I need my laptop to last a minimum of 2 hours, whilst on power saving mode and on the lowest brightness level.
I have a laptop that has a bit of a crappy battery. So it will usually last about an hour or so, depending on what I’m doing. And at the moment I’m unable to get a new battery for it, so I have to look at other options aside from getting a new battery for now.
I’ve been using GNOME for a while now, and I’ve seen that it lasts about 1 hour (sometimes 30 mins) on Balanced power mode and the maximum brightness level.
I’ve also seen that it lasts about 1 hour 40 minutes (sometimes 1 hour 20 minutes) on the lowest brightness level, and on Power Saver mode.
I used KDE one time, doing the same things that I did when using GNOME and found that it lasts 1 hour on the lowest brightness level and on power saving mode.
While I can see that GNOME is works better in my case, but I really like KDE, so I would also like to know if there’s anything I could change on KDE that could hopefully make it last longer, since I need it to last up to 2 hours.
