In KDE Plasma there is a feature which let you paste sticky nodes on your desktop when pressing mouse wheel. 2 weeks ago I redownloaded the os and now this feature isn’t working anymore.
I think that should enable it, but it doesn’t work either
Have you made sure you have copied text? It doesn’t add blank notes
yes I copied text, this is not the problem
Ok, just thought I would check, works fine on mine, have you all check that the sticky notes widget is installed? I know not all widgets are included by default
Is the name of the widget just sticky notes? Because I cannot find it under “paste” “sticky note” or just “note(s)”. But when I click on “get new widget” I don’t find it there either
I’m about 90% sure it’s part of this package
kdeplasma-addons
Thanks it really is part of the package. Kinda weird it wasn’t preinstalled like the last time I downloaded the os, but you helped me so much
You’re welcome
