This is why I thought the keyring wasn’t causing the issue (since it had already been fixed and I downloaded a new ISO), and I spent several hours troubleshooting before deciding to refresh arch-keyring and to my surprise that fixed the issue.
In any case, I’m back to my main issue of wifi not working.
Is the WiFi not showing? Or just not working?
Edit: Sometimes the keyring is updated during updates. I know this has happened just lately.
Wifi interface was showing & working for a few hours after install, and then disappeared without a trace. It does not work now unless I plug in an external dongle. It works in a live environment, so obviously the card itself works fine.
Did you try reinstalling the iwlwifi-driver?
Not sure why it would disappear? Check /var/log/pacman.log for all updates in and around the time you you think the problem happened. Maybe you can narrow it down to an update that happened?
inxi -Na
@thereillywriter
I just had a new kernel too…
This is a fresh install now. I’m not sure how to re-install iwlwifi as it is part of the kernel? Output is much the same as before with the old install pre-kernel panic.
$ inxi -na
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: 00:2b:67:64:21:e3
Device-3: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 1-5:12 chip-ID: 148f:7601 class-ID: 0000 serial: 1.0
IF: wlan0 state: up mac: 20:32:33:c6:62:93
Device 3 is the dongle which is working perfectly.
iwlwifi is a kernel module. Yes there are some packages in the AUR but normally you don’t install iwlwifi.
I can’t do that - it’s a kernel module.
$ sudo pacman -S iwlwifi
error: target not found: iwlwifi
https://wiki.archlinux.org/title/Network_configuration/Wireless
dmesg | grep iwlwifi
Check kernel messages for firmware being loaded:
dmesg | grep firmware
[ 7.148259] iwlwifi 0000:02:00.0: loaded firmware version 39.30.4.1 build 35138 op_mode iwldvm
If there is no relevant output, check the messages for the full output for the module you identified earlier (iwlwifi in this example) to identify the relevant message or further issues:
[ 12.342694] iwlwifi 0000:02:00.0: irq 44 for MSI/MSI-X
[ 12.353466] iwlwifi 0000:02:00.0: loaded firmware version 39.31.5.1 build 35138 op_mode iwldvm
[ 12.430317] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 12.430341] iwlwifi 0000:02:00.0: Detected Intel(R) Corporation WiFi Link 5100 AGN, REV=0x6B
You can try unloading and loading the module but i doubt that’s going to help.
sudo rmmod iwlwifi
sudo modprobe iwlwifi
Hope this tells you something useful - it’s quite beyond my ken:
$ sudo dmesg | grep iwlwifi
[ 3.380579] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 3.457280] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 3.457301] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 3.458118] iwlwifi 0000:00:14.3: loaded firmware version 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode op_mode iwlmvm
[ 6.362306] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 8.149351] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[ 8.149381] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[ 8.149407] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[ 8.149412] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 8.149507] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 8.149510] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 1711787732
[ 8.149515] iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
[ 8.149519] iwlwifi 0000:00:14.3: 0xF9A15A43 | ADVANCED_SYSASSERT
[ 8.149524] iwlwifi 0000:00:14.3: 0x9B97D29B | trm_hw_status0
[ 8.149527] iwlwifi 0000:00:14.3: 0xCB7D5F31 | trm_hw_status1
[ 8.149530] iwlwifi 0000:00:14.3: 0xA3224942 | branchlink2
[ 8.149533] iwlwifi 0000:00:14.3: 0x2104623B | interruptlink1
[ 8.149535] iwlwifi 0000:00:14.3: 0x634943E4 | interruptlink2
[ 8.149538] iwlwifi 0000:00:14.3: 0xB4576E74 | data1
[ 8.149541] iwlwifi 0000:00:14.3: 0xF2BA1BDC | data2
[ 8.149544] iwlwifi 0000:00:14.3: 0x9C5FB1EA | data3
[ 8.149546] iwlwifi 0000:00:14.3: 0xFF7E2DEE | beacon time
[ 8.149549] iwlwifi 0000:00:14.3: 0xFD5EC915 | tsf low
[ 8.149552] iwlwifi 0000:00:14.3: 0x28C3FE70 | tsf hi
[ 8.149555] iwlwifi 0000:00:14.3: 0x4607872E | time gp1
[ 8.149558] iwlwifi 0000:00:14.3: 0xCEB134F8 | time gp2
[ 8.149560] iwlwifi 0000:00:14.3: 0xEEF2FDA1 | uCode revision type
[ 8.149564] iwlwifi 0000:00:14.3: 0xCA257C06 | uCode version major
[ 8.149566] iwlwifi 0000:00:14.3: 0x8855D8D6 | uCode version minor
[ 8.149569] iwlwifi 0000:00:14.3: 0xBCF9852B | hw version
[ 8.149572] iwlwifi 0000:00:14.3: 0x762F10AD | board version
[ 8.149575] iwlwifi 0000:00:14.3: 0xD37CD1F6 | hcmd
[ 8.149578] iwlwifi 0000:00:14.3: 0x4B5A0A38 | isr0
[ 8.149581] iwlwifi 0000:00:14.3: 0x515220A6 | isr1
[ 8.149583] iwlwifi 0000:00:14.3: 0x73D37BB5 | isr2
[ 8.149586] iwlwifi 0000:00:14.3: 0x3BB6064F | isr3
[ 8.149589] iwlwifi 0000:00:14.3: 0x582417D0 | isr4
[ 8.149591] iwlwifi 0000:00:14.3: 0x51D23286 | last cmd Id
[ 8.149594] iwlwifi 0000:00:14.3: 0xF7E9A196 | wait_event
[ 8.149597] iwlwifi 0000:00:14.3: 0xA76CECAB | l2p_control
[ 8.149600] iwlwifi 0000:00:14.3: 0x7E39A09B | l2p_duration
[ 8.149603] iwlwifi 0000:00:14.3: 0xC422610C | l2p_mhvalid
[ 8.149605] iwlwifi 0000:00:14.3: 0x6CCE655A | l2p_addr_match
[ 8.149608] iwlwifi 0000:00:14.3: 0x4104DD3C | lmpm_pmg_sel
[ 8.149611] iwlwifi 0000:00:14.3: 0xE63545E0 | timestamp
[ 8.149615] iwlwifi 0000:00:14.3: 0xED5B8DBA | flow_handler
[ 8.149654] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 8.149657] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: -2800490
[ 8.149661] iwlwifi 0000:00:14.3: 0xC3AE7CA8 | ADVANCED_SYSASSERT
[ 8.149665] iwlwifi 0000:00:14.3: 0x92E35FE6 | umac branchlink1
[ 8.149668] iwlwifi 0000:00:14.3: 0xA3B9A62B | umac branchlink2
[ 8.149670] iwlwifi 0000:00:14.3: 0x08F7D16A | umac interruptlink1
[ 8.149674] iwlwifi 0000:00:14.3: 0xC69DB218 | umac interruptlink2
[ 8.149677] iwlwifi 0000:00:14.3: 0xD9866D8C | umac data1
[ 8.149679] iwlwifi 0000:00:14.3: 0xFD65408B | umac data2
[ 8.149682] iwlwifi 0000:00:14.3: 0x99ED4737 | umac data3
[ 8.149685] iwlwifi 0000:00:14.3: 0xF7F3FD28 | umac major
[ 8.149688] iwlwifi 0000:00:14.3: 0xBEEDA3DE | umac minor
[ 8.149691] iwlwifi 0000:00:14.3: 0x2D557073 | frame pointer
[ 8.149693] iwlwifi 0000:00:14.3: 0xE1FA9FF3 | stack pointer
[ 8.149696] iwlwifi 0000:00:14.3: 0xCA9FF236 | last host cmd
[ 8.149699] iwlwifi 0000:00:14.3: 0x47B7D2DF | isr status reg
[ 8.149720] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 8.149723] iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
[ 8.149726] iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
[ 8.149747] iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
[ 8.149774] iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
[ 8.149798] iwlwifi 0000:00:14.3: Fseq Registers:
[ 8.149818] iwlwifi 0000:00:14.3: 0x60000041 | FSEQ_ERROR_CODE
[ 8.149823] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[ 8.149842] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 8.149864] iwlwifi 0000:00:14.3: 0x0000A481 | FSEQ_OTP_VERSION
[ 8.149885] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 8.149891] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 8.149911] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 8.149916] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 8.149936] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 8.149973] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[ 8.150075] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 8.150156] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 8.150175] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 8.150181] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 8.993508] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 9.006158] iwlwifi 0000:00:14.3: retry init count 0
[ 9.007552] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 10.079004] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[ 10.079032] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[ 10.079059] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[ 10.079063] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 10.079154] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 10.079157] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 1678220237
[ 10.079162] iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
[ 10.079165] iwlwifi 0000:00:14.3: 0xF9A15A40 | ADVANCED_SYSASSERT
[ 10.079169] iwlwifi 0000:00:14.3: 0x9BD7D29A | trm_hw_status0
[ 10.079172] iwlwifi 0000:00:14.3: 0xCB7D5F31 | trm_hw_status1
[ 10.079175] iwlwifi 0000:00:14.3: 0x890F8952 | branchlink2
[ 10.079177] iwlwifi 0000:00:14.3: 0x21E47A3B | interruptlink1
[ 10.079180] iwlwifi 0000:00:14.3: 0xE38B6BE4 | interruptlink2
[ 10.079182] iwlwifi 0000:00:14.3: 0xB2956E74 | data1
[ 10.079185] iwlwifi 0000:00:14.3: 0xE2AB1BDC | data2
[ 10.079187] iwlwifi 0000:00:14.3: 0xD05DB1EA | data3
[ 10.079190] iwlwifi 0000:00:14.3: 0xEA7D6CEE | beacon time
[ 10.079192] iwlwifi 0000:00:14.3: 0xFF3AC337 | tsf low
[ 10.079195] iwlwifi 0000:00:14.3: 0x68D23E70 | tsf hi
[ 10.079197] iwlwifi 0000:00:14.3: 0x8617872C | time gp1
[ 10.079200] iwlwifi 0000:00:14.3: 0xCEB1F9DC | time gp2
[ 10.079202] iwlwifi 0000:00:14.3: 0xEE62FDA5 | uCode revision type
[ 10.079205] iwlwifi 0000:00:14.3: 0x5A857F2F | uCode version major
[ 10.079208] iwlwifi 0000:00:14.3: 0x8855D8FC | uCode version minor
[ 10.079210] iwlwifi 0000:00:14.3: 0xBC59D4A3 | hw version
[ 10.079213] iwlwifi 0000:00:14.3: 0x756B129D | board version
[ 10.079215] iwlwifi 0000:00:14.3: 0xD356D2F6 | hcmd
[ 10.079218] iwlwifi 0000:00:14.3: 0x4B080AA8 | isr0
[ 10.079220] iwlwifi 0000:00:14.3: 0xD45228C6 | isr1
[ 10.079223] iwlwifi 0000:00:14.3: 0xFFD37BB5 | isr2
[ 10.079225] iwlwifi 0000:00:14.3: 0x1FB6668D | isr3
[ 10.079227] iwlwifi 0000:00:14.3: 0xD0AC1714 | isr4
[ 10.079230] iwlwifi 0000:00:14.3: 0x599233BF | last cmd Id
[ 10.079232] iwlwifi 0000:00:14.3: 0xF7F0839E | wait_event
[ 10.079235] iwlwifi 0000:00:14.3: 0xA76CECA9 | l2p_control
[ 10.079237] iwlwifi 0000:00:14.3: 0x7E3DA0F9 | l2p_duration
[ 10.079240] iwlwifi 0000:00:14.3: 0xD4222544 | l2p_mhvalid
[ 10.079243] iwlwifi 0000:00:14.3: 0x75CEE55A | l2p_addr_match
[ 10.079245] iwlwifi 0000:00:14.3: 0x6504EF3C | lmpm_pmg_sel
[ 10.079248] iwlwifi 0000:00:14.3: 0xE637C5E0 | timestamp
[ 10.079250] iwlwifi 0000:00:14.3: 0x7D588DA3 | flow_handler
[ 10.079289] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 10.079291] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: -540977774
[ 10.079295] iwlwifi 0000:00:14.3: 0xC3AE4FBE | ADVANCED_SYSASSERT
[ 10.079298] iwlwifi 0000:00:14.3: 0x84BB5B86 | umac branchlink1
[ 10.079301] iwlwifi 0000:00:14.3: 0xA38BA12B | umac branchlink2
[ 10.079303] iwlwifi 0000:00:14.3: 0x02F1D18E | umac interruptlink1
[ 10.079306] iwlwifi 0000:00:14.3: 0x629DD238 | umac interruptlink2
[ 10.079309] iwlwifi 0000:00:14.3: 0xC00E6DA6 | umac data1
[ 10.079311] iwlwifi 0000:00:14.3: 0xB96D569B | umac data2
[ 10.079314] iwlwifi 0000:00:14.3: 0x9DF54716 | umac data3
[ 10.079316] iwlwifi 0000:00:14.3: 0x7FF3D46B | umac major
[ 10.079319] iwlwifi 0000:00:14.3: 0x3665AFC8 | umac minor
[ 10.079321] iwlwifi 0000:00:14.3: 0xACDD2073 | frame pointer
[ 10.079324] iwlwifi 0000:00:14.3: 0xE1DA9FF3 | stack pointer
[ 10.079326] iwlwifi 0000:00:14.3: 0x0B077A3E | last host cmd
[ 10.079329] iwlwifi 0000:00:14.3: 0x47B7D2DF | isr status reg
[ 10.079349] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 10.079352] iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
[ 10.079354] iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
[ 10.079376] iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
[ 10.079402] iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
[ 10.079427] iwlwifi 0000:00:14.3: Fseq Registers:
[ 10.079447] iwlwifi 0000:00:14.3: 0x60000041 | FSEQ_ERROR_CODE
[ 10.079451] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[ 10.079471] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 10.079476] iwlwifi 0000:00:14.3: 0x0000A481 | FSEQ_OTP_VERSION
[ 10.079495] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 10.079500] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 10.079520] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 10.079524] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 10.079544] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 10.079581] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[ 10.079664] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 10.079749] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 10.079769] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 10.079773] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 10.931156] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 10.943767] iwlwifi 0000:00:14.3: retry init count 1
[ 10.945270] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 11.989134] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[ 11.989163] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[ 11.989189] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[ 11.989194] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 11.989288] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 11.989291] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 1712823237
[ 11.989296] iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
[ 11.989300] iwlwifi 0000:00:14.3: 0xFDA15BE3 | ADVANCED_SYSASSERT
[ 11.989305] iwlwifi 0000:00:14.3: 0x4BC7D29A | trm_hw_status0
[ 11.989309] iwlwifi 0000:00:14.3: 0xCB7D5F31 | trm_hw_status1
[ 11.989312] iwlwifi 0000:00:14.3: 0xA32E0C52 | branchlink2
[ 11.989315] iwlwifi 0000:00:14.3: 0x23446878 | interruptlink1
[ 11.989317] iwlwifi 0000:00:14.3: 0x8B8B23E4 | interruptlink2
[ 11.989320] iwlwifi 0000:00:14.3: 0xB0956E74 | data1
[ 11.989323] iwlwifi 0000:00:14.3: 0xE2AA1BDC | data2
[ 11.989326] iwlwifi 0000:00:14.3: 0x045FB1EA | data3
[ 11.989329] iwlwifi 0000:00:14.3: 0xA37D2DEC | beacon time
[ 11.989332] iwlwifi 0000:00:14.3: 0xFF3ECB51 | tsf low
[ 11.989334] iwlwifi 0000:00:14.3: 0x28C3FE70 | tsf hi
[ 11.989337] iwlwifi 0000:00:14.3: 0x46170F2C | time gp1
[ 11.989340] iwlwifi 0000:00:14.3: 0xCEB1F6FC | time gp2
[ 11.989343] iwlwifi 0000:00:14.3: 0xBEA0FDC5 | uCode revision type
[ 11.989346] iwlwifi 0000:00:14.3: 0x5A257F0A | uCode version major
[ 11.989348] iwlwifi 0000:00:14.3: 0x8855C8D6 | uCode version minor
[ 11.989351] iwlwifi 0000:00:14.3: 0xBC59852B | hw version
[ 11.989354] iwlwifi 0000:00:14.3: 0x752B58AD | board version
[ 11.989357] iwlwifi 0000:00:14.3: 0xD354D0ED | hcmd
[ 11.989360] iwlwifi 0000:00:14.3: 0x4B08C838 | isr0
[ 11.989362] iwlwifi 0000:00:14.3: 0x105228A6 | isr1
[ 11.989365] iwlwifi 0000:00:14.3: 0xFBD3EB85 | isr2
[ 11.989368] iwlwifi 0000:00:14.3: 0x39B4068D | isr3
[ 11.989370] iwlwifi 0000:00:14.3: 0x9C241731 | isr4
[ 11.989373] iwlwifi 0000:00:14.3: 0xC1D33213 | last cmd Id
[ 11.989376] iwlwifi 0000:00:14.3: 0xF7D9919E | wait_event
[ 11.989379] iwlwifi 0000:00:14.3: 0xA76CEDAB | l2p_control
[ 11.989381] iwlwifi 0000:00:14.3: 0x7EB1B959 | l2p_duration
[ 11.989384] iwlwifi 0000:00:14.3: 0xC422250C | l2p_mhvalid
[ 11.989387] iwlwifi 0000:00:14.3: 0xFDCE675A | l2p_addr_match
[ 11.989390] iwlwifi 0000:00:14.3: 0x4104EDB4 | lmpm_pmg_sel
[ 11.989393] iwlwifi 0000:00:14.3: 0xE6374540 | timestamp
[ 11.989396] iwlwifi 0000:00:14.3: 0x7D7BAD93 | flow_handler
[ 11.989435] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 11.989437] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: -7256298
[ 11.989442] iwlwifi 0000:00:14.3: 0xC3BA65A8 | ADVANCED_SYSASSERT
[ 11.989445] iwlwifi 0000:00:14.3: 0x84BB5B86 | umac branchlink1
[ 11.989448] iwlwifi 0000:00:14.3: 0xAB89A473 | umac branchlink2
[ 11.989451] iwlwifi 0000:00:14.3: 0x28E7D1EE | umac interruptlink1
[ 11.989454] iwlwifi 0000:00:14.3: 0x029D9238 | umac interruptlink2
[ 11.989457] iwlwifi 0000:00:14.3: 0xD90E6DA6 | umac data1
[ 11.989460] iwlwifi 0000:00:14.3: 0xB96D420F | umac data2
[ 11.989463] iwlwifi 0000:00:14.3: 0x95F54737 | umac data3
[ 11.989466] iwlwifi 0000:00:14.3: 0x7EC7D428 | umac major
[ 11.989468] iwlwifi 0000:00:14.3: 0x36EDAFDE | umac minor
[ 11.989471] iwlwifi 0000:00:14.3: 0x3C55E839 | frame pointer
[ 11.989474] iwlwifi 0000:00:14.3: 0xB1D09FE5 | stack pointer
[ 11.989477] iwlwifi 0000:00:14.3: 0xCB67F227 | last host cmd
[ 11.989480] iwlwifi 0000:00:14.3: 0xC7C710DF | isr status reg
[ 11.989500] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 11.989503] iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
[ 11.989506] iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
[ 11.989527] iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
[ 11.989554] iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
[ 11.989578] iwlwifi 0000:00:14.3: Fseq Registers:
[ 11.989598] iwlwifi 0000:00:14.3: 0x60000041 | FSEQ_ERROR_CODE
[ 11.989602] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[ 11.989622] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 11.989644] iwlwifi 0000:00:14.3: 0x0000A481 | FSEQ_OTP_VERSION
[ 11.989649] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 11.989670] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 11.989675] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 11.989695] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 11.989700] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 11.989752] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[ 11.989835] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 11.989920] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 11.989940] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 11.989944] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 12.837224] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 12.849039] iwlwifi 0000:00:14.3: retry init count 2
[ 101.249665] iwlmvm: unknown parameter 'iwlwifi' ignored
[ 101.272419] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 101.272431] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 101.272673] iwlwifi 0000:00:14.3: loaded firmware version 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode op_mode iwlmvm
[ 101.274253] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 102.311183] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[ 102.311214] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[ 102.311241] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[ 102.311247] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 102.311343] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 102.311346] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 1711796932
[ 102.311352] iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
[ 102.311356] iwlwifi 0000:00:14.3: 0xFDA15A40 | ADVANCED_SYSASSERT
[ 102.311361] iwlwifi 0000:00:14.3: 0x5BC7D29B | trm_hw_status0
[ 102.311365] iwlwifi 0000:00:14.3: 0xCB7D5F31 | trm_hw_status1
[ 102.311369] iwlwifi 0000:00:14.3: 0xA32A4978 | branchlink2
[ 102.311372] iwlwifi 0000:00:14.3: 0x21456A32 | interruptlink1
[ 102.311375] iwlwifi 0000:00:14.3: 0x8B4963E4 | interruptlink2
[ 102.311378] iwlwifi 0000:00:14.3: 0xA6956E74 | data1
[ 102.311381] iwlwifi 0000:00:14.3: 0xE2AB1BDC | data2
[ 102.311384] iwlwifi 0000:00:14.3: 0xD05F94EA | data3
[ 102.311387] iwlwifi 0000:00:14.3: 0xEA7E2DEE | beacon time
[ 102.311390] iwlwifi 0000:00:14.3: 0xFF9ECBF5 | tsf low
[ 102.311394] iwlwifi 0000:00:14.3: 0x28C33C70 | tsf hi
[ 102.311397] iwlwifi 0000:00:14.3: 0x02070F3A | time gp1
[ 102.311400] iwlwifi 0000:00:14.3: 0xCEB17EFC | time gp2
[ 102.311403] iwlwifi 0000:00:14.3: 0xE662FD84 | uCode revision type
[ 102.311407] iwlwifi 0000:00:14.3: 0xFAAD7C04 | uCode version major
[ 102.311410] iwlwifi 0000:00:14.3: 0x2855C8D6 | uCode version minor
[ 102.311413] iwlwifi 0000:00:14.3: 0xBC599CA3 | hw version
[ 102.311416] iwlwifi 0000:00:14.3: 0x752BB0AD | board version
[ 102.311420] iwlwifi 0000:00:14.3: 0xD3F4D2EF | hcmd
[ 102.311423] iwlwifi 0000:00:14.3: 0xC31E1C6A | isr0
[ 102.311426] iwlwifi 0000:00:14.3: 0xD45228C6 | isr1
[ 102.311429] iwlwifi 0000:00:14.3: 0xFFD3EBB5 | isr2
[ 102.311432] iwlwifi 0000:00:14.3: 0x69B662A7 | isr3
[ 102.311435] iwlwifi 0000:00:14.3: 0x98AC1711 | isr4
[ 102.311438] iwlwifi 0000:00:14.3: 0x59D33213 | last cmd Id
[ 102.311441] iwlwifi 0000:00:14.3: 0xF7E9F39E | wait_event
[ 102.311444] iwlwifi 0000:00:14.3: 0x8F6CEC28 | l2p_control
[ 102.311447] iwlwifi 0000:00:14.3: 0x7EBDA0C9 | l2p_duration
[ 102.311450] iwlwifi 0000:00:14.3: 0xD402250C | l2p_mhvalid
[ 102.311454] iwlwifi 0000:00:14.3: 0x7CCEE55A | l2p_addr_match
[ 102.311457] iwlwifi 0000:00:14.3: 0x6404F73C | lmpm_pmg_sel
[ 102.311460] iwlwifi 0000:00:14.3: 0xF23645E0 | timestamp
[ 102.311463] iwlwifi 0000:00:14.3: 0x5D588DBA | flow_handler
[ 102.311504] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 102.311507] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: -275692522
[ 102.311512] iwlwifi 0000:00:14.3: 0xC33A4FA8 | ADVANCED_SYSASSERT
[ 102.311516] iwlwifi 0000:00:14.3: 0x84E35FE6 | umac branchlink1
[ 102.311520] iwlwifi 0000:00:14.3: 0xA389AC1F | umac branchlink2
[ 102.311523] iwlwifi 0000:00:14.3: 0x28E7D1C8 | umac interruptlink1
[ 102.311526] iwlwifi 0000:00:14.3: 0xC09DB679 | umac interruptlink2
[ 102.311529] iwlwifi 0000:00:14.3: 0xC00E6DA6 | umac data1
[ 102.311532] iwlwifi 0000:00:14.3: 0xB96D428A | umac data2
[ 102.311535] iwlwifi 0000:00:14.3: 0xB9F54737 | umac data3
[ 102.311538] iwlwifi 0000:00:14.3: 0x7BC3D42C | umac major
[ 102.311542] iwlwifi 0000:00:14.3: 0x3675ABDE | umac minor
[ 102.311545] iwlwifi 0000:00:14.3: 0xAC556859 | frame pointer
[ 102.311548] iwlwifi 0000:00:14.3: 0xE1FA8BE3 | stack pointer
[ 102.311551] iwlwifi 0000:00:14.3: 0xCB8FF23E | last host cmd
[ 102.311554] iwlwifi 0000:00:14.3: 0x4FB5D2DF | isr status reg
[ 102.311576] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 102.311579] iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
[ 102.311582] iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
[ 102.311606] iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
[ 102.311632] iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
[ 102.311656] iwlwifi 0000:00:14.3: Fseq Registers:
[ 102.311676] iwlwifi 0000:00:14.3: 0x60000041 | FSEQ_ERROR_CODE
[ 102.311697] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[ 102.311719] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 102.311740] iwlwifi 0000:00:14.3: 0x0000A481 | FSEQ_OTP_VERSION
[ 102.311762] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 102.311783] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 102.311804] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 102.311826] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 102.311847] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 102.311901] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[ 102.311985] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 102.312068] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 102.312087] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 102.312092] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 103.160660] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 103.173282] iwlwifi 0000:00:14.3: retry init count 0
[ 103.174771] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 104.230715] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[ 104.230766] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[ 104.230793] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[ 104.230798] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 104.230893] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 104.230896] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 1711790292
[ 104.230902] iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
[ 104.230906] iwlwifi 0000:00:14.3: 0xB1A15BC6 | ADVANCED_SYSASSERT
[ 104.230912] iwlwifi 0000:00:14.3: 0x4B97D29A | trm_hw_status0
[ 104.230916] iwlwifi 0000:00:14.3: 0xCBED0731 | trm_hw_status1
[ 104.230919] iwlwifi 0000:00:14.3: 0xA32A4940 | branchlink2
[ 104.230922] iwlwifi 0000:00:14.3: 0x034DE078 | interruptlink1
[ 104.230926] iwlwifi 0000:00:14.3: 0xE3A123E4 | interruptlink2
[ 104.230929] iwlwifi 0000:00:14.3: 0xA4576E74 | data1
[ 104.230932] iwlwifi 0000:00:14.3: 0xE2AB1ADC | data2
[ 104.230935] iwlwifi 0000:00:14.3: 0x045FF0EA | data3
[ 104.230939] iwlwifi 0000:00:14.3: 0xE2BF6CEE | beacon time
[ 104.230942] iwlwifi 0000:00:14.3: 0x7E3EC975 | tsf low
[ 104.230945] iwlwifi 0000:00:14.3: 0x08C32A10 | tsf hi
[ 104.230949] iwlwifi 0000:00:14.3: 0x0217872C | time gp1
[ 104.230952] iwlwifi 0000:00:14.3: 0xCEB1F6FC | time gp2
[ 104.230955] iwlwifi 0000:00:14.3: 0xBE62FDA1 | uCode revision type
[ 104.230958] iwlwifi 0000:00:14.3: 0xCAAD7905 | uCode version major
[ 104.230961] iwlwifi 0000:00:14.3: 0x8855CED6 | uCode version minor
[ 104.230965] iwlwifi 0000:00:14.3: 0xBC4914A3 | hw version
[ 104.230968] iwlwifi 0000:00:14.3: 0x752B9AAE | board version
[ 104.230971] iwlwifi 0000:00:14.3: 0xD394D2EF | hcmd
[ 104.230974] iwlwifi 0000:00:14.3: 0xCA5A096A | isr0
[ 104.230977] iwlwifi 0000:00:14.3: 0xD85228C6 | isr1
[ 104.230980] iwlwifi 0000:00:14.3: 0xFFD37BB5 | isr2
[ 104.230983] iwlwifi 0000:00:14.3: 0x39B4622F | isr3
[ 104.230986] iwlwifi 0000:00:14.3: 0xD0341614 | isr4
[ 104.230989] iwlwifi 0000:00:14.3: 0x59D33281 | last cmd Id
[ 104.230992] iwlwifi 0000:00:14.3: 0xF7E9A396 | wait_event
[ 104.230995] iwlwifi 0000:00:14.3: 0xA76CEC0D | l2p_control
[ 104.230999] iwlwifi 0000:00:14.3: 0x7EBDB9C9 | l2p_duration
[ 104.231002] iwlwifi 0000:00:14.3: 0xD4022544 | l2p_mhvalid
[ 104.231005] iwlwifi 0000:00:14.3: 0x7CEE675A | l2p_addr_match
[ 104.231008] iwlwifi 0000:00:14.3: 0x64048F3C | lmpm_pmg_sel
[ 104.231012] iwlwifi 0000:00:14.3: 0xE4364541 | timestamp
[ 104.231015] iwlwifi 0000:00:14.3: 0x77798D93 | flow_handler
[ 104.231055] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 104.231058] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: -271465434
[ 104.231063] iwlwifi 0000:00:14.3: 0xC3AAEDF9 | ADVANCED_SYSASSERT
[ 104.231067] iwlwifi 0000:00:14.3: 0x84E35B24 | umac branchlink1
[ 104.231070] iwlwifi 0000:00:14.3: 0xE389A43B | umac branchlink2
[ 104.231073] iwlwifi 0000:00:14.3: 0x28F7D12A | umac interruptlink1
[ 104.231077] iwlwifi 0000:00:14.3: 0x4E9DB238 | umac interruptlink2
[ 104.231080] iwlwifi 0000:00:14.3: 0xC0866DA6 | umac data1
[ 104.231083] iwlwifi 0000:00:14.3: 0xB96F421B | umac data2
[ 104.231086] iwlwifi 0000:00:14.3: 0x9DF54716 | umac data3
[ 104.231089] iwlwifi 0000:00:14.3: 0x3EC39CEA | umac major
[ 104.231092] iwlwifi 0000:00:14.3: 0x36ED27DE | umac minor
[ 104.231095] iwlwifi 0000:00:14.3: 0xACDD6039 | frame pointer
[ 104.231098] iwlwifi 0000:00:14.3: 0xB1D29F27 | stack pointer
[ 104.231102] iwlwifi 0000:00:14.3: 0x58077A36 | last host cmd
[ 104.231105] iwlwifi 0000:00:14.3: 0x43C7D2DF | isr status reg
[ 104.231127] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 104.231129] iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
[ 104.231133] iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
[ 104.231154] iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
[ 104.231181] iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
[ 104.231206] iwlwifi 0000:00:14.3: Fseq Registers:
[ 104.231226] iwlwifi 0000:00:14.3: 0x60000041 | FSEQ_ERROR_CODE
[ 104.231247] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[ 104.231269] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 104.231290] iwlwifi 0000:00:14.3: 0x0000A481 | FSEQ_OTP_VERSION
[ 104.231311] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 104.231333] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 104.231355] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 104.231377] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 104.231399] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 104.231452] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[ 104.231536] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 104.231619] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 104.231639] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 104.231644] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 105.093306] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 105.105630] iwlwifi 0000:00:14.3: retry init count 1
[ 105.107867] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 106.160310] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[ 106.160341] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[ 106.160367] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[ 106.160373] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 106.160467] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 106.160470] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 1711741637
[ 106.160476] iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
[ 106.160481] iwlwifi 0000:00:14.3: 0xFFA15B43 | ADVANCED_SYSASSERT
[ 106.160486] iwlwifi 0000:00:14.3: 0x5BD7D2BA | trm_hw_status0
[ 106.160490] iwlwifi 0000:00:14.3: 0xCB7D4F31 | trm_hw_status1
[ 106.160493] iwlwifi 0000:00:14.3: 0xA32A4950 | branchlink2
[ 106.160496] iwlwifi 0000:00:14.3: 0x23672238 | interruptlink1
[ 106.160499] iwlwifi 0000:00:14.3: 0xEB8941E4 | interruptlink2
[ 106.160502] iwlwifi 0000:00:14.3: 0xE4577E74 | data1
[ 106.160505] iwlwifi 0000:00:14.3: 0xE2BA1BDC | data2
[ 106.160509] iwlwifi 0000:00:14.3: 0x125F30EA | data3
[ 106.160512] iwlwifi 0000:00:14.3: 0xE9FE2DEE | beacon time
[ 106.160515] iwlwifi 0000:00:14.3: 0xFF5EC3F5 | tsf low
[ 106.160518] iwlwifi 0000:00:14.3: 0x0842FE70 | tsf hi
[ 106.160522] iwlwifi 0000:00:14.3: 0x46070F2C | time gp1
[ 106.160525] iwlwifi 0000:00:14.3: 0xDEB1BED8 | time gp2
[ 106.160528] iwlwifi 0000:00:14.3: 0xEEF27CC5 | uCode revision type
[ 106.160531] iwlwifi 0000:00:14.3: 0x5AAD7F36 | uCode version major
[ 106.160534] iwlwifi 0000:00:14.3: 0xEA55CAFC | uCode version minor
[ 106.160538] iwlwifi 0000:00:14.3: 0xBCF9852B | hw version
[ 106.160541] iwlwifi 0000:00:14.3: 0x752BB0AD | board version
[ 106.160544] iwlwifi 0000:00:14.3: 0xD2F4D0EC | hcmd
[ 106.160547] iwlwifi 0000:00:14.3: 0x4B5A0AA8 | isr0
[ 106.160550] iwlwifi 0000:00:14.3: 0xC43228A6 | isr1
[ 106.160553] iwlwifi 0000:00:14.3: 0x73D37BB5 | isr2
[ 106.160556] iwlwifi 0000:00:14.3: 0x39B4064F | isr3
[ 106.160559] iwlwifi 0000:00:14.3: 0xD8B51731 | isr4
[ 106.160562] iwlwifi 0000:00:14.3: 0x51D23183 | last cmd Id
[ 106.160565] iwlwifi 0000:00:14.3: 0xF7E9E59E | wait_event
[ 106.160568] iwlwifi 0000:00:14.3: 0xA36CEC28 | l2p_control
[ 106.160572] iwlwifi 0000:00:14.3: 0x3FBDA0C9 | l2p_duration
[ 106.160575] iwlwifi 0000:00:14.3: 0xC422610C | l2p_mhvalid
[ 106.160578] iwlwifi 0000:00:14.3: 0x7CCE675A | l2p_addr_match
[ 106.160581] iwlwifi 0000:00:14.3: 0x64048F3C | lmpm_pmg_sel
[ 106.160584] iwlwifi 0000:00:14.3: 0xE63545C5 | timestamp
[ 106.160588] iwlwifi 0000:00:14.3: 0xF458A7B3 | flow_handler
[ 106.160629] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 106.160632] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: -38707690
[ 106.160637] iwlwifi 0000:00:14.3: 0xC3BA7DF8 | ADVANCED_SYSASSERT
[ 106.160641] iwlwifi 0000:00:14.3: 0x84BB5FE6 | umac branchlink1
[ 106.160644] iwlwifi 0000:00:14.3: 0xA389A43B | umac branchlink2
[ 106.160647] iwlwifi 0000:00:14.3: 0x08F7D16A | umac interruptlink1
[ 106.160651] iwlwifi 0000:00:14.3: 0xC2D7B679 | umac interruptlink2
[ 106.160654] iwlwifi 0000:00:14.3: 0xC00E6DA6 | umac data1
[ 106.160657] iwlwifi 0000:00:14.3: 0xB92C401B | umac data2
[ 106.160660] iwlwifi 0000:00:14.3: 0x1D7D4737 | umac data3
[ 106.160663] iwlwifi 0000:00:14.3: 0xFF63E428 | umac major
[ 106.160666] iwlwifi 0000:00:14.3: 0x36758EDE | umac minor
[ 106.160669] iwlwifi 0000:00:14.3: 0xAC55E8B1 | frame pointer
[ 106.160673] iwlwifi 0000:00:14.3: 0xB1FA896B | stack pointer
[ 106.160676] iwlwifi 0000:00:14.3: 0x8307F23E | last host cmd
[ 106.160679] iwlwifi 0000:00:14.3: 0x4786D2F6 | isr status reg
[ 106.160700] iwlwifi 0000:00:14.3: IML/ROM dump:
[ 106.160703] iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
[ 106.160706] iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
[ 106.160730] iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
[ 106.160757] iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
[ 106.160781] iwlwifi 0000:00:14.3: Fseq Registers:
[ 106.160800] iwlwifi 0000:00:14.3: 0x60000041 | FSEQ_ERROR_CODE
[ 106.160823] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[ 106.160845] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 106.160867] iwlwifi 0000:00:14.3: 0x0000A481 | FSEQ_OTP_VERSION
[ 106.160888] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 106.160910] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 106.160932] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 106.160954] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 106.160975] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 106.161029] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[ 106.161112] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 106.161197] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 106.161216] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 106.161221] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 107.023320] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[ 107.035638] iwlwifi 0000:00:14.3: retry init count 2
The device can’t be loaded by the active kernel. Did you ever try using an lts-linux kernel?
Thanks for that! Interesting, wonder why it’s doing that? Sadly it’s the exact same on both the lts and rolling release kernel - I’m running the LTS right now and it’s failed to load also.
It seems you have to compile your own kernel as given in the instructions above (last link).
Assuming, you have linux-firmware (intel-ucode loading in grub) installed already:
The corresponding pkg for your Intel-Wifi kernel-driver “AX201” can be found here, from this site:
(If in doubt, do an on-site search for “AX201”.)
So …sorry to say, after all! Must be a real Wondoze Puter you got there. Or?
Very strange as the wifi card worked fine yesterday!
What I dug up is the only solution i cound find, ASIDE FROM failure reporting. Again, sorry!
