ive tried to install mutilpe packages such as KIO-gdrive, cava, etc and when i try to install these packages i get the error Manual intervention is required what exactly is yay asking for here and how do i fix this
Please show the full list of errors here, and use the
button to make the output more readable.
for KIO-gdrive
Cloning into bare repository '/home/octo/.cache/yay/kio-gdrive-git/kio-gdrive'...
fatal: unable to connect to anongit.kde.org:
anongit.kde.org[0: 85.10.198.44]: errno=Connection refused
anongit.kde.org[1: 2a01:4f8:a0:600e::3]: errno=Network is unreachable
==> ERROR: Failure while downloading kio-gdrive git repo
Aborting...
-> error making: kio-gdrive-git-exit status 1
-> Failed to install the following packages. Manual intervention is required:
kio-gdrive-git - exit status 1
for cava
Makefile.am: installing './depcomp'
/usr/share/automake-1.17/am/depend2.am: error: am__fastdepCC does not appear in AM_CONDITIONAL
/usr/share/automake-1.17/am/depend2.am: The usual way to define 'am__fastdepCC' is to add 'AC_PROG_CC'
/usr/share/automake-1.17/am/depend2.am: to 'configure.ac' and run 'aclocal' and 'autoconf' again
/usr/share/automake-1.17/am/depend2.am: error: AMDEP does not appear in AM_CONDITIONAL
/usr/share/automake-1.17/am/depend2.am: The usual way to define 'AMDEP' is to add one of the compiler tests
/usr/share/automake-1.17/am/depend2.am: AC_PROG_CC, AC_PROG_CXX, AC_PROG_OBJC, AC_PROG_OBJCXX,
/usr/share/automake-1.17/am/depend2.am: AM_PROG_AS, AM_PROG_GCJ, AM_PROG_UPC
==> ERROR: A failure occurred in build().
Aborting...
-> error making: cava-exit status 4
cava - exit status 4
it means exactly what it says. You gotta do something manually to fix it. In this case you gotta manually download kio-gdrive because yay failed to fetch it on it’s own.
You may want to learn to read, write and edit aur PKGBUILDs to make it easier to resolve these kinds of issues.
- network error
- try a clean build
The kio-gdrive-git package is orphaned, and hasn’t been updated since October 2018. The upstream links also lead nowhere meaningful.
I’m not sure exactly what the application did, but I would suggest exploring an alternative, maintained solution.
The cava package currently needs an update. Otherwise, you could try cava-git if you don’t mind running a bleeding edge, and possibly buggy version.
i ended up getting cava to work by reinstalling endeavouros as for kio-drive-git its a google drive thing for dolphin and i havent been able to find anything like it
Have you tried yay kio-gdrive ? I found that one to be in the extra repository.
May you should try google-drive-ocamlfuse instead. Haven’t tried it and according to the comments there might be some inconvenient extra steps required to get it to work.
Find latest release versions here: https://launchpad.net/~alessandro-strada/+archive/ubuntu/ppa
The latest releases are not all tagged versions on GitHub.
For the latest development versions on git, try: https://aur.archlinux.org/packages/google-drive-ocamlfuse-git
