So when there’s an update, i get asked if I want to keep unneeded dependencies after installation.
My understanding on that topic is the following:
These dependencies are “tools” my computer needs to build Anki, but they are not required to run it afterwards.
→ I can delete the tools.
But when I need to update, I’ll probably need the tools again?
→ So it would be clever to leave the dependencies?
But will these dependencies change over time, so they can accumulate?
→ Removing orphans from time to time would do the trick?
Is there a rather fast and noobfriendly way to check whether keeping dependencies would be a smart move?
You don’t use it as a user unless for build once-in-update
It’s BLOAT
It’s potential point of failure / security issue (just logically - more stuff you have installed - more stuff there is to break, this is called “wider attack surface”) this is especially applicable with that program you’ve link, because it uses nodejs / yarn build dependencies which can be huge risk longterm.
But you do you of course
Not really, just plain logic and your personal needs.
