Weird window behavior on second monitor
Hey guys,
its me again :smiley: i installed fresh eos+plasma yesterday. Running on wayland. When there is a program on my second monitor on fullscreen and I minimize a window on my first monitor, the program on the second isnt scaling right. See the video.
Video
Can someone point me in the right direction of the arch wiki to look at? :slight_smile: Heres the outcome of inxi from eos log tool:
#################### inxi -Fxxc0z ########################
  Kernel: 6.6.52-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM Distro: EndeavourOS
    base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: A.C0 date: 03/06/2023
  Info: 8-core model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ rev: 2 cache:
    L1: 512 KiB L2: 4 MiB L3: 96 MiB
  Speed (MHz): avg: 2781 high: 4550 min/max: 2200/4549 boost: enabled cores: 1: 3637 2: 2200
    3: 2200 4: 3400 5: 2200 6: 2200 7: 2200 8: 3640 9: 2200 10: 2200 11: 3640 12: 4550 13: 3638
    14: 2200 15: 2200 16: 2200 bogomips: 108835
  Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] vendor: Tul / PowerColor driver: amdgpu
    v: kernel arch: RDNA-3 pcie: speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-3
    empty: DP-2,HDMI-A-1 bus-ID: 2d:00.0 chip-ID: 1002:747e
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2 compositor: kwin_wayland
    driver: X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu d-rect: 5120x1440 display-ID: 0
  Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A
  Monitor-2: DP-3 pos: primary,left res: 2560x1440 size: N/A
  API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.3-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi navi32 LLVM 18.1.8 DRM 3.54
    6.6.52-1-lts) device-ID: 1002:747e display-ID: :1.0
  API: Vulkan v: 1.3.295 surfaces: xcb,xlib,wayland device: 0 type: discrete-gpu
    driver: mesa radv device-ID: 1002:747e
  Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
    lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab30
  Device-2: SteelSeries ApS Arctis Nova 4 driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-1:2 chip-ID: 1038:12f2
  Device-3: Elgato Systems GmbH Wave:3 driver: snd-usb-audio type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 bus-ID: 3-1:2 chip-ID: 0fd9:0070
  API: ALSA v: k6.6.52-1-lts status: kernel-api
  Server-1: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
    driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
    chip-ID: 10ec:8168
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel pcie:
    speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0 chip-ID: 10ec:8125
  IF: enp42s0 state: down mac: <filter>
  Local Storage: total: 2.95 TiB used: 138.74 GiB (4.6%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M81000G size: 931.51 GiB speed: 31.6 Gb/s
    lanes: 4 serial: <filter> temp: 31.9 C
  ID-2: /dev/nvme1n1 vendor: Crucial model: CT1000P3PSSD8 size: 931.51 GiB speed: 63.2 Gb/s
    lanes: 4 serial: <filter> temp: 30.9 C
  ID-3: /dev/sda vendor: SanDisk model: SSD PLUS 240 GB size: 223.58 GiB speed: 6.0 Gb/s
    serial: <filter>
  ID-4: /dev/sdb vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB speed: 6.0 Gb/s
    serial: <filter>
  ID-1: / size: 906.17 GiB used: 138.74 GiB (15.3%) fs: ext4 dev: /dev/sdb2
  ID-2: /boot/efi size: 1022 MiB used: 288 KiB (0.0%) fs: vfat dev: /dev/sdb1
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb3
  System Temperatures: cpu: 38.1 C mobo: N/A gpu: amdgpu temp: 42.0 C mem: 50.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 19
  Memory: total: 32 GiB available: 31.26 GiB used: 4.61 GiB (14.7%)
  Processes: 438 Power: uptime: 12m wakeups: 0 Init: systemd v: 256 default: graphical
  Packages: pm: pacman pkgs: 1075 Compilers: gcc: 14.2.1 Client: shell wrapper v: 5.2.32-release
    inxi: 3.3.35
I doubt the wiki will help with this one. I think we would be better off seeing if other people can reproduce this issue.
For what it is worth. It isn’t happening for me on Plasma 6.2 beta. I have an nvidia graphics card though.
i turned off freesync on both of my monitors and it seems gone. gonna work my way through freesync/vrr documentation later today and try to fix this. also asked on the kde forums and some are in the same boat since kde 6
