sticks
March 4, 2023, 4:16pm
1
Hi,
I have installed Cassini Neo with the normal XFCE Interface.
Now I want to test Plasma too.
I saw this article in the wiki:
https://discovery.endeavouros.com/desktop-environments/how-to-install-desktop-environments-next-to-your-existing-ones/2021/03/
But now I don’t know which command is the right one, if I want Plasma installed like it was installed directly from the ISO.
dalto
March 4, 2023, 4:53pm
2
Installing multiple DEs is not a great way to test them. A VM is a much better solution if you have at least 8GB of RAM. You will avoid potential conflicts that way.
Try this:
sudo pacman -S eos-packagelist
eos-packagelist KDE-Desktop --install
sticks
March 4, 2023, 6:16pm
3
I know it is not the best solution.
But I have a snapshot of my system, so I can revert back easily
Gamall
March 5, 2023, 8:05pm
4
Does that include a snapshot of your $HOME? If not you may at the very least end up with a lot of lint in .local, .config, etc.
system
Closed
March 7, 2023, 8:05pm
5
