Hi, since my pc does not have an internal wifi adapter, I connected one via usb. This works great for the most part, wifi is usually stable and fast.
That is until I connect an external storage (usb stick or hard disk) to another usb 3 port and start to copy over some data (for example make a backup).
While the data is copying to the external disk, my wifi speed gets slower and slower, reaching a point after about 30 - 80 seconds I guess where it basically dropped to 0 kb/s. No packages come through, so while the system often shows I’m still connected to the wifi, I don’t have a working internet connection anymore. Sometimes the wifi even automatically disconnects. If I try to reconnect it fails.
After my data copy has finished to my external disk, things are starting getting normal again. I can reconnect to my wifi. If not, it works again after re-pluggin my wifi adapter or unmounting the external disk.
This is very frustrating because I can’t have an internet connection while I copy over some data to external USB devices.
The devices themself don’t matter. I tried different usb wifi adapters (my main one is a tp-link ac 600 (dualchannel), but same problem is with a logilink 2.4 GHz only one).
The external storage device also doesn’t matter. The problem happens when I copy data over to my external backup HDD, but also with any other usb stick. Also filesystems do not make any difference, had usb sticks with ext4, ntfs, fat32… all causing the same problem.
However USB ports do matter. At least the version. As long as everything is on an usb 3 port, the problem always occur, no matter what device is connected on which port.
But things making a difference if I connect my external storage device to a usb 2 port.
When I do this, it seems to have much less impact on wifi.
When external storage is on usb 2, my wifi connections sees some drop downs in speed, some more than usual, but I still have a working internet connection. Only when the external storage is connected to an usb 3 port the wifi completely stops working.
System Information:
inxi -Fxzc0
System: Kernel: 5.10.16-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: KDE Plasma 5.20.5
Machine: Type: Desktop Mobo: MSI model: Z170-A PRO (MS-7971) v: 1.0 serial: <filter> UEFI: American Megatrends
v: 1.K0 date: 07/10/2018
CPU: Info: Quad Core model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake rev: 9
L2 cache: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57616
Speed: 800 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
7: 800 8: 800
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nvidia v: 460.39
bus ID: 01:00.0
Display: x11 server: X.org 1.20.10 driver: loaded: nvidia unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 00:1f.3
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Device-3: RODE Microphones RODE NT-USB type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-11:5
Sound Server: ALSA v: k5.10.16-arch1-1
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8168
v: 8.048.03-NAPI port: d000 bus ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-2: Ralink MT7610U (Archer T2U 2.4G+5G WLAN Adapter type: USB driver: mt76x0u bus ID: 1-12:18
Drives: Local Storage: total: 1.19 TiB used: 583.4 GiB (47.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB temp: 28.9 C
ID-2: /dev/sda vendor: Samsung model: SSD 840 EVO 250GB size: 232.89 GiB
ID-3: /dev/sdb vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
Partition: ***
Swap: ID-1: swap-1 type: file size: 4 GiB used: 256 KiB (0.0%) file: /swapfile
Sensors: System Temperatures: cpu: 34.5 C mobo: 29.8 C gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Info: Processes: 260 Uptime: 47m Memory: 31.32 GiB used: 3.13 GiB (10.0%) Init: systemd Compilers:
gcc: 10.2.0 Packages: 1194 Shell: Zsh v: 5.8 inxi: 3.3.00
