I just bought this WiFi 6E card from Amazon but I seem to be missing the little USB header cable. will i need it for the card to work? TIA
From reading the information, it looks like the USB provides the BT functionality. So if you need BT, it may not work without the cable. I would try it out and see if it works for you.
OK
OK, thanks I’ll try it but I’ll be very careful so I can return for a full kit.
I would return it for a full kit anyway.
