Why there is no obvious way to set power settings (e.g. sleep settings)?
I’m using budgie desktop with EndeavourOS and I can’t seem to find a way to set the power settings, similar to Windows where I can set when it would sleep or not.
You are either missing packages that provide access to those settings, or you’re looking in the wrong place.
Let’s look at the optional dependencies:
$ pacman -Si budgie-desktop
Repository : community
Version : 10.5.2+24+g7a5dcfda-1
Depends On : accountsservice gnome-bluetooth gnome-menus gnome-session gnome-themes-standard graphene libibus libpeas libwnck3 mutter
Optional Deps : budgie-desktop-view: Desktop icons
gnome-backgrounds: Default background
gnome-control-center: System settings
gnome-screensaver: Lock screen
network-manager-applet: Network management
very much sounds related, so do you have that installed?
You can also read more about configuring Budgie under Arch via the wiki: https://wiki.archlinux.org/index.php/Budgie
Right click on empty space on the desktop, then click on “system settings”.
In the left column, click on “Power”. Unless you have a lap top, I would turn “Automatic Suspend” off. The rest are pretty explanatory.
Go back to the “Settings” screen and in the left column, click on “Privacy” then click on “screenlock”. Now set up your screen lock.
HTH
Pudge
