Now I installed the snap-store snap. It starts but where there should be letters there are placeholders/rectangles instead like iit wants to use a font which is not installed or so.
Output:
[peter@monastir ~]$ snap-store
07:30:02:0052 Gs enabled plugins: odrs, rewrite-resource, snap, icons, key-colors, key-colors-metadata
07:30:02:0052 Gs disabled plugins: appstream, desktop-categories, desktop-menu-path, dpkg, dummy, epiphany, fedora-pkgdb-collections, generic-updates, hardcoded-blacklist, hardcoded-featured, hardcoded-popular, modalias, os-release, provenance, provenance-license, repos, shell-extensions
07:30:02:0211 Gs failed to create an app for */*/*/*/system/*
07:30:02:0218 Gs updates-shell: failed to get updates: no plugin could handle get-updates
07:30:02:0220 Gs failed to create an app for */*/*/*/system/*
07:30:02:0220 Gs failed to get system app
07:30:02:0220 Gs Only 0 apps for recent list, hiding
07:30:02:0230 GsPluginSnap Failed to load snap icon: local snap has no icon
07:30:02:0404 Gs hiding category graphics featured applications: found only 0 to show, need at least 9
07:30:02:0404 Gs hiding category productivity featured applications: found only 0 to show, need at least 9
07:30:02:0486 GLib g_path_get_basename: assertion 'file_name != NULL' failed
07:30:02:0486 GLib g_regex_match_full: assertion 'string != NULL' failed
07:30:02:0504 GLib g_variant_new_variant: assertion 'value != NULL' failed
07:30:02:0504 Gs not GsPlugin error g-io-error-quark:35: Invalid string value converting to GVariant
07:30:02:0505 Gs not handling error failed for action refine: Invalid string value converting to GVariant
07:30:02:0512 GsPluginSnap Failed to load snap icon: local snap has no icon
07:30:02:0690 GsPluginSnap Failed to load snap icon: local snap has no icon
Pleease assist!
Best regards,
Peter
