Well, if you downloaded the firmware files from the linux-firmware repository, I think you just copied the exact same version you had before. Unless you applied that patch I mentioned?
How would I apply this? I don’t see an obvious download button for the files, and most sites I lookup reference using git commands, which I’m unfamiliar with.
Afraid I’m not too familiar with dmesg, but I was able to follow your steps and copy over the firmware files. Unfortunately, I haven’t noticed too much of a change ;;
Looking back at my firmware folder, I can confirm that the newer uncompressed files made it over, though seeing the older compressed files there along with every other file with a zst extension does make me a bit paranoid.
Switched over to Pop OS, thought I was in the clear when I saw my Wi-Fi speed clear 100 mega bytes per second, but after a little while I began running into the same issue of slower download speeds, websites hanging and Wi-Fi suddenly becoming unavailable, despite showing as connected.
I’m unsure what to do at this point, besides grab an Ethernet chord and adapter and see if that fares better for home use.
