Wifi connection flips between access points
I have a wifi issue - there are multiple access points in my building, and I seem to be on the edge between the range of some 2.4GHz, 6GHz, and 5GHz wifi signals all on the same wifi network that I connect to. The connection is great, but will often flip between access points and disrupt my connection (very bad for gaming). I concluded this was the cause after scanning the room with wifiman on my phone and seeing it connect to all of the different access points.
I have no experience with this sort of networking on linux, so please let me know of any ideas or resources that may be helpful. I need to get used to the networking stack on endeavouros. So far, my basic idea is to identify a good signal or two and blacklist everything else.
Here’s copilot’s advice. Let us know how you get on :slight_smile:
So the main issue is fixed, but now my school’s eduroam connection config is broken. The first fix was done by switching to iwd as the backend, by adding this to a file in networkmanager settings (/etc/NetworkManager/conf.d/roam-settings.conf):
[device]
wifi.backend=iwd
Now I face what seems to be a common issue with iwd+eduroam. My school has a setup-script, which connects nomally when using wpa_supplicant as the backend. In the case of iwd, it creates a config for the connection (/var/lib/iwd/eduroam.8021x):
# Auto-generated from NetworkManager connection "eduroam [***]"
# Changes to that connection overwrite this file when enabled by NM's [main].iwd-config-path value
[Settings]
AutoConnect=false
[IPv6]
Enabled=true
[Security]
EAP-Method=TTLS
EAP-Identity=**@**.**
EAP-TTLS-CACert=/home/**/.joinnow/usertrustrsaca [jdk]-comodoaaaca [jdk]-bundle.pem
EAP-TTLS-ServerDomainMask=*.***
EAP-TTLS-Phase2-Method=Tunneled-PAP
EAP-TTLS-Phase2-Identity=**
EAP-TTLS-Phase2-Password=**
Now iwd fails when connecting and repeats the log:
Sep 23 23:27:42 ** iwd[1106]: Failed to load /home/**/.joinnow/usertrustrsaca [jdk]-comodoaaaca [jdk]-bundle.pem
The error stems (My current theory from reading similar similar posts) from the ProtectHome variable with iwd.service - ie this cert should be moved somewhere else than home. The only issue is I do not know how to change the cert location without being overridden by NM, as the comment in the above file points out. I need to get a better sense of the NM stack and ways to edit NM settings here.
So close! Please let me know how to tidy this problem up.
Paste it into copilot :wink:
It can’t quite solve the issue of connecting to eduroam with iwd
