Any suggestions?
There are lots of kernel parameters. Like pcie_aspm=off or pci=nomsi or pci=noaer or you could try a windows one. acpi_osi='Windows 2021'
These are just some examples not for your wifi problem but the error messages.
Edit: Keep in mind sometimes these parameters can cause some issues also.
It was fixed automatically after the 6.0 kernel update.
Update: Not really. But I finally managed to fix it using the method described here.
In case the answer gets down or something, you basically have to create the following systemd unit file:
/etc/systemd/system/hp-keycodes.service
[Unit]
Description=HP setkeycodes fix
[Service]
Type=oneshot
Restart=no
RemainAfterExit=no
ExecStart=/usr/bin/setkeycodes e057 240 e058 240
[Install]
WantedBy=rescue.target
WantedBy=multi-user.target
WantedBy=graphical.target
and then enable it using
sudo systemctl daemon-reload
sudo systemctl enable --now hp-keycodes.service
and that should be it!
