I’ve recently updated to Gnome 40, but everything looks the same as before, i.e. none of the new gestures do anything, the launcher is still on the LHS and the applications grid looks the same. What am I doing wrong? So far I’ve:
Rebooted
Disabled all extensions
Reset the “Applications” & “Icons” themes to “Adwaita-dark” & “Adwaita”
Logged out to check whether there’s a new desktop type to select in GDM
Have you installed it from the main repo or the testing repo? If you’ve installed it from the main, it is still version 3.38. Usually it takes two weeks before it hits the main repo.
Over here it didn’t reach the mirrors yet, I think, and this is usually the case with Arch, it is a hallfway update, so to say.
Arch usually releases DE components in parts, be prepared for a whole lot of update batches the upcoming days.
I was about to get on here to ask the same question. i’ve had the same issue with it and i noticed that a lot of the gnome apps are version 40 but gnome-shell is still 3.38 which is weird and it says that it’s version 40 in the settings. so it looks like what @Bryanpwo said, it’s just a partial update and it’ll probably take a week or two for gnome-shell to update to version 40
