It prompts me for my password to complete the action
I have a laptop with a hybrid intel/Nvidia GPU which works really well with optimus manager qt configured properly
Is there a better way I can be using my hybrid GPU? Or am I misunderstanding the command there and it just wants to uninstall a useless part of Nvidia configuration?
It is nothing wrong with that. Optimus Hardware nowadays can be run with either proprietary Nvidia OR with Nouveau driver. Some time ago one necessarily needed the proprietary driver.
I’ll check my KDE one right now, then enter those commands in the terminal
On KDE it just says ‘pacman -Rsn nvidia’ and nothing else
I entered the commands, the second one didn’t do anything and just went to the next line. The last one didn’t work, probably because I said no to the installations
I noticed some new system updates a moment ago so I installed them. They were actually for the kernel and Nvidia, maybe these messages in the bottom right have something to do with it
@Archnoob
Thanks for the lspci listing!
That reveals an issue in the device-info command. That’s why welcome app falsely tried to remove nvidia packages. Sorry about that!
Device-info is now fixed, so after updating your system (including welcome), the welcome app should work as expected.
To make sure it works as expected, please show again the output of command
