: Hewlett-Packard driver: N/A modules: r8169 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 8086:24fb class-ID: 0280
Bluetooth:
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:4 chip-ID: 8087:0aa7 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 201.26 GiB (43.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPCX-60VHAT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01
scheme: GPT
ID-1: / raw-size: 32 GiB size: 31.2 GiB (97.50%) used: 17.19 GiB (55.1%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 89 MiB (34.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 200.54 GiB size: 196.89 GiB (98.18%)
used: 79.29 GiB (40.3%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 2 GiB used: 79.3 MiB (3.9%) priority: -2
file: /swapfile
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): N/A
Processes: 169 Uptime: 6h 28m wakeups: 3 Memory: 3.28 GiB
used: 1.7 GiB (51.7%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1214 pacman: 1207 lib: 257 flatpak: 7 Shell: Bash
v: 5.1.8 running-in: yakuake inxi: 3.3.05
Issue:
2 programs I use are Nethack-qt and OSM Scout Server, installed via yay & flatpak, respectively. Yesterday, when I closed OSM Scout Server, the program itself closed, but the window stuck to the screen. KSysGuard showed no sign of the program either. I didn’t try to reproduce it, but left it for next weekend. Today, I was playing Nethack-qt and it showed the same behaviour.
Observed behaviour:
Cannot remove this zombie window shadow without killing Xorg. It doesn’t appear on other virtual desktops though.
Expected behaviour:
The window shouldn’t exist like this in the first place
It should be gone after showing me my result
What I’ve tried:
kquitapp5 plasmashell && kstart5 plasmashell
- kill Xorg (only workaround atm, though it kills my other apps)
- searched google, but nothing remotely related to this issue
How do I get rid of this zombie window? And how do I prevent this from occurring in the future?
